System Administration Guide: Network Services
unshare Command
This command allows you to make a previously available file system unavailable for mounting by clients. You can use the unshare command to unshare any file system, whether the file system was shared explicitly with the share command or automatically through /etc/dfs/dfstab. If you use the unshare command to unshare a file system that you shared through the dfstab file, be careful. Remember that the file system is shared again when you exit and reenter run level 3. You must remove the entry for this file system from the dfstab file if the change is to continue.
When you unshare an NFS file system, access from clients with existing mounts is inhibited. The file system might still be mounted on the client, but the files are not accessible.
Note –
For information about how NFS version 4 functions when a file system is unshared and then reshared, refer to Unsharing and Resharing a File System in NFS Version 4.
The following is an example of unsharing a specific file system:
# unshare /usr/src
