System Administration Guide: Security Services
Using the Key Management Framework (Task Map)
The Key Management Framework (KMF) enables you to centrally manage public key technologies.
For Instructions
Create a certificate.
Creates a certificate for use by PKCS #11, NSS, or SSL.
How to Create a Certificate by Using the pktool gencert Command
Export a certificate.
Creates a file with the certificate and its supporting keys. The file can be protected with a password.
How to Export a Certificate and Private Key in PKCS #12 Format
Import a certificate.
Imports a certificate from another system.
How to Import a Certificate Into Your Keystore
Imports a certificate in PKCS #12 format from another system.
Example 15–2
Generate a passphrase.
Generates a passphrase for access to a PKCS #11 keystore or an NSS keystore.
How to Generate a Passphrase by Using the pktool setpin Command
