System Administration Guide: Security Services
path Token
The path token contains access path information for an object.
The path token contains the following fields:
The praudit command displays the path token, without the second field, as follows:
The praudit -x command shows the content of the path token:
The following figure shows the format of a path token.
Figure 31–4 path Token Format
The preceding context describes the graphic.
