System Administration Guide: Security Services
BART Manifest, Rules File, and Reporting (Reference)
This section includes the following reference information:
BART Manifest File Format
Each manifest file entry is a single line, depending on the file type. Each entry begins with fname, which is the name of the file. To prevent parsing problems that are caused by special characters embedded in file names, the file names are encoded. For more information, see BART Rules File Format.
Subsequent fields represent the following file attributes:
type
Type of file with the following possible values:
  • B for a block device node
  • C for a character device node
  • D for a directory
  • F for a file
  • L for a symbolic link
  • P for a pipe
  • S for a socket
size
File size in bytes.
mode
Octal number that represents the permissions of the file.
acl
ACL attributes for the file. For a file with ACL attributes, this contains the output from acltotext().
uid
Numerical user ID of the owner of this entry.
gid
Numerical group ID of the owner of this entry.
dirmtime
Last modification time, in seconds, since 00:00:00 UTC, January 1, 1970, for directories.
lnmtime
Last modification time, in seconds, since 00:00:00 UTC, January 1, 1970, for links.
mtime
Last modification time, in seconds, since 00:00:00 UTC January 1, 1970, for files.
contents
Checksum value of the file. This attribute is only specified for regular files. If you turn off context checking, or if checksums cannot be computed, the value of this field is .
dest
Destination of a symbolic link.
devnode
Value of the device node. This attribute is for character device files and block device files only.
For more information about BART manifests, see the bart_manifest(4) man page.
The input files to the bart command are text files. These files consist of lines that specify which files are to be included in the manifest and which file attributes are to be included the report. The same input file can be used across both pieces of BART functionality. Lines that begin with #, blank lines, and lines that contain white space are ignored by the tool.
The input files have three types of directives:
Example 5–8 Rules File Format
<Global CHECK/IGNORE Directives>
<subtree1> [pattern1..]
<IGNORE/CHECK Directives for subtree1>
<subtree2> [pattern2..]
<subtree3> [pattern3..]
<subtree4> [pattern4..]
<IGNORE/CHECK Directives for subtree2, subtree3, subtree4>
Note –
All directives are read in order, with later directives possibly overriding earlier directives.
There is one subtree directive per line. The directive must begin with an absolute pathname, followed by zero or more pattern matching statements.
Rules File Attributes
The bart command uses CHECK and IGNORE statements to define which attributes to track or ignore. Each attribute has an associated keyword.
The attribute keywords are as follows:
The all keyword refers to all file attributes.
Quoting Syntax
The rules file specification language that BART uses is the standard UNIX quoting syntax for representing nonstandard file names. Embedded tab, space, newline, or special characters are encoded in their octal forms to enable the tool to read file names. This nonuniform quoting syntax prevents certain file names, such as those containing an embedded carriage return, from being processed correctly in a command pipeline. The rules specification language allows the expression of complex file name filtering criteria that would be difficult and inefficient to describe by using shell syntax alone.
For more information about the BART rules file or the quoting syntax used by BART, see the bart_rules(4) man page.
BART Reporting
In default mode, the bart compare command, as shown in the following example, will check all the files installed on the system, with the exception of modified directory timestamps (dirmtime):
CHECK all
IGNORE	dirmtime
If you supply a rules file, then the global directives of CHECK all and IGNORE dirmtime, in that order, are automatically prepended to the rules file.
BART Output
The following exit values are returned:
0
Success
1
Nonfatal error when processing files, such as permission problems
>1
Fatal error, such as an invalid command-line option
The reporting mechanism provides two types of output: verbose and programmatic:
For a list of attributes that are supported by the bart command, see Rules File Attributes.
For more information about BART, see the bart(1M) man page.
