System Administration Guide: Network Services
What's New for the Solaris 9 FTP Server?
Significant changes were made to the FTP Server in the Solaris 9 release, so this section has been retained for the Solaris 10 release. The FTP Server is compatible with Solaris 8 FTP software, yet offers new capability with improved performance for Solaris 9 users.
Table 27–1 What's New for the Solaris 9 FTP Server
Feature
Description
For Information
User classification by type and location
Permits you to define a class of users, based on type and address
How to Define FTP Server Classes
Limits per class
Controls the number of users from a certain class who are allowed simultaneous login, based on limits that are set in the ftpaccess file
How to Set User Login Limits
System-wide and directory-related messages
Displays the messages that you specify for particular events
How to Create Messages to Be Sent to Users
Upload permissions per directory
Allows you to control uploads to the FTP Server, including file and directory creation and permissions
How to Control Uploads to the FTP Server
File name filter
Enables you to specify which characters, in what sequence, are acceptable in the name of an uploaded file
Virtual host support
Permits you to configure the FTP server to support multiple domains on a single machine
How to Enable Complete Virtual Hosting
Command logging
Allows logging of commands that are executed by real, guest, and anonymous FTP users
How to Check the Commands Executed by FTP Users
Transfer logging
Allows logging of transfers for real, guest, and anonymous FTP users
ftpaccess(4), xferlog(4), in.ftpd(1M)
As-needed compression and archiving
Allows as-needed compression and archiving by using conversions that are specified in the ftpconversions file
ftpconversions(4), ftpaccess(4)
The following list shows the Solaris 8 features that are not supported in later releases.
