Solaris Containers: Resource Management and Solaris Zones Developer's Guide
Chapter 3 Using the C Interface to Extended Accounting
This chapter describes the C interface to extended accounting and covers the following topics:
Overview of the C Interface to Extended Accounting
Projects and tasks are used to label and separate workloads. The extended accounting subsystem is used to monitor resource consumption by workloads that are running on the system. Extended accounting produces accounting records for the workload tasks and processes.
For an overview of extended accounting and example procedures for administering extended accounting, see Chapter 4, Extended Accounting (Overview), in System Administration Guide: Solaris Containers-Resource Management and Solaris Zones and Chapter 5, Administering Extended Accounting (Tasks), in System Administration Guide: Solaris Containers-Resource Management and Solaris Zones.
Extended Accounting API Functions
The extended accounting API contains functions that perform the following:
exacct System Calls
The following table lists the system calls that interact with the extended accounting subsystem.
Table 3–1 Extended Accounting System Calls
Provides privileged processes with the ability to tag accounting records with additional data that is specific to the process
Enables privileged processes to request extended accounting buffers from the kernel for currently executing tasks and processes
Requests the kernel to write resource usage data for a specified task or process
Operations on the exacct File
These functions provide access to the exacct files:
Table 3–2 exacct File Functions
Opens an exacct file.
Closes an exacct file.
First time use on a group of objects reads data into an ea_object_t structure. Subsequent use on the group cycles through the objects in the group.
Appends the specified object to the open exacct file.
Reads the basic fields (eo_catalog and eo_type) into an ea_object_t structure and rewinds to the head of the record.
Skips back one object in the exacct file and reads the basic fields (eo_catalog and eo_type) into an ea_object_t.
Gets the name of the host on which the exacct file was created.
Determines the creator of the exacct file.
Operations on exacct Objects
These functions are used to access exacct objects:
Table 3–3 exacct Object Functions
Assigns an exacct object and sets the value(s).
Sets the values of a group of exacct objects.
Checks an exacct object's mask to see if that object has a specific catalog tag.
Attaches an exacct object to a specified exacct object.
Attaches a chain of exacct objects as member items of a specified group.
Frees the value fields in the specified exacct object.
Frees the specified exacct object and any attached hierarchies of objects.
Miscellaneous Operations
These functions are associated with miscellaneous operations:
C Code Examples for Accessing exacct Files
This section provides code examples for accessing exacct files.
Example 3–1 Displaying exacct Data for a Designated pid
This example displays a specific pid's exacct data snapshot from the kernel.
  ea_object_t *scratch;
  int unpk_flag = EUP_ALLOC;  /* use the same allocation flag */
                              /* for unpack and free */
  /* Omit return value checking, to keep code samples short */
  bsize = getacct(P_PID, pid, NULL, 0);
  buf = malloc(bsize);
  /* Retrieve exacct object and unpack */
  getacct(P_PID, pid, buf, bsize);
  ea_unpack_object(&scratch, unpk_flag, buf, bsize);
  /* Display the exacct record */
  if (scratch->eo_type == EO_GROUP) {
  ea_free_object(scratch, unpk_flag);
Example 3–2 Identifying Individual Tasks During a Kernel Build
This example evaluates kernel builds and displays a string that describes the portion of the source tree being built by this task make. Display the portion of the source being built to aid in the per-source-directory analysis.
The key points for this example include the following:
/* Omit return value checking and error processing */
/* to keep code sample short */
ptid = gettaskid();	/* Save "parent" task-id */
tid = settaskid(getprojid(), TASK_NORMAL);	/* Create new task */
/* Set data for item objects ptskid and cwd */
ea_set_item(&ptskid, EXT_UINT32 | EXC_LOCAL | MY_PTID, &ptid, 0);
ea_set_item(&cwd, EXT_STRING | EXC_LOCAL | MY_CWD, cwdbuf, strlen(cwdbuf));
/* Set grp object and attach ptskid and cwd to grp */
ea_set_group(&grp, EXT_GROUP | EXC_LOCAL |  EXD_GROUP_HEADER);
ea_attach_to_group(&grp, &ptskid);
ea_attach_to_group(&grp, &cwd);
/* Pack the object and put it back into the accounting stream */
ea_buflen = ea_pack_object(&grp, ea_buf, sizeof(ea_buf));
putacct(P_TASKID, tid, ea_buf, ea_buflen, EP_EXACCT_OBJECT);
/* Memory management: free memory allocate in ea_set_item */
ea_free_item(&cwd, EUP_ALLOC);
Example 3–3 Reading and Displaying the Contents of a System exacct File
This example shows how to read and display a system exacct file for a process or a task.
main(int argc, char *argv)
  ea_file_t ef;
  ea_object_t scratch;
  char *fname;
  fname = argv[1];
  ea_open(&ef, fname, NULL,  EO_NO_VALID_HDR, O_RDONLY, 0);
  bzero(&scratch, sizeof (ea_object_t));
  while (ea_get_object(&ef, &scratch)  != -1) {
	     if (scratch.eo_type == EO_GROUP)
	         disp_group(&ef, scratch.eo_group.eg_nobjs);
struct catalog_item {   /* convert Solaris catalog's type ID */
                        /* to a meaningful string */
	 int	type;
	 char *name;
 } catalog[] = {
	 { EXD_VERSION, 	"version\t" },
	 { EXD_PROC_PID,	"  pid\t" },
 static char *
 catalog_name(int type)
	 int i = 0;
	 while (catalog[i].type != EXD_NONE) {
		 if (catalog[i].type == type)
			 return (catalog[i].name);
	 return ("unknown\t");
 static void disp_obj(ea_object_t *o)
	 printf("%s\t", catalog_name(o->eo_catalog & 0xffffff));
	 switch(o->eo_catalog & EXT_TYPE_MASK) {
	 case EXT_UINT8:
		 printf(" 8: %u", o->eo_item.ei_uint8);
	 case EXT_UINT16:
 static void disp_group(ea_file_t *ef, uint_t nobjs)
	 for (i = 0; i < nobjs; i++) {
		 ea_get_object(ef, &scratch));
                disp_group(ef, scratch.eo_group.eg_nobjs);
