Korean Solaris User's Guide
How to Use Packed Code and Johap TTY in the ko Locale
If you use a Packed code (KS C 5601-1987) terminal , you must load the kpack STREAMS module into the kernel.
  1. Become superuser.
    system% su
    Password: (Type superuser password here if required.)
  2. Load the kpack module.
    #modload /kernel/strmod/kpack
  3. Type the following command to enable the module.
    system% setterm -x PACK
