System Administration Guide: Basic Administration
Managing Software With the Oracle Solaris Product Registry GUI (Task Map)
The following task map describes the software management tasks that you can perform with the Oracle Solaris Product Registry.
Task
Description
For Instructions
View installed or uninstalled software with the Oracle Solaris Product Registry.
Used for learning about installed or uninstalled software.
How to View Installed or Uninstalled Software Information With the Oracle Solaris Product Registry GUI
Install software with the Oracle Solaris Product Registry.
You can use the Oracle Solaris Product Registry to find software and launch the Oracle Solaris installation GUI. This program takes you through the installation of that software.
How to Install Software With the Oracle Solaris Product Registry GUI
Uninstall software with the Oracle Solaris Product Registry.
Use tor uninstall software with the Oracle Solaris Product Registry.
How to Uninstall Software With the Oracle Solaris Product Registry GUI
The Oracle Solaris Product Registry is a tool to help you manage installed software. After you have installed the software, Product Registry provides a list of all the installed software by using the Oracle Solaris installation GUI or the pkgadd command.
You can use the Oracle Solaris Product Registry in a GUI or with a command-line interface (CLI). For more information on how to use the Oracle Solaris Product Registry CLI, see Managing Software With the Oracle Solaris Product Registry Command-Line Interface (Task Map).
The Oracle Solaris Product Registry GUI interface enables you to do the following:
The Oracle Solaris Product Registry GUI main window consists of three panes of information:
ProcedureHow to View Installed or Uninstalled Software Information With the Oracle Solaris Product Registry GUI
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Start the Oracle Solaris Product Registry tool.
    # prodreg &
    The Oracle Solaris Product Registry main window is displayed.
  3. Click the turner control that is located to the left of the System Registry directory in the Registered Software box.
    The turner control changes directions, from pointing right, to pointing downward. You can expand or collapse any item in the registry, except an item that has a text file icon to its left.
    The Software Installed in Registered Software box always contains the following components:
    • The configuration software group that you chose when you installed the Oracle Solaris release. Software groups that can be displayed include Reduced Network Support, Core, End User System Support, Developer System Support, Entire Distribution, or Entire Distribution Plus OEM Support.
    • Additional system software, which contains Oracle Solaris products that are not part of the software group you chose.
    • Unclassified software that is not a Oracle Solaris product or part of the software group. This software includes any package that you installed by using the pkgadd command.
  4. Select directories until you find a software application to view.
    The list expands as you open directories.
  5. To view the attributes, select a directory or file.
    The Product Registry displays attribute information in the System Registry box.
    • For software products that were installed with the installation GUI, the Oracle Solaris Product Registry contains values for at least the following: Title, Version, Location, and Installed on. Items in an expanded list under a product or software group inherit the version information of the product.
    • If all or part of the product was removed with the pkgrm command, a cautionary icon appears next to the software product's name.
ProcedureHow to Install Software With the Oracle Solaris Product Registry GUI
You can use Oracle Solaris Product Registry to find software and launch the installation GUI program. This program takes you through the installation of that software.
    # prodreg
  3. Depending on whether you are installing from a CD, a DVD, or from the network, do one of the following:
    • If you running a release that uses CDs, insert the CD into the CD-ROM drive.
    • If you are installing from a DVD, insert the DVD into the DVD-ROM drive.
    • If you are installing from the network, locate the net image of the software that you want to install.
      Note –
      In this Oracle Solaris release, the software is delivered on DVD only.
  4. To view the list of installed and registered software, click the turner control.
  5. Click the New Install button at the bottom of the Oracle Solaris Product Registry window.
    The Select Installer dialog box is displayed. This box initially points to the /cdrom directory or the directory you are in.
  6. Select directories to find the Oracle Solaris installation GUI installer.
    Oracle Solaris installation GUI installers are located in various directories on the CDs and on the DVD.
    • Solaris 10 Software CDs or DVD.
    • Solaris 10 Documentation DVD.
    • Solaris 10 Languages CD. The installation GUI automatically starts when the CD is inserted.
  7. When you find the installer you want, select its name in the Files box.
  8. Click OK.
    The installer you selected is launched.
  9. Follow the directions that are displayed by the installer to install the software.
ProcedureHow to Uninstall Software With the Oracle Solaris Product Registry GUI
    # prodreg
  3. To view the list of installed and registered software, click the turner control.
  4. Select directories until you find the name of the software that you want to uninstall.
  5. Read the software attributes to make sure that this software is the software that you want to uninstall.
  6. Click the Uninstall software-product-name button at the bottom of the Oracle Solaris Product Registry window.
    The software product you selected is uninstalled.
