System Administration Guide: Network Services
ProcedureHow to Add UUCP Logins
To allow a remote machine to access your system, you need to add an entry to the /etc/passwd file as follows:
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Edit the /etc/passwd file and add the entry to identify the machine that is permitted to access your system.
    A typical entry that you might put into the /etc/passwd file for a remote machine that is permitted to access your system with a UUCP connection would be as follows:
    By convention, the login name of a remote machine is the machine name preceded by the uppercase letter U. Note that the name should not exceed eight characters. Otherwise, you might have to truncate or abbreviate the name.
    The previous entry shows that a login request by Ugobi is answered by /usr/lib/uucp/uucico. The home directory is /var/spool/uucppublic. The password is obtained from the /etc/shadow file. You must coordinate the password and the login name with the UUCP administrator of the remote machine. The remote administrator must then add an appropriate entry, with login name and unencrypted password, in the remote machine's Systems file.
  3. Coordinate your machine name with the UUCP administrators on other systems.
    Similarly, you must coordinate your machine's name and password with the UUCP administrators of all machines that you want to reach through UUCP.
