System Administration Guide: Security Services
Controlling System Access (Task Map)
A computer is as secure as its weakest point of entry. The following task map shows the areas that you should monitor and secure.
For Instructions
Monitor, permit, and deny user login
Monitors unusual login activity. Prevents logins temporarily. Manages dial-up logins.
Securing Logins and Passwords (Task Map)
Provide strong password encryption
Specifies algorithms to encrypt user passwords. Installs additional algorithms.
Changing the Password Algorithm (Task Map)
Monitor and restrict superuser activities
Regularly monitors superuser activity. Prevents remote login by a root user.
Monitoring and Restricting Superuser (Task Map)
Prevent access to hardware settings
Keeps ordinary users away from the PROM.
SPARC: Controlling Access to System Hardware (Task Map)
