Verify that the ocfserv daemon is enabled.
The following command provides the status of the service.
% svcs network/rpc/ocfserv |
Before you make any changes to Smartcard, you must make sure that the ocfserv daemon is enabled.
(Optional) If necessary, as root, enable the ocfserv daemon.
# svcadm enable network/rpc/ocfserv |
Select OCF Server from the Navigation pane.
Double-click the icon that represents the local system.
Slide the indicator for the OCF Debug Level slider to indicate the level of debugging you want.
Slide the indicator for the Open Card Trace Level slider to indicate the trace level you want.
(Optional) Specify an alternate name for the debug file.
Click the Apply or OK button.
