The following sections show various commands to help determine the state of the LDAP client environment. Also see the man pages for additional information about the options that can be used.
For an overview of the Service Management Facility, refer to Chapter 18, Managing Services (Overview), in System Administration Guide: Basic Administration. Also refer to the svcadm(1M) and svcs(1) man pages for more details.
The ldap_cachemgr daemon must be running and functioning correctly at all times. Otherwise, the system doesn't work. When you start the LDAP client, the client starts ldap_cachemgr daemon automatically. So, if the ldap_cachemgr is not running, the LDAP client will be disabled. Following are two methods for determining if the LDAP client is online.
Use the svcs command.
# svcs \*ldap\* STATE STIME FMRI disabled Aug_24 svc:/network/ldap/client:default |
or
# svcs -l network/ldap/client:default fmri svc:/network/ldap/client:default enabled true state online next_state none restarter svc:/system/svc/restarter:default contract_id 1598 dependency require_all/none file://localhost/var/ldap/ldap_client_file (-) dependency require_all/none svc:/network/initial (online) dependency require_all/none svc:/system/filesystem/minimal (online) |
Pass the -g option to ldap_cachemgr.
This option provides more extensive status information, which is useful when you diagnose a problem.
# /usr/lib/ldap/ldap_cachemgr -g cachemgr configuration: server debug level 0 server log file "/var/ldap/cachemgr.log" number of calls to ldapcachemgr 19 cachemgr cache data statistics: Configuration refresh information: Previous refresh time: 2001/11/16 18:33:28 Next refresh time: 2001/11/16 18:43:28 Server information: Previous refresh time: 2001/11/16 18:33:28 Next refresh time: 2001/11/16 18:36:08 server: 192.168.0.0, status: UP server: 192.168.0.1, status: ERROR error message: Can't connect to the LDAP server Cache data information: Maximum cache entries: 256 Number of cache entries: 2 |
For more information about the ldap_cachemgr daemon, see the ldap_cachemgr(1M) man page.
Become superuser or assume an equivalent role, and run ldapclient with the list option.
# ldapclient list NS_LDAP_FILE_VERSION= 2.0 NS_LDAP_BINDDN= cn=proxyagent,ou=profile,dc=west,dc=example,dc=com NS_LDAP_BINDPASSWD= {NS1}4a3788e8c053424f NS_LDAP_SERVERS= 192.168.0.1, 192.168.0.10 NS_LDAP_SEARCH_BASEDN= dc=west,dc=example,dc=com NS_LDAP_AUTH= simple NS_LDAP_SEARCH_REF= TRUE NS_LDAP_SEARCH_SCOPE= one NS_LDAP_SEARCH_TIME= 30 NS_LDAP_SERVER_PREF= 192.168.0.1 NS_LDAP_PROFILE= pit1 NS_LDAP_CREDENTIAL_LEVEL= proxy NS_LDAP_SERVICE_SEARCH_DESC= passwd:ou=people,?sub NS_LDAP_SERVICE_SEARCH_DESC= group:ou=group,dc=west,dc=example,dc=com?one NS_LDAP_BIND_TIME= 5 |
Currently the /var/ldap files are in ASCII format. Because the files could change to binary at some time, concatenating the files would cause problems. ldapclient list is the supported method for accessing this information. See the ldapclient(1M) man page for more information.
The best way to show that your client is talking to the LDAP server is with the ldaplist command. Using ldaplist with no arguments dumps all the containers on the server. This works as long as the containers exist, and do not have to be populated. See the ldaplist(1) man page for more information.
If the first step works, you can try ldaplist passwd username or ldaplist hosts hostname but if they contain lots of data you might want to pick a less populated service, or pipe them to head or more.
Most of the commands in the previous sections assume you already have created an LDAP client. If you have not created a client and want to check the data on the server, use the ldapsearch command. The following example lists all of the containers.
# ldapsearch -h server1 -b "dc=west,dc=example,dc=com" -s one "objectclass=*" |
In Solaris 9 and earlier releases, the ldapsearch command, by default, produced output in a nonstandard textual representation. The default output for ldapsearch in later Solaris releases is the industry standardized LDIF format that is defined by RFC-2849. All versions of ldapsearch can output LDIF format using the -L option.
