The /etc/saf/pmtab/_pmtab file, such as /etc/saf/zsmon/_pmtab, is similar to the following:
# VERSION=1 ttya:u:root:reserved:reserved:reserved:/dev/term/a:I::/usr/bin/login::9600: ldterm,ttcompat:ttya login\: ::tvi925:y:# |
Indicates the Service Access Facility version number.
Indicates the service tag.
Identifies whether the following flags are set:
Do not enable the service.
Create a utmpx entry for the service.
Indicates the identity assigned to the service tag.
This field is reserved for future use.
Indicates the TTY port path name.
Identifies the full path name of the service to be invoked when a connection is received.
Indicates whether the following flags are set:
Sets the connect on carrier flag for the port.
Sets the port as bidirectional, allowing both incoming and outgoing traffic.
Suppresses an automatic hand-up immediately after an incoming call is received.
Initializes the port.
Forces ttymon to wait until it receives a character from the port before ttymon prints the login:message.
Identifies the TTY label defined in the /etc/ttydefs file.
Identifies the STREAMS modules to be pushed.
Identifies the prompt to be displayed.
Indicates yes or no response.
Identifies any inactive (disabled) response message.
Identifies the terminal type.
Indicates whether the software carrier is set (y/n).
