How to Use Combination Code and Johap TTY in the ko
Locale
If you use a combination code (KS C 5601-1992) terminal , you must load
the kjohap STREAMS module into the kernel.
Become superuser.
system% su
Password: (Type superuser password here if required.)
Load the kjohap module.
# modload /usr/kernel/strmod/kjohap
Type the following command to enable the module.
