System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Chapter 7 NIS Troubleshooting
This chapter explains how to resolve problems encountered on networks running NIS. It covers problems seen on an NIS client and those seen on an NIS server.
Before trying to debug an NIS server or client, review Chapter 4, Network Information Service (NIS) (Overview) which explains the NIS environment. Then look for the subheading in this section that best describes your problem.
Note –
The NIS service is managed by the Service Management Facility. Administrative actions on this service, such as enabling, disabling, or restarting, can be performed by using the svcadm command. See NIS and the Service Management Facility for more information about using SMF with NIS. For an overview of SMF, refer to Chapter 18, Managing Services (Overview), in System Administration Guide: Basic Administration. Also refer to the svcadm(1M) and svcs(1) man pages for more details.
NIS services can also be started and stopped by using the ypstart and ypstop commands. See the ypstart(1M) and ypstop(1M) man pages for more information.
NIS Binding Problems
Common symptoms of NIS binding problems include the following.
NIS Problems Affecting One Client
If only one or two clients are experiencing symptoms that indicate NIS binding difficulty, the problems probably are on those clients. If many NIS clients are failing to bind properly, the problem probably exists on one or more of the NIS servers. See NIS Problems Affecting Many Clients.
ypbind Not Running on Client
One client has problems, but other clients on the same subnet are operating normally. On the problem client, run ls -l on a directory, such as /usr, that contains files owned by many users, including some not in the client /etc/passwd file. If the resulting display lists file owners who are not in the local /etc/passwd as numbers, rather than names, this indicates that NIS service is not working on the client.
These symptoms usually mean that the client ypbind process is not running. Verify whether the NIS client service is running.
client# svcs network/nis/client
STATE          STIME    FMRI
disabled       Sep_01   svc:/network/nis/client:default
If the client is disabled, log in as superuser, or assume an equivalent role, and start the NIS client service.
client# svcadm enable network/nis/client
Missing or Incorrect Domain Name
One client has problems, the other clients are operating normally, but ypbind is running on the problem client. The client might have an incorrectly set domain.
On the client, run the domainname command to see which domain name is set.
client7# domainname
Compare the output with the actual domain name in /var/yp on the NIS master server. The actual NIS domain is shown as a subdirectory in the /var/yp directory.
Client7# ls /var/yp...
-rwxr-xr-x 1 root Makefile
drwxr-xr-x 2 root binding
drwx------ 2 root ...
If the domain name returned by running domainname on a machine is not the same as the server domain name listed as a directory in /var/yp, the domain name specified in the machine's /etc/defaultdomain file is incorrect. Log in as superuser or assume an equivalent role, and correct the client's domain name in the machine's /etc/defaultdomain file. This assures that the domain name is correct every time the machine boots. Now reboot the machine.
Note –
The domain name is case-sensitive.
Client Not Bound to Server
If your domain name is set correctly, ypbind is running, and commands still hang, then make sure that the client is bound to a server by running the ypwhich command. If you have just started ypbind, then run ypwhich several times (typically, the first one reports that the domain is not bound and the second succeeds normally).
No Server Available
If your domain name is set correctly, ypbind is running, and you get messages indicating that the client cannot communicate with a server, this might indicate a number of different problems:
ypwhich Displays Are Inconsistent
When you use ypwhich several times on the same client, the resulting display varies because the NIS server changes. This is normal. The binding of the NIS client to the NIS server changes over time when the network or the NIS servers are busy. Whenever possible, the network becomes stable at a point where all clients get acceptable response time from the NIS servers. As long as your client machine gets NIS service, it does not matter where the service comes from. For example, an NIS server machine can get its own NIS services from another NIS server on the network.
When Server Binding is Not Possible
In extreme cases where local server binding is not possible, use of the ypset command can temporarily allow binding to another server, if available, on another network or subnet. However, in order to use the -ypset option, ypbind must be started with either the -ypset or -ypsetme options. For more information, see the ypbind(1M) man page.
# /usr/lib/netsvc/yp/ypbind -ypset
For another method, see Binding to a Specific NIS Server.
Note –
For security reasons, the use of the -ypset and -ypsetme options should be limited to debugging purposes under controlled circumstances. Use of the -ypset and -ypsetme options can result in serious security breaches because while the daemons are running, anyone can alter server bindings causing trouble for others and permitting unauthorized access to sensitive data. If you must start ypbind with these options, once you have fixed the problem you should kill ypbind and restart it again without those options.
To restart ypbind, use the service management facility (SMF):
# svcadm enable -r svc:/network/nis/client:default
ypbind Crashes
If ypbind crashes almost immediately each time it is started, look for a problem in some other part of the system. Check for the presence of the rpcbind daemon by typing the following.
% ps -e | grep rpcbind
If rpcbind is not present or does not stay up or behaves strangely, consult your RPC documentation.
You might be able to communicate with rpcbind on the problematic client from a machine operating normally. From the functioning machine, type the following.
% rpcinfo client
If rpcbind on the problematic machine is fine, rpcinfo produces the following output.
program	version	netid	address	service	owner
100007	2	udp	ypbind	superuser
100007	1	udp	ypbind	superuser
100007	1	tcp	ypbind	superuser
100007	2	tcp	ypbind	superuser
100007	2	ticotsord	\000\000\020H	ypbind	superuser
100007	2	ticots	\000\000\020K	ypbind	superuser
Your machine will have different addresses. If the addresses are not displayed, ypbind has been unable to register its services. Reboot the machine and run rpcinfo again. If the ypbind processes are there and they change each time you try to restart the NIS service, reboot the system, even if the rpcbind daemon is running.
If only one or two clients are experiencing symptoms that indicate NIS binding difficulty, the problems probably are on those clients. See NIS Problems Affecting One Client. If many NIS clients are failing to bind properly, the problem probably exists on one or more of the NIS servers.
rpc.yppasswdd Considers a Non-Restricted Shell That Begins With r to be Restricted
  1. Create /etc/default/yppasswdd that contains a special string: "check_restricted_shell_name=1".
  2. If the "check_restricted_shell_name=1" string is commented out, the 'r' check will no occur.
Network or Servers Are Overloaded
NIS can hang if the network or NIS servers are so overloaded that ypserv cannot get a response back to the client ypbind process within the time-out period.
Under these circumstances, every client on the network experiences the same or similar problems. In most cases, the condition is temporary. The messages usually go away when the NIS server reboots and restarts ypserv, or when the load on the NIS servers or network itself decreases.
Server Malfunction
Make sure the servers are up and running. If you are not physically near the servers, use the ping command.
NIS Daemons Not Running
If the servers are up and running, try to find a client machine behaving normally, and run the ypwhich command. If ypwhich does not respond, kill it. Then log in as root on the NIS server and check if the NIS process is running by entering the following.
# ps -e | grep yp
Note –
Do not use the -f option with ps because this option attempts to translate user IDs to names, which causes more naming service lookups that might not succeed.
If neither the NIS server (ypserv) nor the NIS client (ypbind) daemons are running, restart them by typing one of the following.
# svcadm restart network/nis/server
# /usr/lib/netsvc/yp/ypstop
# /usr/lib/netsvc/yp/ypstart
If both the ypserv and ypbind processes are running on the NIS server, then run ypwhich. If ypwhich does not respond, ypserv has probably hung and should be restarted. While logged in as root on the server, restart the NIS service by typing one of the following.
Servers Have Different Versions of an NIS Map
Because NIS propagates maps among servers, occasionally you might find different versions of the same map on various NIS servers on the network. This version discrepancy is normal add acceptable if the differences do not last for more than a short time.
The most common cause of map discrepancy is that something is preventing normal map propagation. For example, an NIS server or router between NIS servers is down. When all NIS servers and the routers between them are running, ypxfr should succeed.
If the servers and routers are functioning properly, check the following:
Logging ypxfr Output
If a particular slave server has problems updating maps, log in to that server and run ypxfr interactively. If ypxfr fails, it tells you why it failed, and you can fix the problem. If ypxfr succeeds, but you suspect it has occasionally failed, create a log file to enable logging of messages. To create a log file, enter the following on the slave.
ypslave# cd /var/yp
ypslave# touch ypxfr.log
This creates a ypxfr.log file that saves all output from ypxfr.
The output resembles the output ypxfr displays when run interactively, but each line in the log file is time stamped. (You might see unusual ordering in the time-stamps. That is okay – the time-stamp tells you when ypxfr started to run. If copies of ypxfr ran simultaneously but their work took differing amounts of time, they might actually write their summary status line to the log files in an order different from that which they were invoked.) Any pattern of intermittent failure shows up in the log.
Note –
When you have fixed the problem, turn off logging by removing the log file. If you forget to remove it, it continues to grow without limit.
Check the crontab File and ypxfr Shell Script
Inspect the root crontab file, and check the ypxfr shell script it invokes. Typographical errors in these files can cause propagation problems. Failures to refer to a shell script within the /var/spool/cron/crontabs/root file, or failures to refer to a map within any shell script can also cause errors.
Check the ypservers Map
Also, make sure that the NIS slave server is listed in the ypservers map on the master server for the domain. If it is not, the slave server still operates perfectly as a server, but yppush does not propagate map changes to the slave server.
Work Around
If the NIS slave server problem is not obvious, you can work around it while you debug using rcp or ftp to copy a recent version of the inconsistent map from any healthy NIS server. The following shows how to transfer the problem map.
ypslave# rcp ypmaster:/var/yp/mydomain/map.\* /var/yp/mydomain
The * character has been escaped in the command line, so that it will be expanded on ypmaster, instead of locally on ypslave.
ypserv Crashes
When the ypserv process crashes almost immediately, and does not stay up even with repeated activations, the debug process is virtually identical to that described in ypbind Crashes. Check for the existence of the rpcbind daemon as follows.
ypserver% ps -e | grep rpcbind
Reboot the server if you do not find the daemon. Otherwise, if the daemon is running, type the following and look for similar output.
% rpcinfo -p ypserver
% program 	vers 	proto 	port 	service
100000	4	tcp	111	portmapper
100000	3	tcp	111	portmapper
100068	2	udp	32813	cmsd
100007	1	tcp	34900	ypbind
100004	2	udp	731	ypserv
100004	1	udp	731	ypserv
100004	1	tcp	732	ypserv
100004	2	tcp	32772	ypserv
Your machine might have different port numbers. The four entries representing the ypserv process are the following.
If there are no entries, and ypserv is unable to register its services with rpcbind, reboot the machine. If there are entries, de-register the service from rpcbind before restarting ypserv. To de-register the service from rpcbind, on the server type the following.
# rpcinfo -d number 1
# rpcinfo -d number 2
where number is the ID number reported by rpcinfo (100004, in the example above).
