Writing Device Drivers
tran_tgt_init() Entry Point
The tran_tgt_init(9E) entry point enables the HBA to allocate and initialize any per-target resources. tran_tgt_init() also enables the HBA to qualify the device's address as valid and supportable for that particular HBA. By returning DDI_FAILURE, the instance of the target driver for that device is not probed or attached.
tran_tgt_init() is not required. If tran_tgt_init() is not supplied, the framework attempts to probe and attach all possible instances of the appropriate target drivers.
static int
isp_tran_tgt_init(
    dev_info_t            *hba_dip,
    dev_info_t            *tgt_dip,
    scsi_hba_tran_t       *tran,
    struct scsi_device    *sd)
    return ((sd->sd_address.a_target < N_ISP_TARGETS_WIDE &&
        sd->sd_address.a_lun < 8) ? DDI_SUCCESS : DDI_FAILURE);
