Name | Synopsis | Description | Return Values | Errors | Attributes | See Also
c99 [ flag... ] file... -lm [ library... ] #include <math.h> int ilogb(double x);
int ilogbf(float x);
int ilogbl(long double x);
cc [ flag... ] file... -lm [ library... ] #include <math.h> int ilogb(double x);
These functions return the exponent part of their argument x. Formally, the return value is the integral part of logr| x | as a signed integral value, for non-zero x, where r is the radix of the machine's floating point arithmetic, which is the value of FLT_RADIX defined in <float.h>.
Upon successful completion, these functions return the exponent part of x as a signed integer value. They are equivalent to calling the corresponding logb(3M) function and casting the returned value to type int.
If x is 0, the value FP_ILOGB0 is returned. For SUSv3–conforming applications compiled with the c99 compiler driver (see standards(5)), a domain error occurs.
If x is ±Inf, the value INT_MAX is returned. For SUSv3–conforming applications compiled with the c99 compiler driver, a domain error occurs.
If x is NaN, the value FP_ILOGBNAN is returned. For SUSv3–conforming applications compiled with the c99 compiler driver, a domain error occurs.
These functions will fail if:
The x argument is zero, NaN, or ±Inf.
If the integer expression (math_errhandling & MATH_ERREXCEPT) is non-zero, then the invalid floating-point exception is raised.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Standard |
MT-Level |
MT-Safe |
feclearexcept(3M), fetestexcept(3M), limits.h(3HEAD), logb(3M), math.h(3HEAD), scalb(3M), attributes(5), standards(5)
