System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Chapter 6 Administering NIS (Tasks)
This chapter describes how to administer NIS. The following topics are covered.
Note –
The NIS service is managed by the Service Management Facility. Administrative actions on this service, such as enabling, disabling, or restarting, can be performed by using the svcadm command. See NIS and the Service Management Facility for more information about using SMF with NIS. For an overview of SMF, refer to Chapter 18, Managing Services (Overview), in System Administration Guide: Basic Administration. Also refer to thesvcadm(1M) and svcs(1) man pages for more details.
NIS services can also be started and stopped by using the ypstart and ypstop commands. See the ypstart(1M) and ypstop(1M) man pages for more information.
Password Files and Namespace Security
For security reasons, follow these guidelines.
For example, the master server password input files could be stored in a directory such as /var/yp, or any directory of your choice, as long as the file itself is not a link to another file and is specified in the Makefile. When you use either the Service Management Facility or the ypstart script to start the NIS service, the correct directory option is set according to the configuration specified in your Makefile.
Note –
In addition to the older Solaris 1 version passwd file format, this implementation of NIS accepts the Solaris 2 passwd and shadow file formats as input for building the NIS password maps.
Administering NIS Users
This section includes information about setting user passwords, adding new users to an NIS domain, and assigning users to netgroups.
ProcedureHow to Add a New NIS User to an NIS Domain
  1. On the master NIS server, become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Chapter 9, Using Role-Based Access Control (Tasks), in System Administration Guide: Security Services.
  2. Create the new user's login ID with the useradd command.
    # useradd userID
    userID is the login ID of the new user. This command creates entries in the /etc/passwd and /etc/shadow files on the master NIS server.
  3. Create the new user's initial password.
    To create an initial password that the new user can use to log in, run the passwd command.
    # passwd userID
    Where userID is the login ID of the new user. You will be prompted for the password to assign to this user.
    This step is necessary because the password entry created by the useradd command is locked, which means that the new user cannot log in. By specifying an initial password, you unlock the entry.
  4. If necessary, copy the new entry into the server's passwd map input files.
    The map source files on your master server should be in a directory other than /etc. Copy and paste the new lines from the /etc/passwd and /etc/shadow files into the passwd map input files on the server. See Password Files and Namespace Security for additional information.
    For example, if you added the new user brown, the line from /etc/passwd that you would copy to your passwd input file would look like the following.
    brown:x:123:10:User brown:/home/brown:/bin/csh:
    The line for brown that you would copy from /etc/shadow would look like:
  5. Make sure that the Makefile correctly specifies the directory where the password input file resides.
  6. If appropriate, delete the new user's entries from /etc/passwd and /etc/shadow input files.
    For security reasons, do not keep user entries in the NIS master server /etc/passwd and /etc/shadow files. After copying the entries for the new user to the NIS map source files that are stored in some other directory, use the userdel command on the master server to delete the new user.
    For example, to delete the new user brown from the master server's /etc files, you would enter the following.
    # userdel brown
    For more information about userdel, see the userdel man page.
  7. Update the NIS passwd maps.
    After you have updated the passwd input file on the master server, update the passwd maps by running make in the directory containing the source file.
    # userdel brown
    # cd /var/yp
    # /usr/ccs/bin/make passwd
  8. Tell the new user the initial password you have assigned to his or her login ID.
    After logging in, the new user can run passwd at any time to establish a different password.
Setting User Passwords
Users run passwd to change their passwords.
% passwd username
Before users can change their passwords, you must start the rpc.yppasswdd daemon on the master server to update the password file.
The rpc.yppasswdd daemon starts automatically on the master server. Notice that when the -m option is given to rpc.yppasswdd, a make is forced in /var/yp immediately following a modification of the file. If you want to avoid having this make take place each time the passwd file is changed, remove the -m option from the rpc.yppasswd command in the ypstart script and control the pushing of the passwd maps through the crontab file.
Note –
No arguments should follow the rpc.yppasswd -m command. Although you can edit the ypstart script file to achieve a different action, it is not recommended that you modify this file other than optionally removing the -m option. All commands and daemons invoked by this file with the proper set of command line parameters. If you choose to edit this file, be especially careful when editing the rpc.yppasswdd command. If you add an explicit call to the passwd.adjunct file, the exact $PWDIR/security/passwd.adjunct path must be used; otherwise, incorrect processing results.
NIS Netgroups
NIS netgroups are groups (sets) of users or machines that you define for your administrative purposes. For example, you can create netgroups that do the following.
Each netgroup is given a netgroup name. Netgroups do not directly set permissions or access rights. Instead, the netgroup names are used by other NIS maps in places where a user name or machine name would normally be used. For example, suppose you created a netgroup of network administrators called netadmins. To grant all members of the netadmins group access to a given machine, you need only add a netadmin entry to that machine's /etc/passwd file. Netgroup names can also be added to the /etc/netgroup file and propagated to the NIS netgroup map. See netgroup(4) for more detailed information on using netgroups.
On a network using NIS, the netgroup input file on the master NIS server is used for generating three maps: netgroup, netgroup.byuser, and netgroup.byhost. The netgroup map contains the basic information in the netgroup input file. The two other NIS maps contain information in a format that speeds lookups of netgroup information, given the machine or user.
Entries in the netgroup input file are in the format: name ID, where name is the name you give to a netgroup, and ID identifies a machine or user who belongs to the netgroup. You can specify as many IDs (members) to a netgroup as you want, separated by commas. For example, to create a netgroup with three members, the netgroup input file entry would be in the format: name ID, ID, ID. The member IDs in a netgroup input file entry are in the following format.
([-|machine], [-|user], [domain])
Where machine is a machine name, user is a user ID, and domain is the machine or user's NIS domain. The domain element is optional and should only be used to identify machines or users in some other NIS domain. The machine and user element of each member's entry are required, but a dash (-) is used to denote a null. There is no necessary relationship between the machine and user elements in an entry.
The following are two sample netgroup input file entries, each of which create a netgroup named admins composed of the users hauri and juanita who is in the remote domain sales and the machines altair and sirius.
admins (altair, hauri), (sirius,juanita,sales)
admins (altair,-), (sirius,-), (-,hauri), (-,juanita,sales)
Various programs use the netgroup NIS maps for permission checking during login, remote mount, remote login, and remote shell creation. These programs include mountd, login, rlogin, and rsh . The login command consults the netgroup maps for user classifications if it encounters netgroup names in the passwd database. The mountd daemon consults the netgroup maps for machine classifications if it encounters netgroup names in the /etc/dfs/dfstab file. rlogin and rsh In fact, any program that uses the ruserok interface consults the netgroup maps for both machine and user classifications if they encounter netgroup names in the /etc/hosts.equiv or .rhosts files.
If you add a new NIS user or machine to your network, be sure to add them to appropriate netgroups in the netgroup input file. Then use the make and yppush commands to create the netgroup maps and push them to all of your NIS servers. See netgroup(4) for detailed information on using netgroups and netgroup input file syntax.
Working With NIS Maps
This section contains the following information:
Obtaining Map Information
Users can obtain information from and about the maps at any time by using the ypcat, ypwhich, and ypmatch commands. In the examples that follow, mapname refers both to the official name of a map and to its nickname, if any.
To list all the values in a map, type the following.
% ypcat mapname
To list both the keys and the values (if any) in a map, type the following.
% ypcat -k mapname
To list all the map nicknames, type any of the following commands.
% ypcat -x
% ypmatch -x
% ypwhich -x
To list all the available maps and their master(s), type the following.
% ypwhich -m
To list the master server for a particular map, type the following.
% ypwhich -m mapname
To match a key with an entry in a map, type the following.
% ypmatch key mapname
If the item you are looking for is not a key in a map, type the following.
% ypcat mapname | grep item
where item is the information for which you are searching. To obtain information about other domains, use the -d domainname options of these commands.
If the machine requesting information for a domain other than its default does not have a binding for the requested domain, ypbindconsults the /var/yp/binding/domainname/ypservers file for a list of servers for that domain. If this file does not exist it issues an RPC broadcast for a server. In this case, there must be a server for the requested domain on the same subnet as the requesting machine.
Changing a Map's Master Server
To change the master server for a selected map, you first have to build the map on the new NIS master. Since the old master server name occurs as a key-value pair in the existing map (this pair is inserted automatically by makedbm), copying the map to the new master or transferring a copy to the new master with ypxfr is insufficient. You have to reassociate the key with the new master server name. If the map has an ASCII source file, you should copy this file to the new master.
ProcedureHow to Change a Map's Master Server
  1. On the new master, become superuser or assume an equivalent role.
  2. Change directories.
    newmaster# cd /var/yp
  3. The Makefile must have an entry for the new map before you specify the map to make. If this is not the case, edit the Makefile now, using a map called sites.byname.
  4. To update or remake the map, type the following.
    newmaster# make sites.byname
  5. If the old master remains an NIS server, remote log in (rlogin) to the old master and edit Makefile. Make sure you comment out the section of the Makefile that made sites.byname so that it is no longer made there.
  6. If sites.byname only exists as an ndbm file, remake it on the new master by disassembling a copy from any NIS server, then running the disassembled version through makedbm.
    newmaster# ypcat sites.byname | makedbm -domain-/sites.byname
    After making the map on the new master, you must send a copy of the new map to the other slave servers. Do not use yppush, because the other slaves will try to get new copies from the old master, rather than the new one. A typical method for circumventing this is to transfer a copy of the map from the new master back to the old master. To do this, become superuser, or assume an equivalent role, on the old master server and type the following.
    oldmaster# /usr/lib/netsvc/yp/ypxfr -h newmaster sites.byname
    Now it is safe to run yppush. Any remaining slave servers still believe that the old master is the current master and will attempt to get the current version of the map from the old master. When clients do so, they will get the new map, which names the new master as the current master.
    If this method fails, you can log in as root on each NIS server and execute the ypxfr command shown above.
Modifying Configuration Files
NIS intelligently parses the setup files. Although this makes NIS administration easier, it does make the behavior of NIS more sensitive to changes in the setup and configuration files.
Use the procedures in this section when modifying any of the following.
ProcedureHow to Modify Configuration Files
You do not have to stop and start NIS when changing NIS maps or the map source files.
Keep the following in mind.
  1. Become superuser or assume an equivalent role.
  2. Stop the NIS server.
    # svcadm disable network/nis/server
  3. Make the necessary changes to your files.
  4. Start the NIS server.
    # svcadm enable network/nis/server
Modifying and Using the Makefile
You can modify the Makefile provided by default in /var/yp to suit your needs. You can add or delete maps, and you can change the names of some of the directories.
Tip –
Keep an unmodified copy of the original Makefile for future reference.
Working With the Makefile
To add a new NIS map, you must get copies of the ndbm files for the map into the /var/yp/domainname directory on each of the NIS servers in the domain. This is normally done for you by the Makefile. After deciding which NIS server is the master of the map, modify the Makefile on the master server so that you can conveniently rebuild the map. Different servers can be masters of different maps, but in most cases this leads to administrative confusion. Try to set only one server as the master of all maps.
Typically a human-readable text file is filtered through awk, sed, or grep to make it suitable for input to makedbm. Refer to the default Makefile for examples. See the make(1S) for general information about the make command.
Use the mechanisms already in place in the Makefile when deciding how to create dependencies that make will recognize. Be aware that make is very sensitive to the presence or absence of tabs at the beginning of lines within the dependency rules. A missing tab can invalidate an entry that is otherwise well formed.
Adding an entry to the Makefile involves the following.
For example, in order for the Makefile to work on automounter input files, you would have to add the auto_direct.time and auto_home.time maps to the NIS database.
To add these maps to the NIS database you need to modify the Makefile.
Changing Makefile Macros/Variables
You can change the settings of the variables defined at the top of the Makefile by changing the value to the right of the equal sign (=). For instance, if you do not want to use the files located in /etc as input for the maps, but you would rather use files located in another directory, such as /var/etc/domainname, you should change DIR from DIR=/etc to DIR=/var/etc/domainname. You should also change PWDIR from PWDIR=/etc to PWDIR=/var/etc/domainname.
The variables are the following.
Modifying Makefile Entries
The following procedure describes how to add and delete databases from the Makefile.
ProcedureHow to Modify the Makefile to Use Specific Databases
  2. Modify the line that starts with the word all by adding the name(s) of the database you want to add:
    all: passwd group hosts ethers networks rpc services protocols \
    	netgroup bootparams aliases netid netmasks \
    	audit_user auth_attr exec_attr prof_attr \
      auto_direct auto_home auto_direct.time auto_home.time
    The order of the entries is not relevant, but the blank space at the beginning of the continuation lines must be a Tab, not spaces.
  3. Add the following lines at the end of the Makefile:
    auto_direct: auto_direct.time
    auto_home: auto_home.time
  4. Add an entry for auto_direct.time in the middle of the file.
    auto_direct.time: $(DIR)/auto_direct
     @(while read L; do echo $$L; done < $(DIR)/auto_direct
     $(CHKPIPE)) | \ (sed -e "/^#/d" -e "s/#.*$$//" -e "/^ *$$/d"
     $(CHKPIPE)) | \ $(MAKEDBM) - $(YPDBDIR)/$(DOM)/auto_direct;
     @touch auto_direct.time;
     @echo "updated auto_direct";
     @if [ ! $(NOPUSH) ]; then $(YPPUSH) auto_direct; fi
     @if [ ! $(NOPUSH) ]; then echo "pushed auto_direct"; fi
    • CHKPIPE makes certain that the operations to the left of the pipe (|) are successfully completed before piping the results to next commands. If the operations to the left of the pipe do not successfully complete, the process is terminated with a NIS make terminated message.
    • NOPUSH prevents the makefile from calling yppush to transfer the new map to the slave servers. If NOPUSH is not set, the push is done automatically.
    The while loop at the beginning is designed to eliminate any backslash-extended lines in the input file. The sed script eliminates comment and empty lines.
    The same procedure should be followed for all other automounter maps, such as auto_home, or any other nondefault maps.
  5. Run make.
    # make mapname
    Where mapname is the name of the map you want to make.
ProcedureHow to Modify the Makefile to Delete Databases
If you do not want the Makefile to produce maps for a specific database, edit the Makefile as follows.
  1. Delete the name of the database from the all rule.
  2. Delete or comment out the database rule for the database you want to delete.
    For example, to delete the hosts database, the hosts.time entry should be removed.
  3. Remove the time rule.
    For example, to delete the hosts database, the hosts: hosts.time entry should be removed.
  4. Remove the map from the master and slave servers.
Updating and Modifying Existing Maps
After you have installed NIS, you might discover that some maps require frequent updating while others never need to change. For example, the passwd.byname map can change frequently on a large company's network, while the auto_master map changes little, if at all.
As mentioned in Default NIS Maps, the default location of the default NIS maps is on the master server in /var/yp/domainname, where domainname is the name of the NIS domain. When you need to update a map, you can use one of two updating procedures, depending on whether or not it is a default map.
The following sections explain how to use various updating tools. In practice, you might decide to only use them if you add nondefault maps or change the set of NIS servers after the system is already up and running.
ProcedureHow to Update Maps Supplied With the Default Set
Use the following procedure for updating maps supplied with the default set.
  1. Become a superuser on the master server.
    Always modify NIS maps only on the master server.
  2. Edit the source file for the map you want to change, whether that file resides in /etc or in some other directory of your choice.
  3. Type the following.
    # cd /var/yp
    # make mapname
    The make command then updates your map according to the changes you made in its corresponding file. It also propagates the changes among the other servers.
Maintaining Updated Maps
The following sections describe additional procedures after you have completed updating maps that are supplied with the default set.
Propagating an NIS Map
After a map is changed, the Makefile uses yppush to propagate a new map to the slave servers (unless NOPUSH is set in the Makefile). It does this by informing the ypserv daemon and sending a map transfer request. The ypserv daemon on the slave then starts a ypxfr process, which in turn contacts the ypxfrd daemon on the master server. Some basic checks are made (for example did the map really change?) and then the map is transferred. ypxfr on the slave then sends a response to the yppush process indicating whether the transfer succeeded.
Note –
The above procedure will not work for newly created maps that do not yet exist on the slave servers. New maps must be sent to the slave servers by running ypxfr on the slaves.
Occasionally, maps fail to propagate and you must to use ypxfr manually to send new map information. You can choose to use ypxfr in two different ways: periodically through the root crontab file, or interactively on the command line. These approaches are discussed in the following sections.
Using cron for Map Transfers
Maps have different rates of change. For instance, some might not change for months at a time, such as protocols.byname among the default maps and auto_master among the nondefault maps; but passwd.byname can change several times a day. Scheduling map transfer using the crontab command allows you to set specific propagation times for individual maps.
To periodically run ypxfr at a rate appropriate for the map, the root crontab file on each slave server should contain the appropriate ypxfr entries. ypxfr contacts the master server and transfers the map only if the copy on the master server is more recent than the local copy.
Note –
If your master server runs rpc.yppasswdd with the default -m option, then each time someone changes their yp password, the passwd daemon runs make, which rebuilds the passwd maps.
Using Shell Scripts With cron and ypxfr
As an alternative to creating separate crontab entries for each map, you might prefer to have the root crontab command run a shell script that periodically updates all maps. Sample map-updating shell scripts are n the /usr/lib/netsvc/yp directory. The script names are ypxfr_1perday, ypxfr_1perhour, and ypxfr_2perday. You can modify or replace these shell scripts to fit your site requirements. Example 6–1 shows the default ypxfr_1perday shell script.
Example 6–1 ypxfr_1perday Shell Script
#! /bin/sh
# - Do daily yp map check/updates
export PATH
# set -xv
ypxfr group.byname
ypxfr group.bygid
ypxfr protocols.byname
ypxfr protocols.bynumber
ypxfr networks.byname
ypxfr networks.byaddr
ypxfr services.byname
ypxfr ypservers
This shell script updates the maps once per day, if the root crontab is executed daily. You can also have scripts that update maps once a week, once a month, once every hour, and so forth, but be aware of the performance degradation implied in frequently propagating the maps.
Run the same shell scripts as root on each slave server configured for the NIS domain. Alter the exact time of execution from one server to another to avoid bogging down the master.
If you want to transfer the map from a particular slave server, use the -h machine option of ypxfr within the shell script. Here is the syntax of the commands you put in the script.
# /usr/lib/netsvc/yp/ypxfr -h machine [ -c ] mapname
Where machine is the name of the server with the maps you want to transfer, and mapname is the name of the requested map. If you use the -h option without specifying a machine, ypxfr tries to get the map from the master server. If ypserv is not running locally at the time ypxfr is executed, you must use the -c flag so that ypxfr does not send a clear current map request to the local ypserver.
You can use the -s domain option to transfer maps from another domain to your local domain. These maps should be the same across domains. For example, two domains might share the same services.byname and services.byaddr maps. Alternatively, you can use rcp, or rdist for more control, to transfer files across domains.
Directly Invoking ypxfr
The second method of invoking ypxfr is to run it as a command. Typically, you do this only in exceptional situations – for example, when setting up a temporary NIS server to create a test environment or when trying to quickly get an NIS server that has been out of service consistent with the other servers.
Logging ypxfr Activity
The transfer attempts and results of ypxfr can be captured in a log file. If a file called /var/yp/ypxfr.log exists, results are appended to it. No attempt to limit the size of the log file is made. To prevent it from growing indefinitely, empty it from time to time by typing the following.
# cd /var/yp
# cp ypxfr.log ypxfr.log.old
# cat /dev/null > /var/yp/ypxfr.log
You can have crontab execute these commands once a week. To turn off logging, remove the log file.
Modifying Default Maps
To update a nondefault map, you must do the following.
  1. Create or edit its corresponding text file.
  2. Build (or rebuild) the new or updated map. There are two ways to build a map.
    • Use the Makefile. Using the Makefile is the preferred method of building a non-default map. If the map has an entry in the Makefile, run make name where name is the name of map you want to build. If the map does not have a Makefile entry, try to create one following the instructions in Modifying and Using the Makefile.
    • Use the /usr/sbin/makedbm program. makedbm(1M) fully describes this command.
Using makedbm to Modify a Non-Default Map
There are two different methods for using makedbm to modify maps if you do not have an input file:
Creating New Maps from Text Files
Assume that a text file /var/yp/mymap.asc was created with an editor or a shell script on the master. You want to create an NIS map from this file and locate it in the homedomain subdirectory. To do this, type the following on the master server.
# cd /var/yp
# makedbm mymap.asc homedomain/mymap
The mymap map now exists on the master server in the directory homedomain. To distribute the new map to slave servers run ypxfr.
Adding Entries to a File-Based Map
Adding entries to mymap is simple. First, you must modify the text file /var/yp/mymap.asc. If you modify the actual dbm files without modifying the corresponding text file, the modifications are lost. Then run makedbm as shown above.
Creating Maps From Standard Input
When no original text file exists, create the NIS map from the keyboard by typing input to makedbm, as shown below (end with Control-D).
ypmaster# cd /var/yp
ypmaster# makedbm -homedomain-/mymapkey1 value1 key2 value2 key3 value3
Modifying Maps Made From Standard Input
If you later need to modify the map, you can use makedbm to disassemble the map and create a temporary text intermediate file. To disassemble the map and create a temporary file, type the following.
% cd /var/yp
% makedbm -u homedomain/mymap > mymap.temp
The resulting temporary file mymap.temp has one entry per line. You can edit this file as needed, using any text editor.
To update the map, give the name of the modified temporary file to makedbm by typing the following.
% makedbm mymap.temp homedomain/mymap
% rm mymap.temp
Then propagate the map to the slave servers, by becoming root and typing the following.
# yppush mymap
The preceding paragraphs explained how to use makedbm to create maps; however, almost everything you actually have to do can be done by ypinit and Makefile unless you add nondefault maps to the database or change the set of NIS servers after the system is already up and running.
Whether you use the Makefile in /var/yp or some other procedure the goal is the same. Anew pair of well-formed dbm files must end up in the maps directory on the master server.
Adding a Slave Server
After NIS is running, you might need to create an NIS slave server that you did not include in the initial list given to ypinit.
To add an NIS slave server:
ProcedureHow to Add a Slave Server
  1. On the master server, become superuser or assume an equivalent role.
  2. Change to the NIS domain directory.
    # cd /var/yp/domainname
  3. Disassemble the ypservers file.
    # makedbm -u ypservers >/tmp/temp_file
    The makedbm command converts ypservers from ndbm format to a temporary ASCII file /tmp/temp_file.
  4. Edit the /tmp/temp_file file using a text editor. Add the name of the new slave server to the list of servers. Then save and close the file.
  5. Run the makedbm command with temp_file as the input file and ypservers as the output file.
    # makedbm /tmp/temp_file ypservers
    makedbm then converts ypservers back into ndbm format.
  6. Verify that the ypservers map is correct (since there is no ASCII file for ypservers) by typing the following on the slave.
    slave3# makedbm -u ypservers
    The makedbm command displays each entry in ypservers on your screen.
    Note –
    If a machine name is not in ypservers, it will not receive updates to the map files because yppush consults this map for the list of slave servers.
  7. On the new NIS slave, become superuser or assume an equivalent role.
  8. Set up the new slave server's NIS domain directory.
    Copy the NIS map set from the master server, then start the NIS client. When running the ypinit command, follow the prompts and list the NIS servers in order of preference.
    slave3# cd /var/yp
    slave3# ypinit -c
    slave3# svcadm enable network/nis/client
  9. Initialize this machine as a slave.
    slave3# /usr/sbin/ypinit -s ypmaster
    where ypmaster is the machine name of the existing NIS master server.
  10. Stop the machine running as an NIS client.
    # svcadm disable network/nis/client
  11. Start NIS slave service.
Using NIS With C2 Security
If the $PWDIR/security/passwd.adjunct file is present, C2 security is started automatically. ($PWDIR is defined in /var/yp/Makefile.) The C2 security mode uses the passwd.adjunct file to create the passwd.adjunct NIS map. In this implementation, NIS allows you to use both the passwd.adjunct file and shadow file to manage security. The passwd.adjunct file is processed only when you type the following.
# make passwd.adjunct
The make passwd command processes the passwd map only, not the passwd.adjunct map when you run make manually in the C2 security mode.
Binding to a Specific NIS Server
Use the following steps to bind to an NIS server that you specify. For more information, see the ypinit(1M), ypstart(1M), and svcadm(1M) man pages.
  1. Add the hostname of the NIS server and its IP address to the /etc/hosts file.
  2. Run the domainname command to populate the /etc/defaultdomain file.
    # /usr/bin/domainname name-of-NIS-domain
  3. Prompt for the NIS server host name.
    # /usr/sbin/ypinit -c
    Server name: Type the NIS server hostname
  4. Restart the NIS services by performing one of the following steps.
    • For the services to persist across reboots, run the svcadm command:
      # svcadm enable -r svc:/network/nis/client
    • For the services to persist until reboot only, run the ypstop and ypstart commands:
      # /usr/lib/netsvc/yp/ypstop
      # /usr/lib/netsvc/yp/ypstart
Changing a Machine's NIS Domain
To change the NIS domain name of a machine, do the following.
ProcedureHow to Change a Machine's NIS Domain Name
  2. Edit the machine's /etc/defaultdomain file, exchanging its present contents with the new domain name for the machine.
    For example, if the current domain name is, you might change it to
  3. Run domainname `cat /etc/defaultdomain'
  4. Re-initialize the machine as an NIS client, slave, or master server.
    For the details, see Chapter 5, Setting Up and Configuring NIS Service.
Using NIS in Conjunction With DNS
Typically, NIS clients are configured with the nsswitch.conf file to use only NIS for machine name and address lookups. If this type of lookup fails, an NIS server can forward these lookups to DNS.
ProcedureHow to Configure Machine Name and Address Lookup Through NIS and DNS
  2. The two map files, hosts.byname and hosts.byaddr must include the YP_INTERDOMAIN key. To test this key, edit the Makefile and modify the following lines.
    makedbm will now start with the -b flag when it makes the maps, and the YP_INTERDOMAIN key will be inserted into the ndbm files.
  3. Run the make command to rebuild maps.
    # /usr/ccs/bin/make hosts
  4. Check that all the NIS server's /etc/resolv.conf files point to valid nameservers.
    Note –
    If you have NIS servers that are not running Solaris, Release 2, make sure YP_INTERDOMAIN exists in the hosts maps.
  5. To enable DNS forwarding, restart each server.
    # svcadm restart network/nis/server:<instance>
    In this implementation of NIS, ypserv automatically starts with the -d option to forward requests to DNS.
Dealing with Mixed NIS Domains
If the master and slave servers are not both running Solaris 2, refer to the following table for how to avoid potential problems. The notation “4.0.3+” refers to that and later releases of the Solaris OS. makedm -b is a reference to the “B” variable in the Makefile.
Table 6–1 NIS/DNS in Heterogeneous NIS Domains
Solaris NIS
Master: makedbm -b
Slave: ypxfr
Master: makedbm -b
Slave: ypxfr -b
Master: ypserv -d
Slave: ypxfr -b
Solaris NIS
Master: makedbm -b
Slave: ypxfr
Master: makedbm -b
Slave: ypxfr
Master: ypserv -d
Slave:ypxfr with resolv.conf or ypxfr -b
Turning Off NIS Services
If ypserv on the NIS master is disabled, you can no longer update any of the NIS maps.
