You can run the bart command as a regular user, superuser, or a user who has assumed the Primary Administrator role. If you run the bart command as a regular user, you will only be able to catalog and monitor files that you have permission to access, for example, information about files in your home directory. The advantage of becoming superuser when you run the bart command is that the manifests you create will contain information about hidden and private files that you might want to monitor. If you need to catalog and monitor information about files that have restricted permissions, for example, the /etc/passwd or /etc/shadow file, run the bart command as superuser or assume an equivalent role. For more information about using role-based access control, see Configuring RBAC (Task Map).
Running the bart command as superuser makes the output readable by anyone. This output might contain file names that are intended to be private. If you become superuser when you run the bart command, take appropriate measures to protect the output. For example, use options that generate output files with restrictive permissions.
The procedures and examples in this chapter show the bart command run by superuser. Unless otherwise specified, running the bart command as superuser is optional.
You can create a manifest of a system immediately after an initial Solaris software installation. This type of manifest will provide you with a baseline for comparing changes to the same system over time. Or, you can use this manifest to compare with the manifests for different systems. For example, if you take a snapshot of each system on your network, and then compare each test manifest with the control manifest, you can quickly determine what you need to do to synchronize the test system with the baseline configuration.
Assume the Primary Administrator role, or become superuser.
The Primary Administrator role includes the Primary Administrator profile. To create the role and assign the role to a user, see Chapter 2, Working With the Solaris Management Console (Tasks), in System Administration Guide: Basic Administration.
After installing the Solaris software, create a control manifest and redirect the output to a file.
# bart create options > control-manifest |
Specifies the root directory for the manifest. All paths specified by the rules will be interpreted relative to this directory. All paths reported in the manifest will be relative to this directory.
Accepts a list of individual files to be cataloged, either on the command line or read from standard input.
Is the name of the rules file for this manifest. Note that –, when used with the -r option, will be read the rules file from standard input.
Turns off content signatures for all regular files in the file list. This option can be used to improve performance. Or, you can use this option if the contents of the file list are expected to change, as in the case of system log files.
Examine the contents of the manifest.
Save the manifest for future use.
Choose a meaningful name for the manifest. For example, use the system name and date that the manifest was created.
If you run the bart create command without any options, information about every file that is installed on the system will be cataloged. Use this type of manifest as a baseline when you are installing many systems from a central image. Or, use this type of manifest to run comparisons when you want to ensure that the installations are identical.
For example:
# bart create ! Version 1.0 ! Thursday, December 04, 2003 (16:17:39) # Format: #fname D size mode acl dirmtime uid gid #fname P size mode acl mtime uid gid #fname S size mode acl mtime uid gid #fname F size mode acl mtime uid gid contents #fname L size mode acl lnmtime uid gid dest #fname B size mode acl mtime uid gid devnode #fname C size mode acl mtime uid gid devnode / D 1024 40755 user::rwx,group::r-x,mask:r-x,other:r-x 3fd9ea47 0 0 /.java D 512 40755 user::rwx,group::r-x,mask:r-x,other:r-x 3f8dc04d 0 10 /.java/.userPrefs D 512 40700 user::rwx,group::---,mask:--- other:--- 3f8dc06b 010 /.java/.userPrefs/.user.lock.root F 0 100600 user::rw- group::---,mask:---,other:--- 3f8dc06b 0 10 - /.java/.userPrefs/.userRootModFile.root F 0 100600 user::rw-, group::---,mask:---,other:--- 3f8dc0a1 0 10 - . . . /var/sadm/pkg/SUNWdtmad/install/depend F 932 100644 user::rw-, group::r--,mask:r--,other:r-- 3c23a19e 0 0 - /var/sadm/pkg/SUNWdtmad/pkginfo F 594 100644 user::rw- group::r--,mask:r--,other:r-- 3f81e416 0 0 - /var/sadm/pkg/SUNWdtmad/save D 512 40755 user::rwx,group::r-x mask:r-x,other:r-x 3f81e416 0 0 /var/sadm/pkg/SUNWdtmaz D 512 40755 user::rwx,group::r-x mask:r-x,other:r-x 3f81e41b 0 0 /var/sadm/pkg/TSIpgxw/save D 512 40755 user::rwx group::r-x,mask:r-x,other:r-x 3f81e892 0 0 . . . |
Each manifest consists of a header and entries. Each manifest file entry is a single line, depending on the file type. For example, for each manifest entry in the preceding output, type F specifies a file and type D specifies a directory. Also listed is information about size, content, user ID, group ID, and permissions. File entries in the output are sorted by the encoded versions of the file names to correctly handle special characters. All entries are sorted in ascending order by file name. All nonstandard file names, such as those that contain embedded newline or tab characters, have the nonstandard characters quoted before being sorted.
Lines that begin with ! supply metadata about the manifest. The manifest version line indicates the manifest specification version. The date line shows the date on which the manifest was created, in date form. See the date(1) man page. Some lines are ignored by the manifest comparison tool. Ignored lines include blank lines, lines that consist only of white space, and comments that begin with #.
You can customize a manifest in one of the following ways:
By specifying a subtree
Creating a manifest for an individual subtree on a system is an efficient way to monitor changes to specific files, rather than the entire contents of a large directory. You can create a baseline manifest of a specific subtree on your system, then periodically create test manifests of the same subtree. Use the bart compare command to compare the control manifest with the test manifest. By using this option, you are able to efficiently monitor important file systems to determine whether any files have been compromised by an intruder.
By specifying a file name
Since creating a manifest that catalogs the entire system is more time-consuming, takes up more space, and is more costly, you might choose to use this option of the bart command when you want to only list information about a specific file or files on a system.
By using a rules file
You use a rules file to create custom manifests that list information about specific files and specific subtrees on a given system. You can also use a rules file to monitor specific file attributes. Using a rules file to create and compare manifests gives you the flexibility to specify multiple attributes for more than one file or subtree. Whereas, from the command line, you can only specify a global attribute definition that applies to all files for each manifest you create or report you generate.
Determine which files you want to catalog and monitor.
After installing the Solaris software, create a custom manifest by using one of the following options:
By specifying a subtree:
# bart create -R root-directory |
By specifying a file name or file names:
# bart create -I filename... |
For example:
# bart create -I /etc/system /etc/passwd /etc/shadow |
By using a rules file:
# bart create -r rules-file |
This example shows how to create a manifest that contains information about the files in the /etc/ssh subtree only.
# bart create -R /etc/ssh ! Version 1.0 ! Saturday, November 29, 2003 (14:05:36) # Format: #fname D size mode acl dirmtime uid gid #fname P size mode acl mtime uid gid #fname S size mode acl mtime uid gid #fname F size mode acl mtime uid gid contents #fname L size mode acl lnmtime uid gid dest #fname B size mode acl mtime uid gid devnode #fname C size mode acl mtime uid gid devnode / D 512 40755 user::rwx,group::r-x,mask:r-x,other:r-x 3f81eab9 0 3 /ssh_config F 861 100644 user::rw-,group::r--,mask:r--, other:r-- 3f81e504 0 3 422453ca0e2348cd9981820935600395 /ssh_host_dsa_key F 668 100600 user::rw-,group::---,mask:---, other:--- 3f81eab9 0 0 5cc28cdc97e833069fd41ef89e4d9834 /ssh_host_dsa_key.pub F 602 100644 user::rw-,group::r--,mask:r--, other:r-- 3f81eab9 0 0 16118c736995a4e4754f5ab4f28cf917 /ssh_host_rsa_key F 883 100600 user::rw-,group::---,mask:---, other:--- 3f81eaa2 0 0 6ff17aa968ecb20321c448c89a8840a9 /ssh_host_rsa_key.pub F 222 100644 user::rw-,group::r--,mask:r--, other:r-- 3f81eaa2 0 0 9ea27617efc76058cb97aa2caa6dd65a . . . |
This example shows how to create a manifest that lists only information about the /etc/passwd and /etc/shadow files on a system.
# bart create -I /etc/passwd /etc/shadow ! Version 1.0 ! Monday, December 15, 2003 (16:28:55) # Format: #fname D size mode acl dirmtime uid gid #fname P size mode acl mtime uid gid #fname S size mode acl mtime uid gid #fname F size mode acl mtime uid gid contents #fname L size mode acl lnmtime uid gid dest #fname B size mode acl mtime uid gid devnode #fname C size mode acl mtime uid gid devnode /etc/passwd F 542 100444 user::r--,group::r--,mask:r--, other:r-- 3fcfd45b 0 3 d6 84554f85d1de06219d80543174ad1a /etc/shadow F 294 100400 user::r--,group::---,mask:---, other:--- 3f8dc5a0 0 3 fd c3931c1ae5ee40341f3567b7cf15e2 |
By comparison, the following is the standard output of the ls -al command for the /etc/passwd and the /etc/shadow files on the same system.
# ls -al /etc/passwd -r--r--r-- 1 root sys 542 Dec 4 17:42 /etc/passwd |
# ls -al /etc/shadow -r-------- 1 root sys 294 Oct 15 16:09 /etc/shadow |
This example shows how to create a manifest by using a rules file to catalog only those files in the /etc directory. The same rules file includes directives to be used by the bart compare command for monitoring changes to the acl attribute of the /etc/system file.
Use a text editor to create a rules file that catalogs only those files in the /etc directory.
# List information about all the files in the /etc directory. CHECK all /etc # Check only acl changes in the /etc/system file IGNORE all CHECK acl /etc/system |
For more information about creating a rules file, see BART Rules File.
Create a control manifest by using the rules file you created.
# bart create -r etc.rules-file > etc.system.control-manifest ! Version 1.0 ! Thursday, December 11, 2003 (21:51:32) # Format: #fname D size mode acl dirmtime uid gid #fname P size mode acl mtime uid gid #fname S size mode acl mtime uid gid #fname F size mode acl mtime uid gid contents #fname L size mode acl lnmtime uid gid dest #fname B size mode acl mtime uid gid devnode #fname C size mode acl mtime uid gid devnode /etc/system F 1883 100644 user::rw-,group::r--,mask:r--, other:r-- 3f81db61 0 3 |
Create a test manifest whenever you want to monitor changes to the system. Prepare the test manifest identically to the control manifest by using the same bart options and the same rules file.
Compare manifests by using the same rules file.
Use this procedure when you want to monitor file-level changes to the same system over time. This type of manifest can assist you in locating corrupted or unusual files, detecting security breaches, or in troubleshooting performance issues on a system.
After installing the Solaris software, create a control manifest of the files that you want to monitor on the system.
# bart create -R /etc > control-manifest |
Create a test manifest that is prepared identically to the control manifest whenever you want monitor changes to the system.
# bart create -R /etc > test-manifest |
Compare the control manifest with the test manifest.
# bart compare options control-manifest test-manifest > bart-report |
Is the name of the rules file for this comparison. Using the -r option with the – means that the directives will be read from standard input.
Allows the user to set global IGNORE directives from the command line.
Is the programmatic mode that generates standard non-localized output for programmatic parsing.
Is the output from the bart create command for the control system.
Is the output from the bart create command of the test system.
Examine the BART report for oddities.
This example shows how to monitor changes that have occurred in the /etc directory between two points in time. This type of comparison enables you to quickly determine whether important files on the system have been compromised.
Create a control manifest.
# bart create -R /etc > system1.control.121203 ! Version 1.0 ! Friday, December 12, 2003 (08:34:51) # Format: #fname D size mode acl dirmtime uid gid #fname P size mode acl mtime uid gid #fname S size mode acl mtime uid gid #fname F size mode acl mtime uid gid contents #fname L size mode acl lnmtime uid gid dest #fname B size mode acl mtime uid gid devnode #fname C size mode acl mtime uid gid devnode / D 4096 40755 user::rwx,group::r-x,mask:r-x,other:r-x 3fd9dfb4 0 3 /.cpr_config F 2236 100644 user::rw-,group::r--,mask:r--,other:r-- 3fd9991f 0 0 67cfa2c830b4ce3e112f38c5e33c56a2 /.group.lock F 0 100600 user::rw-,group::---,mask:---,other:--- 3f81f14d 0 1 d41 d8cd98f00b204e9800998ecf8427e /.java D 512 40755 user::rwx,group::r-x,mask:r-x,other:r-x 3f81dcb5 0 2 /.java/.systemPrefs D 512 40755 user::rwx,group::r-x,mask:r-x, other:r-x 3f81dcb7 . . . |
Create a test manifest when you want to monitor changes to the /etc directory.
# bart create -R /etc > system1.test.121503 Version 1.0 ! Monday, December 15, 2003 (08:35:28) # Format: #fname D size mode acl dirmtime uid gid #fname P size mode acl mtime uid gid #fname S size mode acl mtime uid gid #fname F size mode acl mtime uid gid contents #fname L size mode acl lnmtime uid gid dest #fname B size mode acl mtime uid gid devnode #fname C size mode acl mtime uid gid devnode / D 4096 40755 user::rwx,group::r-x,mask:r-x,other:r-x 3fd9dfb4 0 3 /.cpr_config F 2236 100644 user::rw-,group::r--,mask:r--,other:r-- 3fd9991f 0 0 67cfa2c830b4ce3e112f38c5e33c56a2 /.group.lock F 0 100600 user::rw-,group::---,mask:---,other:--- 3f81f14d 0 1 d41d8cd98f00b204e9800998ecf8427e /.java D 512 40755 user::rwx,group::r-x,mask:r-x,other:r-x 3f81dcb5 0 2 /.java/.systemPrefs D 512 40755 user::rwx,group::r-x,mask:r-x, other:r-x 3f81dcb70 2 /.java/.systemPrefs/.system.lock F 0 100644 user::rw-,group::r-- ,mask:r--,other: r-- 3f81dcb5 0 2 d41d8cd98f00b204e9800998ecf8427e /.java/.systemPrefs/.systemRootModFile F 0 100644 user::rw-, group::r--,mask:r--, other:r-- 3f81dd0b 0 2 d41d8cd98f00b204e9800998ecf8427e . . . |
# bart compare system1.control.121203 system1.test.121503 /vfstab: mode control:100644 test:100777 acl control:user::rw-,group::r--,mask:r--,other:r-- test:user::rwx, group::rwx,mask:rwx,other:rwx |
The preceding output indicates permissions on the vfstab file have changed since the control manifest was created. This report can be used to investigate whether ownership, date, content, or any other file attributes have changed. Having this type of information readily available can assist you in tracking down who might have tampered with the file and when the change might have occurred.
You can run system to system comparisons, thereby enabling you to quickly determine whether there are any file-level differences between a baseline system and the other systems. For example, if you have installed a particular version of the Solaris software on a baseline system, and you want to know whether other systems have identical packages installed, you can create manifests for those systems and then compare the test manifests with the control manifest. This type of comparison will list any discrepancies in the file contents for each test system that you compare with the control system.
After installing the Solaris software, create a control manifest.
Save the control manifest.
On the test system, use the same bart options to create a manifest, and redirect the output to a file.
# bart create options > test1-manifest |
Choose a distinct and meaningful name for the test manifest.
Save the test manifest to a central location on the system until you are ready to compare manifests.
When you want to compare manifests, copy the control manifest to the location of the test manifest. Or, copy the test manifest to the control system.
For example:
# cp control-manifest /net/test-server/bart/manifests
If the test system is not an NFS-mounted system, use FTP or some other reliable means to copy the control manifest to the test system.
Compare the control manifest with the test manifest and redirect the output to a file.
# bart compare control-manifest test1-manifest > test1.report |
Repeat Step 4 through Step 9 for each test manifest that you want to compare with the control manifest.
Use the same bart options for each test system.
This example describes how to monitor changes to the contents of the /usr/bin directory by comparing a control manifest with a test manifest from a different system.
# bart create -R /usr/bin > control-manifest.121203 !Version 1.0 ! Friday, December 12, 2003 (09:19:00) # Format: #fname D size mode acl dirmtime uid gid #fname P size mode acl mtime uid gid #fname S size mode acl mtime uid gid #fname F size mode acl mtime uid gid contents #fname L size mode acl lnmtime uid gid dest #fname B size mode acl mtime uid gid devnode #fname C size mode acl mtime uid gid devnode / D 13312 40755 user::rwx,group::r-x,mask:r-x,other:r-x 3fd9e925 0 2 /.s F 14200 104711 user::rwx,group::--x,mask:--x,other:--x 3f8dbfd6 0 1 8ec7e52d8a35ba3b054a6394cbf71cf6 /ControlPanel L 28 120777 - 3f81dc71 0 1 jre/bin/ControlPanel /HtmlConverter L 25 120777 - 3f81dcdc 0 1 bin/HtmlConverter /acctcom F 28300 100555 user::r-x,group::r-x,mask:r-x,other:r-x 3f6b5750 0 2 d6e99b19c847ab4ec084d9088c7c7608 /activation-client F 9172 100755 user::rwx,group::r-x,mask:r-x, other:r-x 3f5cb907 0 1 b3836ad1a656324a6e1bd01edcba28f0 /adb F 9712 100555 user::r-x,group::r-x,mask:r-x,other:r-x 3f6b5736 0 2 5e026413175f65fb239ee628a8870eda /addbib F 11080 100555 user::r-x,group::r-x,mask:r-x,other:r-x 3f6b5803 0 2 a350836c36049febf185f78350f27510 . . . |
Create a test manifest for each system that you want to compare with the control system.
# bart create -R /usr/bin > system2-manifest.121503 ! Version 1.0 ! Friday, December 15, 2003 (13:30:58) # Format: #fname D size mode acl dirmtime uid gid #fname P size mode acl mtime uid gid #fname S size mode acl mtime uid gid #fname F size mode acl mtime uid gid contents #fname L size mode acl lnmtime uid gid dest #fname B size mode acl mtime uid gid devnode #fname C size mode acl mtime uid gid devnode / D 13312 40755 user::rwx,group::r-x,mask:r-x,other:r-x 3fd9ea9c 0 2 /.s F 14200 104711 user::rwx,group::--x,mask:--x,other:--x 3f8dbfd6 0 1 8ec7e52d8a35ba3b054a6394cbf71cf6 /ControlPanel L 28 120777 - 3f81dc71 0 1 jre/bin/ControlPanel /HtmlConverter L 25 120777 - 3f81dcdc 0 1 bin/HtmlConverter /acctcom F 28300 100555 user::r-x,group::r-x,mask:r-x,other: r-x 3f6b5750 0 2 d6e99b19c847ab4ec084d9088c7c7608 . . . |
When you want to compare manifests, copy the manifests to the same location.
# cp control-manifest /net/system2.central/bart/manifests |
# bart compare control-manifest system2.test > system2.report /su: gid control:3 test:1 /ypcat: mtime control:3fd72511 test:3fd9eb23 |
The previous output indicates that the group ID of the su file in the /usr/bin directory is not the same as that of the control system. This information can be helpful in determining whether a different version of the software was installed on the test system or if possibly someone has tampered with the file.
This procedure is optional and explains how to customize a BART report by specifying file attributes from the command line. If you create a baseline manifest that lists information about all the files or specific on your system, you can run the bart compare command, specifying different attributes, whenever you need to monitor changes to a particular directory, subdirectory, file or files. You can run different types of comparisons for the same manifests by specifying different file attributes from the command line.
Determine which file attributes you want to monitor.
Create a test manifest when you want to monitor changes.
Prepare the test manifest identically to the control manifest.
Compare the manifests.
For example:
# bart compare -i dirmtime,lnmtime,mtime control-manifest.121503 \ test-manifest.010504 > bart.report.010504 |
Note that a comma separates each attribute you specify in the command-line syntax.
This procedure is also optional and explains how to customize a BART report by using a rules file as input to the bart compare command. By using a rules file, you can customize a BART report, which allows you the flexibility of specifying multiple attributes for more than one file or subtree. You can run different comparisons for the same manifests by using different rules files.
Determine which files and file attributes you want to monitor.
Use a text editor to create a rules file with the appropriate directives.
After installing the Solaris software, create a control manifest by using the rules file you created.
# bart create -r rules-file > control-manifest |
Create a test manifest that is prepared identically to the control manifest.
# bart create -r rules-file > test-manifest |
Compare the control manifest with the test manifest by using the same rules file.
# bart compare -r rules-file control-manifest test-manifest > bart.report |
The following rules file includes directives for both the bart create and the bart compare commands. The rules file directs the bart create command to list information about the contents of the /usr/bin directory. In addition, the rules file directs the bart compare command to track only size and content changes in the same directory.
# Check size and content changes in the /usr/bin directory. # This rules file only checks size and content changes. # See rules file example. IGNORE all CHECK size contents /usr/bin |
# bart create -r bartrules.txt > usr_bin.control-manifest.121003 |
Create a test manifest whenever you want to monitor changes to the /usr/bin directory.
# bart create -r bartrules.txt > usr_bin.test-manifest.121103 |
Compare the manifests by using the same rules file.
# bart compare -r bartrules.txt usr_bin.control-manifest \ usr_bin.test-manifest |
Examine the output of the bart compare command.
/usr/bin/gunzip: add /usr/bin/ypcat: delete |
In the preceding output, the bart compare command reported a discrepancy in the /usr/bin directory. This output indicates that /usr/bin/ypcat file was deleted, and the /usr/bin/gunzip file was added.
