The information in the /etc/saf/_sactab file is as follows:
# VERSION=1 zsmon:ttymon::0:/usr/lib/saf/ttymon # |
Indicates the Service Access Facility version number.
Is the name of the port monitor.
Is the type of port monitor.
Indicates whether the following two flags are set:
Do not enable the port monitor.
Do not start the port monitor. No flags are set in this example.
Indicates the return code value. A return count of 0 indicates that the port monitor is not be restarted if the port monitor fails.
Indicates the port monitor path name.
