The following task map describes the tasks for managing PCI or PCIe devices on your system.
Task |
Description |
For Instructions |
Display PCI slot configuration information. |
Display the status of PCI hot-pluggable devices and slots on the system. | |
Remove a PCI adapter card. |
Unconfigure the card, disconnect power from the slot, and remove the card from the system. | |
Add a PCI adapter card. |
Insert the adapter card into a hot-pluggable slot, connect power to the slot, and configure the card. | |
Troubleshoot PCI configuration problems. |
Identify error message and possible solutions to resolve PCI configuration problems. |
