Writing Device Drivers
Appendix B Summary of Solaris DDI/DKI Services
This appendix discusses the interfaces provided by the Solaris DDI/DKI. These descriptions should not be considered complete or definitive, nor do they provide a thorough guide to usage. The descriptions are intended to describe what the functions do in general terms. See physio(9F) for more detailed information. The categories are:
Module Functions
The module functions are:
mod_info
Query a loadable module
mod_install
Add a loadable module
mod_remove
Remove a loadable module
Device Information Tree Node (dev_info_t) Functions
The device information tree node functions are:
ddi_binding_name()
Return driver binding name
ddi_dev_is_sid()
Tell whether a device is self-identifying
ddi_driver_major()
Return driver major device number
ddi_driver_name()
Return normalized driver name
ddi_node_name()
Return the devinfo node name
ddi_get_devstate()
Check device state
ddi_get_instance()
Get device instance number
ddi_get_name()
ddi_get_parent()
Find the parent of a device information structure
ddi_root_node()
Get the root of the dev_info tree
Device (dev_t) Functions
The device functions are:
ddi_create_minor_node()
Create a minor node for a device
ddi_getiminor()
Get kernel internal minor number from an external dev_t
ddi_remove_minor_node()
Remove a minor mode for a device
getmajor()
Get major device number
getminor()
Get minor device number
makedevice()
Make device number from major and minor numbers
Property Functions
The property functions are:
ddi_prop_exists()
Check for the existence of a property
ddi_prop_free()
Free resources consumed by property lookup
ddi_prop_get_int()
Look up integer property
ddi_prop_get_int64()
Look up 64-bit integer property
ddi_prop_lookup_byte_array()
Look up byte array property
ddi_prop_lookup_int_array()
Look up integer array property
ddi_prop_lookup_int64_array()
Look up 64-bit integer array property
ddi_prop_lookup_string()
Look up string property
ddi_prop_lookup_string_array()
Look up string array property
ddi_prop_remove()
Remove a property of a device
ddi_prop_remove_all()
Remove all properties of a device
ddi_prop_undefine()
Hide a property of a device
ddi_prop_update_byte_array()
Create or update byte array property
ddi_prop_update_int()
Create or update integer property
ddi_prop_update_int64()
Create or update 64-bit integer property
ddi_prop_update_int_array()
Create or update integer array property
ddi_prop_update_int64_array()
Create or update 64-bit integer array property
ddi_prop_update_string()
Create or update string property
ddi_prop_update_string_array()
Create or update string array property
Table B–1 Deprecated Property Functions
Deprecated Functions
Replacements
ddi_getlongprop()
see ddi_prop_lookup()
ddi_getlongprop_buf()
ddi_prop_lookup()
ddi_getprop()
ddi_prop_get_int()
ddi_getproplen()
ddi_prop_lookup()
ddi_prop_create()
ddi_prop_lookup()
ddi_prop_modify()
ddi_prop_lookup()
ddi_prop_op()
ddi_prop_lookup()
Device Software State Functions
The device software state functions are:
ddi_get_driver_private()
Get the address of the device's private data area
ddi_get_soft_state()
Get pointer to instance soft-state structure
ddi_set_driver_private()
Set the address of the device's private data area
ddi_soft_state_fini()
Destroy driver soft-state structure
ddi_soft_state_free()
Free instance soft-state structure
ddi_soft_state_init()
Initialize driver soft-state structure
ddi_soft_state_zalloc()
Allocate instance soft-state structure
Memory Allocation and Deallocation Functions
The memory allocation and deallocation functions are:
kmem_alloc()
Allocate kernel memory
kmem_free()
Free kernel memory
kmem_zalloc()
Allocate zero-filled kernel memory
The following functions allocate and free memory intended to be used for DMA. See Direct Memory Access (DMA) Functions.
ddi_dma_mem_alloc()
Allocate memory for DMA transfer
ddi_dma_mem_free()
Free previously allocated DMA memory
The following functions allocate and free memory intended to be exported to user space. See User Space Access Functions.
ddi_umem_alloc()
Allocate page-aligned kernel memory
ddi_umem_free()
Free page-aligned kernel memory
Table B–2 Deprecated Memory Allocation and Deallocation Functions
Deprecated Function
Replacement
ddi_iopb_alloc()
ddi_dma_mem_alloc()
ddi_iopb_free()
ddi_dma_mem_free()
ddi_mem_alloc()
ddi_dma_mem_alloc()
ddi_mem_free()
ddi_dma_mem_free()
Kernel Thread Control and Synchronization Functions
The kernel thread control and synchronization functions are:
cv_broadcast()
Wake up all waiting threads
cv_destroy()
Free an allocated condition variable
cv_init()
Allocate a condition variable
cv_signal()
Wake up one waiting thread
cv_timedwait()
Await an event with timeout
cv_timedwait_sig()
Await an event or signal with timeout
cv_wait()
Await an event
cv_wait_sig()
ddi_can_receive_sig()
Determine whether the current thread can receive a signal
ddi_enter_critical()
Enter a critical region of control
ddi_exit_critical()
Exit a critical region of control
mutex_destroy()
Destroy mutual exclusion lock
mutex_enter()
Acquire mutual exclusion lock
mutex_exit()
Release mutual exclusion lock
mutex_init()
Initialize mutual exclusion lock
mutex_owned()
Determine whether current thread is holding mutual exclusion lock
mutex_tryenter()
Attempt to acquire mutual exclusion lock without waiting
rw_destroy()
Destroy a readers/writer lock
rw_downgrade()
Downgrade a readers/writer lock holding from writer to reader
rw_enter()
Acquire a readers/writer lock
rw_exit()
Release a readers/writer lock
rw_init()
Initialize a readers/writer lock
rw_read_locked()
Determine whether readers/writer lock is held for read or write
rw_tryenter()
Attempt to acquire a readers/writer lock without waiting
rw_tryupgrade()
Attempt to upgrade readers/writer lock holding from reader to writer
sema_destroy()
Destroy a semaphore
sema_init()
Initialize a semaphore
sema_p()
Decrement semaphore and possibly block
sema_p_sig()
Decrement semaphore but do not block if signal is pending
sema_tryp()
Attempt to decrement semaphore but do not block
sema_v()
Increment semaphore and possibly unblock waiter
Task Queue Management Functions
The task queue management functions are listed below. See the taskq(9F) man page for more information about these interfaces.
ddi_taskq_create()
Create a task queue
ddi_taskq_destroy()
Destroy a task queue
ddi_taskq_dispatch()
Add a task to a task queue
ddi_taskq_wait()
Wait for pending tasks to complete
ddi_taskq_suspend()
Suspend a task queue
ddi_taskq_suspended()
Check whether a task queue is suspended
ddi_taskq_resume()
Resume a suspended task queue
Interrupt Functions
The interrupt functions are:
ddi_intr_add_handler(9F)
Adds an interrupt handler.
ddi_intr_add_softint(9F)
Adds a soft interrupt handler.
ddi_intr_alloc(9F)
Allocates system resources and interrupt vectors for the specified type of interrupt.
ddi_intr_block_disable(9F)
Disables the specified range of interrupts. For MSI only.
ddi_intr_block_enable(9F)
Enables the specified range of interrupts. For MSI only.
ddi_intr_clr_mask(9F)
Clears an interrupt mask if the specified interrupt is enabled.
ddi_intr_disable(9F)
Disables the specified interrupt.
ddi_intr_dup_handler(9F)
Use with MSI-X only. Copies an address and data pair for an allocated interrupt vector to an unused interrupt vector on the same device.
ddi_intr_enable(9F)
Enables the specified interrupt.
ddi_intr_free(9F)
Releases the system resources and interrupt vectors for a specified interrupt handle.
ddi_intr_get_cap(9F)
Returns interrupt capability flags for the specified interrupt.
ddi_intr_get_hilevel_pri(9F)
Returns the minimum priority level for a high-level interrupt.
ddi_intr_get_navail(9F)
Returns the number of interrupts available for a particular hardware device and given interrupt type.
ddi_intr_get_nintrs(9F)
Get the number of interrupts that the device supports for the given interrupt type.
ddi_intr_get_pending(9F)
Read the interrupt pending bit if one is supported by either the host bridge or the device.
ddi_intr_get_pri(9F)
Returns the current software priority setting for the specified interrupt.
ddi_intr_get_softint_pri(9F)
Returns the soft interrupt priority for the specified interrupt.
ddi_intr_get_supported_types(9F)
Returns the hardware interrupt types that are supported by both the device and the host.
ddi_intr_remove_handler(9F)
Removes the specified interrupt handler.
ddi_intr_remove_softint(9F)
Remove the specified soft interrupt handler.
ddi_intr_set_cap(9F)
Sets the DDI_INTR_FLAG_LEVEL or DDI_INTR_FLAG_EDGE flag for the specified interrupt.
ddi_intr_set_mask(9F)
Sets an interrupt mask if the specified interrupt is enabled.
ddi_intr_set_pri(9F)
Sets the interrupt priority level for the specified interrupt.
ddi_intr_set_softint_pri(9F)
Changes the relative soft interrupt priority for the specified soft interrupt.
ddi_intr_trigger_softint(9F)
Trigger the specified soft interrupt.
To take advantage of the features of the new framework, use the above interfaces. Do not use the deprecated interfaces that are listed in the following table. These deprecated interfaces are retained for compatibility purposes only.
Table B–3 Deprecated Interrupt Functions
Replacements
ddi_add_intr(9F)
Three-step process:
  1. ddi_intr_alloc(9F)
  2. ddi_intr_add_handler(9F)
  3. ddi_intr_enable(9F)
ddi_add_softintr(9F)
ddi_dev_nintrs(9F)
ddi_get_iblock_cookie(9F)
Three-step process:
  2. ddi_intr_get_pri(9F)
  3. ddi_intr_free(9F)
ddi_get_soft_iblock_cookie(9F)
Three-step process:
  1. ddi_intr_add_softint(9F)
  2. ddi_intr_get_softint_pri(9F)
  3. ddi_intr_remove_softint(9F)
ddi_intr_hilevel(9F)
Three-step process:
  2. ddi_intr_get_hilevel_pri(9F)
ddi_remove_intr(9F)
Three-step process:
  1. ddi_intr_disable(9F)
  2. ddi_intr_remove_handler(9F)
ddi_remove_softintr(9F)
ddi_trigger_softintr(9F)
Programmed I/O Functions
The programmed I/O functions are:
ddi_dev_nregs()
Return the number of register sets a device has
ddi_dev_regsize()
Return the size of a device's register
ddi_regs_map_setup()
Set up a mapping for a register address space
ddi_regs_map_free()
Free a previously mapped register address space
ddi_device_copy()
Copy data from one device register to another device register
ddi_device_zero()
Zero fill the device
ddi_check_acc_handle()
Check data access handle
ddi_get8()
Read 8-bit data from mapped memory, device register, or DMA memory
ddi_get16()
Read 16-bit data from mapped memory, device register, or DMA memory
ddi_get32()
Read 32-bit data from mapped memory, device register, or DMA memory
ddi_get64()
Read 64-bit data from mapped memory, device register, or DMA memory
ddi_put8()
Write 8-bit data to mapped memory, device register, or DMA memory
ddi_put16()
Write 16-bit data to mapped memory, device register, or DMA memory
ddi_put32()
Write 32-bit data to mapped memory, device register, or DMA memory
ddi_put64()
Write 64-bit data to mapped memory, device register, or DMA memory
ddi_rep_get8()
Read multiple 8-bit data from mapped memory, device register, or DMA memory
ddi_rep_get16()
Read multiple 16-bit data from mapped memory, device register, or DMA memory
ddi_rep_get32()
Read multiple 32-bit data from mapped memory, device register, or DMA memory
ddi_rep_get64()
Read multiple 64-bit data from mapped memory, device register, or DMA memory
ddi_rep_put8()
Write multiple 8-bit data to mapped memory, device register, or DMA memory
ddi_rep_put16()
Write multiple 16-bit data to mapped memory, device register, or DMA memory
ddi_rep_put32()
Write multiple 32-bit data to mapped memory, device register, or DMA memory
ddi_rep_put64()
Write multiple 64-bit data to mapped memory, device register, or DMA memory
ddi_peek8()
Cautiously read an 8-bit value from a location
ddi_peek16()
Cautiously read a 16-bit value from a location
ddi_peek32()
Cautiously read a 32-bit value from a location
ddi_peek64()
Cautiously read a 64-bit value from a location
ddi_poke8()
Cautiously write an 8-bit value to a location
ddi_poke16()
Cautiously write a 16-bit value to a location
ddi_poke32()
Cautiously write a 32-bit value to a location
ddi_poke64()
Cautiously write a 64-bit value to a location
The general programmed I/O functions listed above can always be used rather than the mem, io, and pci_config functions that follow. However, the following functions can be used as alternatives in cases where the type of access is known at compile time.
ddi_io_get8()
Read 8-bit data from a mapped device register in I/O space
ddi_io_get16()
Read 16-bit data from a mapped device register in I/O space
ddi_io_get32()
Read 32-bit data from a mapped device register in I/O space
ddi_io_put8()
Write 8-bit data to a mapped device register in I/O space
ddi_io_put16()
Write 16-bit data to a mapped device register in I/O space
ddi_io_put32()
Write 32-bit data to a mapped device register in I/O space
ddi_io_rep_get8()
Read multiple 8-bit data from a mapped device register in I/O space
ddi_io_rep_get16()
Read multiple 16-bit data from a mapped device register in I/O space
ddi_io_rep_get32()
Read multiple 32-bit data from a mapped device register in I/O space
ddi_io_rep_put8()
Write multiple 8-bit data to a mapped device register in I/O space
ddi_io_rep_put16()
Write multiple 16-bit data to a mapped device register in I/O space
ddi_io_rep_put32()
Write multiple 32-bit data to a mapped device register in I/O space
ddi_mem_get8()
Read 8-bit data from a mapped device in memory space or DMA memory
ddi_mem_get16()
Read 16-bit data from a mapped device in memory space or DMA memory
ddi_mem_get32()
Read 32-bit data from a mapped device in memory space or DMA memory
ddi_mem_get64()
Read 64-bit data from a mapped device in memory space or DMA memory
ddi_mem_put8()
Write 8-bit data to a mapped device in memory space or DMA memory
ddi_mem_put16()
Write 16-bit data to a mapped device in memory space or DMA memory
ddi_mem_put32()
Write 32-bit data to a mapped device in memory space or DMA memory
ddi_mem_put64()
Write 64-bit data to a mapped device in memory space or DMA memory
ddi_mem_rep_get8()
Read multiple 8-bit data from a mapped device in memory space or DMA memory
ddi_mem_rep_get16()
Read multiple 16-bit data from a mapped device in memory space or DMA memory
ddi_mem_rep_get32()
Read multiple 32-bit data from a mapped device in memory space or DMA memory
ddi_mem_rep_get64()
Read multiple 64-bit data from a mapped device in memory space or DMA memory
ddi_mem_rep_put8()
Write multiple 8-bit data to a mapped device in memory space or DMA memory
ddi_mem_rep_put16()
Write multiple 16-bit data to a mapped device in memory space or DMA memory
ddi_mem_rep_put32()
Write multiple 32-bit data to a mapped device in memory space or DMA memory
ddi_mem_rep_put64()
Write multiple 64-bit data to a mapped device in memory space or DMA memory
pci_config_setup()
Set up access to PCI Local Bus Configuration space
pci_config_teardown()
Tear down access to PCI Local Bus Configuration space
pci_config_get8()
Read 8-bit data from the PCI Local Bus Configuration space
pci_config_get16()
Read 16-bit data from the PCI Local Bus Configuration space
pci_config_get32()
Read 32-bit data from the PCI Local Bus Configuration space
pci_config_get64()
Read 64-bit data from the PCI Local Bus Configuration space
pci_config_put8()
Write 8-bit data to the PCI Local Bus Configuration space
pci_config_put16()
Write 16-bit data to the PCI Local Bus Configuration space
pci_config_put32()
Write 32-bit data to the PCI Local Bus Configuration space
pci_config_put64()
Write 64-bit data to the PCI Local Bus Configuration space
Table B–4 Deprecated Programmed I/O Functions
Deprecated Function
Replacement
ddi_getb()
ddi_get8()
ddi_getl()
ddi_get32()
ddi_getll()
ddi_get64()
ddi_getw()
ddi_get16()
ddi_io_getb()
ddi_io_get8()
ddi_io_getl()
ddi_io_get32()
ddi_io_getw()
ddi_io_get16()
ddi_io_putb()
ddi_io_put8()
ddi_io_putl()
ddi_io_put32()
ddi_io_putw()
ddi_io_put16()
ddi_io_rep_getb()
ddi_io_rep_get8()
ddi_io_rep_getl()
ddi_io_rep_get32()
ddi_io_rep_getw()
ddi_io_rep_get16()
ddi_io_rep_putb()
ddi_io_rep_put8()
ddi_io_rep_putl()
ddi_io_rep_put32()
ddi_io_rep_putw()
ddi_io_rep_put16()
ddi_map_regs()
ddi_mem_getb()
ddi_mem_get8()
ddi_mem_getl()
ddi_mem_get32()
ddi_mem_getll()
ddi_mem_get64()
ddi_mem_getw()
ddi_mem_get16()
ddi_mem_putb()
ddi_mem_put8()
ddi_mem_putl()
ddi_mem_put32()
ddi_mem_putll()
ddi_mem_put64()
ddi_mem_putw()
ddi_mem_put16()
ddi_mem_rep_getb()
ddi_mem_rep_get8()
ddi_mem_rep_getl()
ddi_mem_rep_get32()
ddi_mem_rep_getll()
ddi_mem_rep_get64()
ddi_mem_rep_getw()
ddi_mem_rep_get16()
ddi_mem_rep_putb()
ddi_mem_rep_put8()
ddi_mem_rep_putl()
ddi_mem_rep_put32()
ddi_mem_rep_putll()
ddi_mem_rep_put64()
ddi_mem_rep_putw()
ddi_mem_rep_put16()
ddi_peekc()
ddi_peek8()
ddi_peekd()
ddi_peek64()
ddi_peekl()
ddi_peek32()
ddi_peeks()
ddi_peek16()
ddi_pokec()
ddi_poke8()
ddi_poked()
ddi_poke64()
ddi_pokel()
ddi_poke32()
ddi_pokes()
ddi_poke16()
ddi_putb()
ddi_put8()
ddi_putl()
ddi_put32()
ddi_putll()
ddi_put64()
ddi_putw()
ddi_put16()
ddi_rep_getb()
ddi_rep_get8()
ddi_rep_getl()
ddi_rep_get32()
ddi_rep_getll()
ddi_rep_get64()
ddi_rep_getw()
ddi_rep_get16()
ddi_rep_putb()
ddi_rep_put8()
ddi_rep_putl()
ddi_rep_put32()
ddi_rep_putll()
ddi_rep_put64()
ddi_rep_putw()
ddi_rep_put16()
ddi_unmap_regs()
ddi_regs_map_free()
inb()
ddi_io_get8()
inl()
ddi_io_get32()
inw()
ddi_io_get16()
outb()
ddi_io_put8()
outl()
ddi_io_put32()
outw()
ddi_io_put16()
pci_config_getb()
pci_config_get8()
pci_config_getl()
pci_config_get32()
pci_config_getll()
pci_config_get64()
pci_config_getw()
pci_config_get16()
pci_config_putb()
pci_config_put8()
pci_config_putl()
pci_config_put32()
pci_config_putll()
pci_config_put64()
pci_config_putw()
pci_config_put16()
repinsb()
ddi_io_rep_get8()
repinsd()
ddi_io_rep_get32()
repinsw()
ddi_io_rep_get16()
repoutsb()
ddi_io_rep_put8()
repoutsd()
ddi_io_rep_put32()
repoutsw()
ddi_io_rep_put16()
The DMA functions are:
ddi_dma_alloc_handle()
Allocate a DMA handle
ddi_dma_free_handle()
Free a DMA handle
ddi_dma_mem_alloc()
Allocate memory for a DMA transfer
ddi_dma_mem_free()
ddi_dma_addr_bind_handle()
Bind an address to a DMA handle
ddi_dma_buf_bind_handle()
Bind a system buffer to a DMA handle
ddi_dma_unbind_handle()
Unbind the address in a DMA handle
ddi_dma_nextcookie()
Retrieve the subsequent DMA cookie
ddi_dma_getwin()
Activate a new DMA window
ddi_dma_numwin()
Retrieve number of DMA windows
ddi_dma_sync()
Synchronize CPU and I/O views of memory
ddi_check_dma_handle()
Check a DMA handle
ddi_dma_set_sbus64()
Allow 64-bit transfers on SBus
ddi_slaveonly()
Report whether a device is installed in a slave access-only location
ddi_iomin()
Find the minimum alignment and transfer size for DMA
ddi_dma_burstsizes()
Find out the allowed burst sizes for a DMA mapping
ddi_dma_devalign()
Find DMA mapping alignment and minimum transfer size
ddi_dmae_alloc()
Acquire a DMA channel
ddi_dmae_release()
Release a DMA channel
ddi_dmae_getattr()
Get the DMA engine attributes
ddi_dmae_prog()
Program a DMA channel
ddi_dmae_stop()
Terminate a DMA engine operation
ddi_dmae_disable()
Disable a DMA channel
ddi_dmae_enable()
Enable a DMA channel
ddi_dmae_getcnt()
Get the remaining DMA engine count
ddi_dmae_1stparty()
Configure the DMA channel cascade mode
ddi_dma_coff()
Convert a DMA cookie to an offset within a DMA handle
Table B–5 Deprecated Direct Memory Access (DMA) Functions
Deprecated Function
Replacement
ddi_dma_addr_setup()
ddi_dma_alloc_handle(), ddi_dma_addr_bind_handle()
ddi_dma_buf_setup()
ddi_dma_alloc_handle(), ddi_dma_buf_bind_handle()
ddi_dma_curwin()
ddi_dma_getwin()
ddi_dma_free()
ddi_dma_htoc()
ddi_dma_addr_bind_handle(), ddi_dma_buf_bind_handle()
ddi_dma_movwin()
ddi_dma_getwin()
ddi_dma_nextseg()
ddi_dma_segtocookie()
ddi_dma_setup()
ddi_dma_alloc_handle(), ddi_dma_addr_bind_handle(), ddi_dma_buf_bind_handle()
ddi_dmae_getlim()
ddi_dmae_getattr()
ddi_iopb_alloc()
ddi_dma_mem_alloc()
ddi_iopb_free()
ddi_dma_mem_free()
ddi_mem_alloc()
ddi_dma_mem_alloc()
ddi_mem_free()
ddi_dma_mem_free()
hat_getkpfnum()
ddi_dma_addr_bind_handle(), ddi_dma_buf_bind_handle(), ddi_dma_nextcookie()
The user space access functions are:
ddi_copyin()
Copy data to a driver buffer
ddi_copyout()
Copy data from a driver
uiomove()
Copy kernel data using a uio structure
ureadc()
Add character to a uio structure
uwritec()
Remove a character from a uio structure
getminor()
Get minor device number.
ddi_model_convert_from()
Determine a data model type mismatch
IOC_CONVERT_FROM()
Determine whether there is a need to translate M_IOCTL contents
STRUCT_DECL()
Establish the handle to application data in a possibly differing data model
STRUCT_HANDLE()
STRUCT_INIT()
STRUCT_SET_HANDLE()
SIZEOF_PTR()
Return the size of pointer in specified data model
SIZEOF_STRUCT()
Return the size of a structure in the specified data model
STRUCT_SIZE()
Return the size of a structure in the application data model
STRUCT_BUF()
Return a pointer to the native mode instance of the structure
STRUCT_FADDR()
Return a pointer to the specified field of a structure
STRUCT_FGET()
Return the specified field of a structure in the application data model
STRUCT_FGETP()
Return the specified pointer field of a structure in the application data model
STRUCT_FSET()
Set a specified field of a structure in the application data model
STRUCT_FSETP()
Set a specified pointer field of a structure in the application data model
Table B–6 Deprecated User Space Access Functions
Deprecated Function
Replacement
copyin()
ddi_copyin()
copyout()
ddi_copyout()
ddi_getminor()
getminor()
User Process Event Functions
The user process event functions are:
pollwakeup()
Inform a process that an event has occurred
proc_ref()
Get a handle on a process to signal
proc_unref()
Release a handle on a process to signal
proc_signal()
Send a signal to a process
User Process Information Functions
The user process information functions are:
ddi_get_cred()
Return a pointer to the credential structure of the caller
drv_priv()
Determine process credentials privilege
ddi_get_pid()
Return the process ID
Table B–7 Deprecated User Process Information Functions
Replacement
drv_getparm()
ddi_get_pid(), ddi_get_cred()
User Application Kernel and Device Access Functions
The user application kernel and device access functions are:
ddi_dev_nregs()
ddi_dev_regsize()
ddi_devmap_segmap(), devmap_setup()
Set up a user mapping to device memory using the devmap framework
devmap_devmem_setup()
Export device memory to user space
devmap_load()
Validate memory address translations
devmap_unload()
Invalidate memory address translations
devmap_do_ctxmgt()
Perform device context switching on a mapping
devmap_set_ctx_timeout()
Set the timeout value for the context management callback
devmap_default_access()
Default driver memory access function
ddi_umem_alloc()
ddi_umem_free()
ddi_umem_lock()
Lock memory pages
ddi_umem_unlock()
Unlock memory pages
ddi_umem_iosetup()
Setup I/O requests to application memory
devmap_umem_setup()
Export kernel memory to user space
Determine data model type mismatch
Table B–8 Deprecated User Application Kernel and Device Access Functions
Deprecated Function
Replacement
ddi_mapdev()
devmap_setup()
ddi_mapdev_intercept()
devmap_load()
ddi_mapdev_nointercept()
devmap_unload()
ddi_mapdev_set_device_acc_attr()
devmap()
ddi_segmap()
devmap()
ddi_segmap_setup()
devmap_setup()
hat_getkpfnum()
devmap()
ddi_mmap_get_model()
devmap()
Time-Related Functions
The time-related functions are:
ddi_get_lbolt()
Return the number of clock ticks since reboot
ddi_get_time()
Return the current time in seconds
ddi_periodic_add()
Issue nanosecond periodic timeout requests
ddi_periodic_delete()
Cancel nanosecond periodic timeout requests
delay()
Delay execution for a specified number of clock ticks
drv_hztousec()
Convert clock ticks to microseconds
drv_usectohz()
Convert microseconds to clock ticks
drv_usecwait()
Busy-wait for specified interval
gethrtime()
Get high-resolution time
gethrvtime()
Get high-resolution LWP virtual time
timeout()
Execute a function after a specified length of time
untimeout()
Cancel the previous time out function call
drv_getparm()
ddi_get_lbolt(), ddi_get_time()
Table B–9 Deprecated Time-Related Functions
Deprecated Function
Replacement
drv_getparm()
Power Management Functions
The power management functions are:
ddi_removing_power()
Check if device loses power with DDI_SUSPEND
pci_report_pmcap()
Report the power management capability of a PCI device
pm_busy_component()
Mark a component as busy
pm_idle_component()
Mark a component as idle
pm_raise_power()
Raise the power level of a component
pm_lower_power()
Lower the power level of a component
pm_power_has_changed()
Notify the power management framework of an autonomous power level change
pm_trans_check()
Device power cycle advisory check
Table B–10 Deprecated Power Management Functions
Function Name
Description
ddi_dev_is_needed()
Inform the system that a device's component is required
pm_create_components()
Create power-manageable components
pm_destroy_components()
Destroy power-manageable components
pm_get_normal_power()
Get the normal power level of a device component
pm_set_normal_power()
Set the normal power level of a device component
Fault Management Functions
The fault management functions are:
ddi_fm_init()
Allocates and initializes resources based on declared fault management capabilities
ddi_fm_fini()
Cleans up resources that were allocated for this device instance to support fault management capabilities declared to ddi_fm_init()
ddi_fm_capable()
Returns the capability bit mask currently set for this device instance
ddi_fm_handler_register()
Registers an error handler callback routine with the IO Fault Management framework
ddi_fm_handler_unregister()
Removes an error handler callback routine that was registered with ddi_fm_handler_register()
ddi_fm_acc_err_get()
Returns the error status for an access handle
ddi_fm_dma_err_get()
Returns the error status for a DMA handle
ddi_fm_acc_err_clear()
Clears the error status for an access handle
ddi_fm_dma_err_clear()
Clears the error status for a DMA handle
ddi_fm_ereport_post()
Queues an encoded fault management error report name-value pair list for delivery to the Fault Manager daemon, fmd(1M)
ddi_fm_service_impact()
Reports the impact of an error
pci_ereport_setup()
Initializes support for error report generation and sets up the resources for subsequent accesses to PCI, PCI/X, or PCI Express configuration space
pci_ereport_teardown()
Releases any resources allocated and setup by pci_ereport_setup() for this device instance
pci_ereport_post()
Scans for and posts any PCI, PCI/X, or PCI Express bus errors
Kernel Statistics Functions
The kernel statistics (kstats) functions are:
kstat_create()
Create and initialize a new kstat
kstat_delete()
Remove a kstat from the system
kstat_install()
Add a fully initialized kstat to the system
kstat_named_init()
Initialize a named kstat
kstat_runq_back_to_waitq()
Record a transaction migration from run queue to the wait queue
kstat_runq_enter()
Record a transaction addition to the run queue
kstat_runq_exit()
Record a transaction removal from the run queue
kstat_waitq_enter()
Record a transaction addition to the wait queue
kstat_waitq_exit()
Record a transaction removal from the wait queue
kstat_waitq_to_runq()
Record a transaction migration from the wait queue to the run queue
Kernel Logging and Printing Functions
The kernel logging and printing functions are:
cmn_err(), vcmn_err()
Display an error message
ddi_report_dev()
Announce a device
strlog()
Submit messages to the log driver
ddi_dev_report_fault()
Report a hardware failure
scsi_errmsg()
Display a SCSI request sense message
scsi_log()
Display a SCSI-device-related message
scsi_vu_errmsg()
Buffered I/O Functions
The buffered I/O functions are:
physio()
Perform physical I/O
aphysio()
Perform asynchronous physical I/O
anocancel()
Prevent cancellation of an asynchronous I/O request
minphys()
Limit the physio() buffer size
biowait()
Suspend processes pending completion of block I/O
biodone()
Release the buffer after buffer I/O transfer and notify blocked threads
bioerror()
Indicate the error in a buffer header
geterror()
Return an I/O error
bp_mapin()
Allocate virtual address space
bp_mapout()
Deallocate virtual address space
disksort()
Use a single-direction elevator seek strategy to sort for buffers
getrbuf()
Get a raw buffer header
freerbuf()
Free a raw buffer header
biosize()
Return the size of a buffer structure
bioinit()
Initialize a buffer structure
biofini()
Uninitialize a buffer structure
bioreset()
Reuse a private buffer header after I/O is complete
bioclone()
Clone another buffer
biomodified()
Check whether a buffer is modified
clrbuf()
Erase the contents of a buffer
Virtual Memory Functions
The virtual memory functions are:
ddi_btop()
Convert device bytes to pages (round down)
ddi_btopr()
Convert device bytes to pages (round up)
ddi_ptob()
Convert device pages to bytes
btop()
Convert size in bytes to size in pages (round down)
btopr()
Convert size in bytes to size in pages (round up)
ptob()
Convert size in pages to size in bytes
Table B–11 Deprecated Virtual Memory Functions
Replacement
hat_getkpfnum()
devmap(), ddi_dma_*_bind_handle(), ddi_dma_nextcookie()
Device ID Functions
The device ID functions are:
ddi_devid_init()
Allocate a device ID structure
ddi_devid_free()
Free a device ID structure
ddi_devid_register()
Register a device ID
ddi_devid_unregister()
Unregister a device ID
ddi_devid_compare()
Compare two device IDs
ddi_devid_sizeof()
Return the size of a device ID
ddi_devid_valid()
Validate a device ID
ddi_devid_str_encode()
Encode a device ID and minor_name into a null-terminated ASCII string; return a pointer to that string
ddi_devid_str_decode()
Decode the device ID and minor_name from a previously encoded string; allocate and return pointers to the extracted parts
ddi_devid_str_free()
Free all strings returned by the ddi_devid_* functions
SCSI Functions
The SCSI functions are:
scsi_probe()
Probe a SCSI device
scsi_unprobe()
Free resources allocated during initial probing
scsi_alloc_consistent_buf()
Allocate an I/O buffer for SCSI DMA
scsi_free_consistent_buf()
Free a previously allocated SCSI DMA I/O buffer
scsi_init_pkt()
Prepare a complete SCSI packet
scsi_destroy_pkt()
Free an allocated SCSI packet and its DMA resource
scsi_setup_cdb()
Set up SCSI command descriptor block (CDB)
scsi_transport()
Start a SCSI command
scsi_poll()
Run a polled SCSI command
scsi_ifgetcap()
Get SCSI transport capability
scsi_ifsetcap()
Set SCSI transport capability
scsi_sync_pkt()
scsi_abort()
Abort a SCSI command
scsi_reset()
Reset a SCSI bus or target
scsi_reset_notify()
Notify the target driver of bus resets
scsi_cname()
Decode a SCSI command
scsi_dname()
Decode a SCSI peripheral device type
scsi_mname()
Decode a SCSI message
scsi_rname()
Decode a SCSI packet completion reason
scsi_sname()
Decode a SCSI sense key
scsi_errmsg()
scsi_log()
scsi_vu_errmsg()
scsi_hba_init()
SCSI HBA system initialization routine
scsi_hba_fini()
SCSI HBA system completion routine
scsi_hba_attach_setup()
SCSI HBA attach routine
scsi_hba_detach()
SCSI HBA detach routine
scsi_hba_probe()
Default SCSI HBA probe function
scsi_hba_tran_alloc()
Allocate a transport structure
scsi_hba_tran_free()
Free a transport structure
scsi_hba_pkt_alloc()
Allocate a scsi_pkt structure
scsi_hba_pkt_free()
Free a scsi_pkt structure
scsi_hba_lookup_capstr()
Return an index matching capability string
Table B–12 Deprecated SCSI Functions
Deprecated Function
Replacement
free_pktiopb()
get_pktiopb()
makecom_g0()
scsi_setup_cdb()
makecom_g0_s()
scsi_setup_cdb()
makecom_g1()
scsi_setup_cdb()
makecom_g5()
scsi_setup_cdb()
scsi_dmafree()
scsi_destroy_pkt()
scsi_dmaget()
scsi_init_pkt()
scsi_hba_attach()
scsi_pktalloc()
scsi_init_pkt()
scsi_pktfree()
scsi_destroy_pkt()
scsi_resalloc()
scsi_init_pkt()
scsi_resfree()
scsi_destroy_pkt()
scsi_slave()
scsi_probe()
scsi_unslave()
scsi_unprobe()
Resource Map Management Functions
The resource map management functions are:
rmallocmap()
Allocate a resource map
rmallocmap_wait()
Allocate a resource map, wait if necessary
rmfreemap()
Free a resource map
rmalloc()
Allocate space from a resource map
rmalloc_wait()
Allocate space from a resource map, wait if necessary
rmfree()
Free space back into a resource map
System Global State
ddi_in_panic()
Determine whether the system is in panic state
Utility Functions
The utility functions are:
nulldev()
Zero return function
nodev()
Error return function
nochpoll()
Error return function for non-pollable devices
ASSERT()
Expression verification
bcopy()
Copy data between address locations in the kernel
bzero()
Clear memory for a given number of bytes
bcmp()
Compare two byte arrays
ddi_ffs()
Find the first bit set in a long integer
ddi_fls()
Find the last bit set in a long integer
swab()
Swap bytes in 16-bit halfwords
strcmp()
Compare two null-terminated strings
strncmp()
Compare two null-terminated strings, with length limit
strlen()
Determine the number of non-null bytes in a string
strcpy()
Copy a string from one location to another
strncpy()
Copy a string from one location to another, with length limit
strchr()
Find a character in a string
sprintf(), vsprintf()
Format characters in memory
numtos()
Convert an integer to a decimal string
stoi()
Convert a decimal string to an integer
max()
Return the larger of two integers
min()
Return the lesser of two integers
va_arg()
Finds the next value in a variable argument list
va_copy()
Copies the state of a variable argument list
va_end()
Deletes pointer to a variable argument list
va_start()
Finds the pointer to the start of a variable argument list
