System Administration Guide: Security Services
ProcedureHow to Automatically Configure a Kerberos Client
Before You Begin
This procedure uses an installation profile. See How to Create a Kerberos Client Installation Profile.
  1. Become superuser.
  2. Run the kclient installation script.
    You need to provide the password for the clntconfig principal to complete the process.
    client# /usr/sbin/kclient -p /net/denver.example.com/export/install/profile
    Starting client setup
    kdc1.example.com
    Setting up /etc/krb5/krb5.conf.
    Obtaining TGT for clntconfig/admin ...
    Password for clntconfig/admin@EXAMPLE.COM: <Type the password>
    nfs/client.example.com entry ADDED to KDC database.
    nfs/client.example.com entry ADDED to keytab.
    host/client.example.com entry ADDED to KDC database.
    host/client.example.com entry ADDED to keytab.
    Copied /net/denver.example.com/export/install/krb5.conf.
    Setup COMPLETE.
    client#
Example 23–7 Automatically Configuring a Kerberos Client With Command-Line Overrides
The following example overrides the DNSARG and the KDC parameters that are set in the installation profile.
# /usr/sbin/kclient -p /net/denver.example.com/export/install/profile\
-d dns_fallback -k kdc2.example.com
kdc1.example.com
Setup COMPLETE.
client#
