System Administration Guide: Network Services
UUCP Administration (Task Map)
The following table provides pointers to the procedures that are covered in this chapter, in addition to a short description of each procedure.
Table 25–1 Task Map for UUCP Administration
Task
Description
For Instructions
Allow remote machines to have access to your system
Edit the /etc/passwd file to add entries to identify the machines that are permitted to access your system.
How to Add UUCP Logins
Start UUCP
Use the supplied shell scripts to start UUCP.
How to Start UUCP
Enable UUCP to work with TCP/IP
Edit /etc/inetd.conf and /etc/uucp/Systems files to activate UUCP for TCP/IP.
How to Activate UUCP for TCP/IP
Troubleshoot some common UUCP problems
Use diagnostic steps to check for faulty modems or ACUs.
How to Check for Faulty Modems or ACUs
Use diagnostic steps to debug transmissions.
How to Debug Transmissions
