System Administration Guide: Devices and File Systems
Chapter 23 Backing Up and Restoring UFS File Systems (Overview)
This chapter provides guidelines and planning information for backing up and restoring UFS file systems by using the ufsdump and ufsrestore commands.
This is a list of the overview information in this chapter.
Where to Find UFS Backup and Restore Tasks
Backup or Restore Task
For More Information
Back up file systems by using the ufsdump command.
Chapter 24, Backing Up UFS Files and File Systems (Tasks)
Create UFS snapshots by using the fssnap command.
Chapter 25, Using UFS Snapshots (Tasks)
Restore file systems by using the ufsrestore command.
Chapter 26, Restoring UFS Files and File Systems (Tasks)
Copy files and directories by using the cpio, dd, pax, and cpio commands.
Chapter 28, Copying UFS Files and File Systems (Tasks)
Introduction to Backing Up and Restoring UFS File Systems
Backing up file systems means copying file systems to removable media, such as tape, to safeguard against loss, damage, or corruption. Restoring file systems means copying reasonably current backup files from removable media to a working directory.
This chapter describes the ufsdump and ufsrestore commands for backing up and restoring UFS file systems. Other commands are available for copying files and file systems for the purpose of sharing or transporting files. The following table provides pointers to all commands that copy individual files and file systems to other media.
Table 23–1 Commands for Backing Up and Restoring Files and File Systems
Task
Command
Back up one or more file systems to a local tape device or a remote tape device.
ufsdump
Chapter 24, Backing Up UFS Files and File Systems (Tasks) or Chapter 27, UFS Backup and Restore Commands (Reference)
Create read-only copies of file systems.
fssnap
Back up all file systems for systems on a network from a backup server.
Solstice Backup software
Solstice Backup 6.1 Administration Guide
Back up and restore an NIS+ master server.
nisbackup and nisrestore
System Administration Guide: Naming and Directory Services (NIS+)
Copy, list, and retrieve files on a tape or diskette.
tar, cpio, or pax
Copy the master disk to a clone disk.
dd
Restore complete file systems or individual files from removable media to a working directory.
ufsrestore
Why You Should Back Up File Systems
Backing up files is one of the most crucial system administration functions. You should perform regularly scheduled backups to prevent loss of data due to the following types of problems:
Planning Which UFS File Systems to Back Up
You should back up all file systems that are critical to users, including file systems that change frequently. The following tables provide general guidelines on the file systems to back up for stand-alone systems and servers.
Table 23–2 File Systems to Back Up for Stand-alone Systems
File System to Back Up
Description
Back Up Interval
root (/) – slice 0
This file system contains the kernel and possibly the /var directory. The /var directory contains temporary files, logging files, or status files, and possibly contains frequently updated system accounting and mail files.
At regular intervals such as weekly or daily
/usr – slice 6, /opt
The /usr and /opt file systems contain software and executables. The /opt directory is either part of root (/) or is its own file system.
Occasionally
/export/home – slice 7
This file system can contain the directories and subdirectories of all users on the stand-alone system.
More often than root (/) or /usr, perhaps as often as once a day, depending on your site's needs
/export, /var, or other file systems
The /export file system can contain the kernel and executables for diskless clients. The /var directory contains temporary files, logging files, or status files.
As your site requires
Table 23–3 UFS File Systems to Back Up for Servers
Description
Back Up Interval
root (/) – slice 0
This file system contains the kernel and executables.
Once a day to once a month depending on your site's needs.
If you frequently add and remove users and systems on the network, you have to change configuration files in this file system. In this case, you should do a full backup of the root (/) file system at intervals between once a week and once a month.
If your site keeps user mail in the /var/mail directory on a mail server, which client systems then mount, you might want to back up root (/) daily. Or, backup the /var directory, if it is a separate file system.
/export – slice 3
This file system can contain the kernel and executables for diskless clients.
Once a day to once a month, depending on your site's needs.
Because the information in this file system is similar to the server's root directory in slice 0, the file system does not change frequently. You need to back up this file system only occasionally, unless your site delivers mail to client systems. Then, you should back up /export more frequently.
These file systems are fairly static unless software is added or removed frequently.
This file system can contains the home directories of all the users on the system. The files in this file system are volatile.
Once a day to once a week.
Choosing the Type of Backup
You can perform full or incremental backups by using the ufsdump command. You can create a temporary image of a file system by using the fssnap command. The following table lists the differences between these types of backup procedures.
Table 23–4 Differences Between Types of Backups
Backup Type
Result
Advantages
Disadvantages
Full
Copies a complete file system or directory
All data is in one place
Requires large numbers of backup tapes that take a long time to write. Takes longer to retrieve individual files because the drive has to move sequentially to the point on the tape where the file is located. You might have to search multiple tapes.
Snapshot
Creates a temporary image of a file system
System can be in multiuser mode
System performance might degrade while the snapshot is created.
Incremental
Copies only those files in the specified file system that have changed since a previous backup
Easier to retrieve small changes in file systems
Finding which incremental tape contains a file can take time. You might have to go back to the last full backup.
Choosing a Tape Device
The following table shows typical tape devices that are used for storing file systems during the backup process. The storage capacity depends on the type of drive and the data being written to the tape. For more information on tape devices, see Chapter 29, Managing Tape Drives (Tasks).
Table 23–5 Typical Media for Backing Up File Systems
Backup Media
Storage Capacity
1/2-inch reel tape
140 MB (6250 bpi)
2.5-GB 1/4-inch cartridge (QIC) tape
2.5 GB
DDS3 4-mm cartridge tape (DAT)
12–24 GB
14-GB 8-mm cartridge tape
14 GB
DLT 7000 1/2-inch cartridge tape
35–70 GB
High-Level View of Backing Up and Restoring UFS File Systems (Task Map)
Use this task map to identify all the tasks for backing up and restoring file systems. Each task points to a series of additional tasks, such as determining the type of backup to perform.
Task
Description
For Instructions
1. Identify the file systems to back up.
Identify which file systems need to be backed up on a daily, weekly, or monthly basis.
2. Determine the type of backup.
Determine the type of backup you need for the file systems at your site.
3. Create the backup.
Use one of the following methods:
If you want to have full and incremental backups of your file systems, use the ufsdump command.
If you want to create a snapshot of a file system while it is active and mounted, consider using the fssnap command.
If you just want to have full backups of your personal home directory or smaller, less-important file systems, use the tar, cpio, or pax commands.
4. (Optional) Restore a file system.
Select the restoration method that is based on the command used to back up the files or file system:
Restore a file system backup that was created with the ufsdump command.
Restore a file system that was created with the tar, cpio, or pax command.
5. (Optional) Restore the root (/) or /usr file system.
Restoring the root (/) or /usr file system is more complicated than restoring a noncritical file system. You need to boot from a local Solaris DVD or from the network while these file systems are being restored.
How to Restore a UFS root (/) and /usr File System
Considerations for Scheduling Backups
A backup schedule is the schedule that you establish to run the ufsdump command. This section identifies considerations to think about when you create a backup schedule. This section also includes sample backup schedules.
The backup schedule that you create depends on the following:
How Often Should You Do Backups?
If you do not need to minimize time requirements and the number of media that is used for backups, you can do full backups every day. However, this backup method is not realistic for most sites, so incremental backups are used most often. In this case, you should back up your site enough to so that you can restore files from the last four weeks. This schedule requires at least four sets of tapes, one set for each week. You would then reuse the tapes each month. In addition, you should archive the monthly backups for at least a year. Then, keep yearly backups for a number of years.
Backup Interval Terms and Definitions
The following table describes backup interval terms and definitions.
Term
Definition
Snapshot
Creates a temporary image of a file system.
Full backup
Copies a complete file system or directory.
Incremental backup
Copies only those files in the specified file system that have changed since a previous backup. Incremental backup types include the following:
  • Daily, cumulative – Copies a day's worth of file changes on Monday. Then, overwrites Monday's backup with file changes from Tuesday, Wednesday, and so on.
  • Daily, incremental – Copies a day's worth of file changes so that you have distinct tapes of Monday's changes, Tuesday's changes, and so on.
  • Weekly cumulative – Copies the files that have changed during the week and includes the previous week's file changes.
  • Weekly incremental – Copies the files that have changed during the week since the previous weekly backup.
Guidelines for Scheduling Backups
The following table provides guidelines for scheduling backups. For additional backup schedule considerations, see Considerations for Scheduling Backups.
Table 23–6 Guidelines for Backup Schedules
File Restoration Need
Backup Interval
Comments
To restore different versions of files (for example, file systems that are used for word processing)
Do daily incremental backups every working day.
Do not reuse the same tape for daily incremental backups.
This schedule saves all files modified that day, as well as those files still on disk that were modified since the last backup of a lower level. However, with this schedule, you should use a different tape each day because you might otherwise be unable to restore the needed version of the file.
For example, a file that changed on Tuesday, and again on Thursday, goes onto Friday's lower-level backup appearing as it did Thursday night, not Tuesday night. If a user needs the Tuesday version, you cannot restore it unless you have a Tuesday backup tape (or a Wednesday backup tape). Similarly, a file that is present on Tuesday and Wednesday, but removed on Thursday, does not appear on the Friday lower-level backup.
To quickly restore a complete file system
Do lower-level backups more frequently.
To back up a number of file systems on the same server
Consider staggering the schedule for different file systems.
This way you're not doing all level 0 backups on the same day.
To minimize the number of tapes used
Increase the level of incremental backups that are done across the week.
Only changes from day to day are saved on each daily tape.
Increase the level of backups that are done at the end of the week. Put each day's and week's incremental backups onto the same tape.
Only changes from week to week (rather than the entire month) are saved on the weekly tapes.
To do so, use the no rewind option of the ufsdump command, such as specifying /dev/rmt/0n.
Using Dump Levels to Create Incremental Backups
The dump level you specify in the ufsdump command (0–9) determines which files are backed up. Dump level 0 creates a full backup. Levels 1–9 are used to schedule incremental backups, but have no defined meanings. Levels 1–9 are just a range of numbers that are used to schedule cumulative or discrete backups. The only meaning levels 1–9 have is in relationship to each other, as a higher or lower number. A lower dump number always restarts a full or a cumulative backup. The following examples show the flexibility of the incremental dump procedure using levels 1–9.
Example—Dump Levels for Daily, Cumulative Backups
Doing daily, cumulative incremental backups is the most commonly used backup schedule and is recommended for most situations. The following example shows a schedule that uses a level 9 dump Monday through Thursday, and a level 5 dump on Friday restarts process.
Figure 23–1 Incremental Backup: Daily Cumulative
Illustration shows increasing amount of tape needed for
a daily cumulative backup that starts on Monday and finishes on Friday.
In the preceding example, you could have used other numbers in the 1–9 range to produce the same results. The key is using the same number Monday through Thursday, with any lower number on Friday. For example, you could have specified levels 4, 4, 4, 4, 2 or 7, 7, 7, 7, 5.
Example—Dump Levels for Daily, Incremental Backups
The following example shows a schedule where you capture only a day's work on different tapes. This type of backup is referred to as a daily, incremental backup. In this case, sequential dump level numbers are used during the week (3, 4, 5, 6) with a lower number (2) on Friday. The lower number on Friday restarts the processing.
Figure 23–2 Incremental Backup: Daily Incremental
Illustration shows approximately equal amount of tape
needed for a daily discrete backup that starts on Monday and finishes on Friday.
In the preceding example, you could have used the sequence 6, 7, 8, 9 followed by 2, or 5, 6, 7, 8 followed by 3. Remember, the numbers themselves have no defined meaning. You attribute meaning by ordering them in a specified sequence, as described in the examples.
Sample Backup Schedules
This section provides sample backup schedules. All schedules assume that you begin with a full backup (dump level 0), and that you use the -u option to record each backup in the /etc/dumpdates file.
Example—Daily Cumulative, Weekly Cumulative Backup Schedule
Table 23–7 shows the most commonly used incremental backup schedule. This schedule is recommended for most situations. With this schedule, the following occurs:
Table 23–7 Daily Cumulative/Weekly Cumulative Backup Schedule
Floating
Mon
Tues
Wed
Thurs
Fri
1st of Month
Week 1
Week 2
Week 3
Week 4
The following table shows how the contents of the tapes can change across two weeks with the daily cumulative, weekly cumulative schedule. Each letter represents a different file.
Table 23–8 Contents of Tapes for Daily Cumulative/Weekly Cumulative Backup Schedule
Mon
Tues
Wed
Thurs
Fri
Week 1
a b
a b c
a b c d
a b c d e
a b c d e f
Week 2
g h
g h i
g h i j
a b c d e f g h i j k
Tape Requirements for the Daily Cumulative, Weekly Cumulative Schedule
With this schedule, you need six tapes if you want to reuse daily tapes. However, you need nine tapes if you want to use four different daily tapes:
If you need to restore a complete file system, you need the following tapes:
Example—Daily Cumulative, Weekly Incremental Backup Schedule
The following table shows a schedule where each weekday tape accumulates all files that changed since the beginning of the week, or the initial level 0 backup for the first week. In addition, each Friday's tape contains all the files that changed that week.
Table 23–9 Daily Cumulative, Weekly Incremental Backup Schedule
Floating
Mon
Tues
Wed
Thurs
Fri
1st of Month
Week 1
Week 2
9
Week 3
Week 4
The following table shows how the contents of the tapes can change across two weeks with the daily cumulative, weekly incremental backup schedule. Each letter represents a different file.
Table 23–10 Contents of Tapes for Daily Cumulative, Weekly Incremental Backup Schedule
Mon
Tues
Wed
Thurs
Fri
Week 1
a b
a b c
a b c d
a b c d e
a b c d e f
Week 2
g h
g h i
g h i j
g h i j k
Tape Requirements for the Daily Cumulative, Weekly Incremental Backup Schedule
Example—Daily Incremental, Weekly Cumulative Backup Schedule
The following table shows a schedule where each weekday tape contains only the files that changed since the previous day. In addition, each Friday's tape contains all files changed since the initial level 0 backup at the beginning of the month.
Table 23–11 Daily Incremental, Weekly Cumulative Backup Schedule
Floating
Mon
Tues
Wed
Thurs
Fri
1st of Month
Week 1
Week 2
Week 3
Week 4
The following table shows how the contents of the tapes can change across two weeks with the daily incremental, weekly cumulative schedule. Each letter represents a different file.
Table 23–12 Contents of Tapes for Daily Incremental, Weekly Cumulative Backup Schedule
Mon
Tues
Wed
Thurs
Fri
Week 1
a b
c d
e f g
hi
a b c d e f g h i
Week 2
j k l
n o
p q
a b c d e f g h i j k l m n o p q r s
Tape Requirements for Daily Incremental, Weekly Cumulative Schedule
With this schedule, you need at least 9 tapes if you want to reuse daily tapes, which is not recommended. Preferably, you need 21 tapes if you save weekly tapes for a month: one tape for the level 0, 4 tapes for the Fridays, and 4 or 16 daily tapes.
If you need to restore the complete file system, you need the following tapes:
Example—Monthly Backup Schedule for a Server
The following table shows an example backup strategy for a heavily used file server on a small network where users are doing file-intensive work, such as program development or document production. This example assumes that the backup period begins on a Sunday and consists of four seven-day weeks.
Table 23–13 Example of Monthly Backup Schedule for a Server
Directory
Date
Dump Level
Tape Name
root (/)
1st Sunday
n tapes
/usr
1st Sunday
n tapes
/export
1st Sunday
n tapes
/export/home
1st Sunday
n tapes
1st Monday
1st Tuesday
1st Wednesday
1st Thursday
1st Friday
1st Saturday
root (/)
2nd Sunday
n tapes
/usr
2nd Sunday
n tapes
/export
2nd Sunday
n tapes
/export/home
2nd Sunday
n tapes
2nd Monday
G
2nd Tuesday
H
2nd Wednesday
I
2nd Thursday
J
2nd Friday
2nd Saturday
L
root (/)
3rd Sunday
n tapes
/usr
3rd Sunday
n tapes
/export
3rd Sunday
n tapes
/export/home
3rd Sunday
n tapes
3rd Monday
3rd Tuesday
N
3rd Wednesday
O
3rd Thursday
3rd Friday
3rd Saturday
root (/)
4th Sunday
n tapes
/usr
4th Sunday
n tapes
/export
4th Sunday
n tapes
/export/home
4th Sunday
n tapes
4th Monday
4th Tuesday
4th Wednesday
4th Thursday
4th Friday
4th Saturday
With this schedule, you use 4n tapes, the number of tapes needed for 4 full backups of the root (/), /usr, /export, and /export/home file systems. Also, you need 24 additional tapes for the incremental backups of the /export/home file systems. This schedule assumes that each incremental backup uses one tape and that you save the tapes for a month.
Here's how this schedule works:
  1. On each Sunday, do a full backup (level 0) of the root (/), /usr, /export, and /export/home file systems. Save the level 0 tapes for at least three months.
  2. On the first Monday of the month, use tape A to do a level 9 backup of the /export/home file system. The ufsdump command copies all files changed since the previous lower-level backup. In this case, the previous lower-level backup is the level 0 backup that you did on Sunday.
  3. On the first Tuesday of the month, use tape B to do a level 9 backup of the /export/home file system. Again, the ufsdump command copies all files changed since the last lower-level backup, which is Sunday's level 0 backup.
  4. On the first Wednesday of the month, use tape C to do a level 5 backup of the /export/home file system. The ufsdump command copies all files that changed since Sunday.
  5. Do the Thursday and Friday level 9 backups of the /export/home file system on tapes D and E. The ufsdump command copies all files that changed since the last lower-level backup, which is Wednesday's level 5 backup.
  6. On the first Saturday of the month, use tape F to do a level 5 backup of /export/home. The ufsdump command copies all files changed since the previous lower-level backup (in this case, the level 0 backup you did on Sunday). Store tapes A–F until the first Monday of the next four-week period, when you use them again.
  7. Repeat steps 1–6 for the next three weeks, using tapes G–L and 4n tapes for the level 0 backup on Sunday, and so on.
  8. For each four-week period, repeat steps 1–7, using a new set of tapes for the level 0 backups and reusing tapes A–X for the incremental backups. The level 0 tapes could be reused after three months.
    This schedule lets you save files in their various states for a month. This plan requires many tapes, but ensures that you have a library of tapes to draw upon. To reduce the number of tapes, you could reuse Tapes A–F each week.
