System Administration Guide: Network Services
shareall Command
This command allows for multiple file systems to be shared. When used with no options, the command shares all entries in /etc/dfs/dfstab. You can include a file name to specify the name of a file that lists share command lines. If you do not include a file name, /etc/dfs/dfstab is checked. If you use a “-” to replace the file name, you can type share commands from standard input.
The following is an example of sharing all file systems that are listed in a local file:
# shareall /etc/dfs/special_dfstab
