System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
LDAP Configuration Problems and Solutions
The following sections describe LDAP configuration problems and suggests solutions to the problems.
Unresolved Hostname
The Solaris platform LDAP client back end returns fully qualified host names for host lookups, such as host names returned by gethostbyname() and getaddrinfo(). If the name stored is qualified, that is, contains at least one dot, the client returns the name as is. For example, if the name stored is hostB.eng, the returned name is hostB.eng.
If the name stored in the LDAP directory is not qualified (it does not contain a dot), the client back end appends the domain part to the name. For example, if the name stored is hostA, the returned name is hostA.domainname.
Unable to Reach Systems in the LDAP Domain Remotely
If the DNS domain name is different from the LDAP domain name, then the LDAP naming service cannot be used to serve host names unless the host names are stored fully qualified.
Login Does Not Work
LDAP clients use the PAM modules for user authentication during login. When using the standard UNIX PAM module, the password is read from the server and checked on the client side. This can fail due to one of the following reasons:
  1. ldap is not used by the passwd service in the /etc/nsswitch.conf file.
  2. The user's userPassword attribute on the server list is not readable by the proxy agent. You need to allow at least the proxy agent to read the password because the proxy agent returns it to the client for comparison. pam_ldap does not require read access to the password.
  3. The proxy agent might not have the correct password.
  4. The entry does not have the shadowAccount object class.
  5. No password is defined for the user.
    When you use ldapaddent, you must use the -p option to ensure that the password is added to the user entry. If you use ldapaddent without the -p option, the user's password is not stored in the directory unless you also add the /etc/shadow file by using ldapaddent.
  6. No LDAP servers are reachable.
    Check the status of the servers.
    # /usr/lib/ldap/ldap_cachemgr -g
  7. pam.conf is configured incorrectly.
  8. The user is not defined in the LDAP namespace.
  9. NS_LDAP_CREDENTIAL_LEVEL is set to anonymous for pam_unix, and userPassword is not available to anonymous users.
  10. The password is not stored in crypt format.
  11. If pam_ldap is configured to support account management, login failure could be the result of one of the following:
    • The user's password has expired.
    • The user's account is locked out due to too many failed login attempts.
    • The user's account has been deactivated by the administrator.
    • The user tried to log in using a nonpassword-based program, such as rsh, rlogin, ssh, or sftp.
  12. If per-user authentication and sasl/GSSAPI are being used, then some component of Kerberos or the pam_krb5 configuration is setup incorrectly. Refer to the System Administration Guide: Security Services for details on resolving these issues.
Lookup Too Slow
The LDAP database relies on indexes to improve search performance. A major performance degradation occurs when indexes are improperly configured. The documentation includes a common set of attributes that should be indexed. You can also add your own indexes to improve performance at your site.
ldapclient Cannot Bind to Server
ldapclient failed to initialize the client when using the init option with the profileName attribute specified. Possible reasons for failure include the following:
  1. The incorrect domain name was specified on the command line.
  2. The nisDomain attribute is not set in the DIT to represent the entry point for the specified client domain.
  3. Access control information is not set up properly on the server, thus disallowing anonymous search in the LDAP database.
  4. An incorrect server address passed to the ldapclient command. Use ldapsearch to verify the server address.
  5. An incorrect profile name passed to the ldapclient command. Use ldapsearch to verify the profile name in the DIT.
  6. Use snoop on the client's network interface to see what sort of traffic is going out, and determine to which server it is talking.
Using ldap_cachemgr for Debugging
Using ldap_cachemgr with the -g option can be a useful way to debug, as you can view the current client configuration and statistics. For example,
# ldap_cachemgr -g
would print current configuration and statistics to standard output, including the status of all LDAP servers, as mentioned previously. Note that you do not need to become super user to execute this command.
ldapclient Hangs During Setup
If the ldapclient command hangs, pressing Ctrl-C will exit after restoring the previous environment. If this happens, check with the server administrator to ensure that the server is running.
Also check the server list attributes in either the profile or from the command line and make sure that the server information is correct.
