The following table describes the slices that might be found on a system that runs the Oracle Solaris OS.
On x86 systems:
Disks are divided into fdisk partitions. An fdisk partition is a section of the disk that is reserved for a particular operating system, such as the Oracle Solaris OS.
The Oracle Solaris OS places ten slices, numbered 0-9, on a Solaris fdisk partition.
Slice |
File System |
Usually Found on Client or Server Systems? |
Comments |
0 |
root (/) |
Both |
Holds files and directories that make up the OS. EFI – You cannot boot from a disk with an EFI label. |
1 |
swap |
Both |
Provides virtual memory, or swap space. |
2 |
Both |
VTOC – Refers to the entire disk, by convention. The size of this slice should not be changed. EFI – Optional slice to be defined based on your site's needs. |
3 |
/export, for example |
Both |
Optional slice that can be defined based on your site's needs. Can be used on a server to hold alternative versions of operating systems that are required by client systems. |
4 |
Both |
5 |
/opt, for example |
Both |
Optional slice to be defined based on your site's needs. Can be used to hold application software added to a system. If a slice is not allocated for the /opt file system during installation, the /opt directory is put in slice 0. |
6 |
/usr |
Both |
Holds OS commands (also known as executables). This slice also holds documentation, system programs (init and syslogd, for example), and library routines. |
7 |
/home or /export/home |
Both |
Holds files that are created by users. |
8 |
N/A |
N/A |
VTOC – Contains GRUB boot information. EFI – A reserved slice created by default. This area is similar to the VTOC's alternate cylinders. Do not modify or delete this slice. |
9 (x86 only) |
Both |
EFI – Not applicable. VTOC – Provides an area that is reserved for alternate disk blocks. Slice 9 is known as the alternate sector slice. |
On a disk with a VTOC label, do not modify slice or use slice 2 to store a file system. Products, such as Solaris Volume Manager, Solaris Live Upgrade, and installgrub, do not work correctly if slice 2 is modified in any way.
