System Administration Guide: Devices and File Systems
Chapter 15 The format Utility (Reference)
This chapter describes the format utility's menus and commands.
This is a list of the reference information in this chapter.
For a overview of when to use the format utility, see format Utility.
Recommendations and Requirements for Using the format Utility
You must be superuser or have assumed an equivalent role to use the format utility. Otherwise, the following error message is displayed when you try to use the format utility:
$ format
Searching for disks...done
No permission (or no disks found)!
Keep the following guidelines in mind when you use the format utility and want to preserve the existing data:
format Menu and Command Descriptions
The format main menu appears similar to the following:
FORMAT MENU:
        disk       - select a disk
        type       - select (define) a disk type
        partition  - select (define) a partition table
        current    - describe the current disk
        format     - format and analyze the disk
        fdisk      - run the fdisk program (x86 only)
        repair     - repair a defective sector
        label      - write label to the disk
        analyze    - surface analysis
        defect     - defect list management
        backup     - search for backup labels
        verify     - read and display labels
        save       - save new disk/partition definitions
        inquiry    - show vendor, product and revision
        volname    - set 8-character volume name
        !<cmd>     - execute <cmd>, then return
        quit
format>
The following table describes the main menu items for the format utility.
Table 15–1 The Main Menu Item Descriptions for the format Utility
Menu Item
Command or Menu?
Description
disk
Command
Lists all of the system's drives. Also lets you choose the disk you want to use in subsequent operations. This disk is referred to as the current disk.
type
Command
Identifies the manufacturer and model of the current disk. Also displays a list of known drive types. Choose the Auto configure option for all SCSI-2 disk drives.
partition
Menu
Creates and modifies slices. For more information, see partition Menu.
current
Command
Displays the following information about the current disk:
  • Device name and device type
  • Number of cylinders, alternate cylinders, heads and sectors
  • Physical device name
format
Command
Formats the current disk by using one of these sources of information in this order:
  1. Information that is found in the format.dat file
  2. Information from the automatic configuration process
  3. Information that you type at the prompt if no format.dat entry exists
This command does not apply to IDE disks. IDE disks are preformatted by the manufacturer.
fdisk
Menu
x86 platform only: Runs the fdisk program to create a Solaris fdisk partition.
The fdisk command cannot be used on disks with an EFI label that are greater than 1 terabyte in size.
repair
Command
Repairs a specific block on the current disk.
label
Command
Writes a new label to the current disk.
analyze
Menu
Runs read, write, and compare tests. For more information, see analyze Menu.
defect
Menu
Retrieves and displays defect lists. For more information, see defect Menu. This feature does not apply to IDE disks. IDE disks manage defects automatically.
backup
Command
VTOC – Searches for backup labels.
EFI – Not supported.
verify
Command
  • Partition table
save
Command
VTOC – Saves new disk and partition information.
EFI – Not applicable.
inquiry
Command
SCSI disks only – Displays the vendor, product name, and revision level of the current drive.
volname
Command
Labels the disk with a new eight-character volume name that you specify.
quit
Command
Exits the format menu.
partition Menu
The partition menu appears similar to the following:
format> partition
PARTITION MENU:
        0      - change `0' partition
        1      - change `1' partition
        2      - change `2' partition
        3      - change `3' partition
        4      - change `4' partition
        5      - change `5' partition
        6      - change `6' partition
        7      - change `7' partition
        select - select a predefined table
        modify - modify a predefined partition table
        name   - name the current table
        print  - display the current table
        label  - write partition map and label to the disk
        quit
partition>
The following table describes the partition menu items.
Table 15–2 Descriptions for partition Menu Items
Subcommand
Description
change `n' partition
Enables you to specify the following information for the new partition:
  • Identification tag
  • Permission flags
  • Starting cylinder
  • Size
select
Enables you to choose a predefined partition table.
modify
Enables you to change all the slices in the partition table. This command is preferred over the individual change `x' partition commands.
name
Enables you to specify a name for the current partition table.
print
Displays the current partition table.
label
Writes the partition map and the label to the current disk.
quit
Exits the partition menu.
x86: fdisk Menu
The fdisk menu appears on x86 based systems only and appears similar to the following.
format> fdisk
             Total disk size is 14169 cylinders
             Cylinder size is 2510 (512 byte) blocks
                                               Cylinders
      Partition   Status    Type          Start   End   Length    %
          1       Active    x86 Boot          1     9       9      0
          2                 Solaris2         10  14168    14159    100
SELECT ONE OF THE FOLLOWING:
  1. Create a partition
  2. Specify the active partition
  3. Delete a partition
  4. Change between Solaris and Solaris2 Partition IDs
  5. Exit (update disk configuration and exit)
  6. Cancel (exit without updating disk configuration)
  Enter Selection:
The following table describes the fdisk menu items.
Table 15–3 x86: Descriptions for fdisk Menu Items
Menu Item
Description
Create a partition
Creates an fdisk partition. You must create a separate partition for each OS such as Solaris or DOS. There is a maximum of four partitions per disk. You are prompted for the size of the fdisk partition as a percentage of the disk.
Enables you to specify the partition to be used for booting. This menu item identifies where the first stage boot program looks for the second stage boot program.
Delete a partition
Deletes a previously created partition. This command destroys all the data in the partition.
Changes partition IDs from 130 (0x82) to 191 (0xbf) and back again.
Writes a new version of the partition table and exits the fdisk menu.
Exits the fdisk menu without modifying the partition table.
analyze Menu
The analyze menu appears similar to the following.
format> analyze
ANALYZE MENU:
    read     - read only test   (doesn't harm SunOS)
    refresh  - read then write  (doesn't harm data)
    test     - pattern testing  (doesn't harm data)
    write    - write then read      (corrupts data)
    compare  - write, read, compare (corrupts data)
    purge    - write, read, write   (corrupts data)
    verify   - write entire disk, then verify (corrupts data)
    print    - display data buffer
    setup    - set analysis parameters
    config   - show analysis parameters
    quit
analyze>
The following table describes the analyze menu items.
Table 15–4 Descriptions for analyze Menu Items
Subcommand
Description
read
Reads each sector on the current disk. Repairs defective blocks as a default.
refresh
Reads then writes data on the current disk without harming the data. Repairs defective blocks as a default.
test
Writes a set of patterns to the disk without harming the data. Repairs defective blocks as a default.
write
Writes a set of patterns to the disk then reads back the data on the disk. Destroys existing data on the disk. Repairs defective blocks as a default.
compare
Writes a set of patterns to the disk, reads back the data, and then compares it to the data in the write buffer. Destroys existing data on the disk. Repairs defective blocks as a default.
purge
Removes all data from the disk so that the data cannot be retrieved by any means. Data is removed by writing three distinct patterns over the entire disk (or a section of the disk). If the verification passes, a hex-bit pattern is written over the entire disk (or a section of the disk).
verify
In the first pass, writes unique data to each block on the entire disk. In the next pass, reads and verifies the data. Destroys existing data on the disk. Repairs defective blocks as a default.
print
Displays the data in the read/write buffer.
setup
Enables you to specify the following analysis parameters:
Analyze entire disk? yes
Starting block number: depends on drive
Ending block number: depends on drive
Loop continuously? no
Number of passes: 2
	Repair defective blocks? yes
Stop after first error? no
Use random bit patterns? no
Number of blocks per transfer: 126 (0/n/nn)
Verify media after formatting? yes
Enable extended messages? no
Restore defect list? yes
Restore disk label? yes
config
Displays the current analysis parameters.
quit
Exits the analyze menu.
defect Menu
The defect menu appears similar to the following:
format> defect
DEFECT MENU:
        primary  - extract manufacturer's defect list
        grown    - extract manufacturer's and repaired defects lists
        both     - extract both primary and grown defects lists
        print    - display working list
        dump     - dump working list to file
        quit
defect>
The following table describes the defect menu items.
Table 15–5 The defect Menu Item Descriptions
Subcommand
Description
primary
Reads the manufacturer's defect list from the disk drive and updates the in-memory defect list.
grown
Reads the grown defect list and then updates the in-memory defect list. Grown defects are defects that have been detected during analysis.
both
Reads both the manufacturer's defect list and the grown defect list. Then, updates the in-memory defect list.
print
Displays the in-memory defect list.
dump
Saves the in-memory defect list to a file.
quit
Exits the defect menu.
format.dat File
The format.dat file that is shipped with the Oracle Solaris OS supports many standard disks. If your disk drive is not listed in the format.dat file, you can do the following:
Adding an entry to the format.dat file can save time if the disk drive will be used throughout your site. To use the format.dat file on other systems, copy the file to each system that will use the specific disk drive that you added to the format.dat file.
You might need to modify the /etc/format.dat file for your system if you have one of the following:
Note –
Do not alter default entries in the /etc/format.dat file. If you want to alter the default entries, copy the entry, give the entry a different name, and make the appropriate changes to avoid confusion.
The /etc/format.dat is not applicable for disks with EFI labels.
Contents of the format.dat File
The format.dat contains disk drive information that is used by the format utility. Three items are defined in the format.dat file:
Syntax of the format.dat File
The following syntax rules apply to the /etc/format.dat file:
Keywords in the format.dat File
The format.dat file contains disk definitions that are read by the format utility when it is started. Each definition starts with one of the following keywords: disk_type or partition. These keywords are described in the following table.
Table 15–6 Keyword Descriptions for the format.dat File
Keyword
Description
disk_type
Defines the controller and disk model. Each disk_type definition contains information that concerns the physical geometry of the disk. The default data file contains definitions for the controllers and disks that the Oracle Solaris OS supports.
You need to add a new disk_type definition only if you have an unsupported disk. You can add as many disk_type definitions to the data file as you want.
partition
Defines a partition table for a specific disk type. The partition table contains the partition information, plus a name that lets you refer to it in the format utility. The default format.dat file contains default partition definitions for several kinds of disk drives. Add a partition definition if you recreated partitions on any of the disks on your system. Add as many partition definitions to the data file as you need.
Disk Type (format.dat)
The disk_type keyword in the format.dat file defines the controller and disk model. Each disk_type definition contains information about the physical geometry of the disk. The default format.dat file contains definitions for the controllers and disks that the Oracle Solaris OS supports. You need to add a new disk_type only if you have an unsupported disk. You can add as many disk_type definitions to the data file as you want.
The keyword itself is assigned the name of the disk type. This name appears in the disk's label, and is used to identify the disk type whenever the format utility is run. Enclose the name in double quotation marks to preserve any white space in the name. The following table describes the identifiers that must also be assigned values in all disk_type definitions.
Table 15–7 Required disk_type Identifiers (format.dat)
Identifier
Description
ctlr
Identifies the controller type for the disk type. Currently, the supported values are SCSI and ATA.
ncyl
Specifies the number of data cylinders in the disk type. This determines how many logical disk cylinders the system will be allowed to access.
acyl
Specifies the number of alternate cylinders in the disk type. These cylinders are used by the format utility to store information such as the defect list for the drive. You should always reserve at least two cylinders for alternates.
pcyl
Specifies the number of physical cylinders in the disk type. This number is used to calculate the boundaries of the disk media. This number is usually equal to ncyl plus acyl.
nhead
Specifies the number of heads in the disk type. This number is used to calculate the boundaries of the disk media.
nsect
Specifies the number of data sectors per track in the disk type. This number is used to calculate the boundaries of the disk media. Note that this number includes only the data sectors. Any spares are not reflected in the number of data sections per track.
rpm
Specifies the rotations per minute of the disk type. This information is put in the label and later used by the file system to calculate the optimal placement of file data.
Other identifiers might be necessary, depending on the controller. The following table describes the identifiers that are required for SCSI controllers.
Table 15–8 Required disk_type Identifiers for SCSI Controllers format.dat
Identifier
Description
fmt_time
Specifies a number that indicates how long it takes to format a given drive. See the controller manual for more information.
cache
Specifies a number that controls the operation of the on-board cache while the format utility is operating. See the controller manual for more information.
trks_zone
Specifies a number that identifies how many tracks that exist per defect zone, to be used in alternate sector mapping. See the controller manual for more information.
asect
Specifies a number that identifies how many sectors are available for alternate mapping within a given defect zone. See the controller manual for more information.
Example 15–1 Required disk_type Identifiers for SCSI Controllers (format.dat)
The following are examples of disk_type definitions:
disk_type = "SUN1.3G" \
        : ctlr = SCSI : fmt_time = 4 \
        : trks_zone = 17 : asect = 6 : atrks = 17 \
        : ncyl = 1965 : acyl = 2 : pcyl = 3500 : nhead = 17 : nsect = 80 \
        : rpm = 5400 : bpt = 44823
disk_type = "SUN2.1G" \
        : ncyl = 2733 : acyl = 2 : pcyl = 3500 : nhead = 19 : nsect = 80 \
disk_type = "SUN2.9G" \
        : ncyl = 2734 : acyl = 2 : pcyl = 3500 : nhead = 21 : nsect = 99 \
        : rpm = 5400
Partition Tables (format.dat)
A partition table in the format.dat file defines a slice table for a specific disk type.
The partition keyword in the format.dat file is assigned the name of the partition table. Enclose the name in double quotation marks to preserve any white space in the name. The following table describes the identifiers that must be assigned values in all partition tables.
Table 15–9 Required Identifiers for Partition Tables (format.dat)
Identifier
Description
disk
The name of the disk_type that this partition table is defined for. This name must appear exactly as it does in the disk_type definition.
ctlr
The disk controller type that this partition table can be attached to. Currently, the supported values are ATA for ATA controllers and SCSI for SCSI controllers. The controller type that is specified here must also be defined for the disk_type that you specified in the disk_type definition.
The other identifiers in a slice definition describe the actual partition information. The identifiers are the numbers 0 through 7. These identifiers are optional. Any partition that is not explicitly assigned is set to 0 length. The value of each of these identifiers is a pair of numbers separated by a comma. The first number is the starting cylinder for the partition. The second is the number of sectors in the slice.
Example 15–2 Required Identifiers for Partition Tables (format.dat)
The following are some examples of slice definitions:
partition = "SUN1.3G" \
        : disk = "SUN1.3G" : ctlr = SCSI \
        : 0 = 0, 34000 : 1 = 25, 133280 : 2 = 0, 2672400 : 6 = 123, 2505120
partition = "SUN2.1G" \
        : disk = "SUN2.1G" : ctlr = SCSI \
        : 0 = 0, 62320 : 1 = 41, 197600 : 2 = 0, 4154160 : 6 = 171, 3894240
partition = "SUN2.9G" \
        : disk = "SUN2.9G" : ctlr = SCSI \
        : 0 = 0, 195426 : 1 = 94, 390852 : 2 = 0, 5683986 : 6 = 282, 5097708
Specifying an Alternate Data File for the format Utility
The format utility determines the location of an alternate file by the following methods in this order:
  1. If a file name is given with the format -x option, that file is always used as the data file.
  2. If the -x option is not specified, then the format utility searches the current directory for a file named format.dat. If the file exists, it is used as the data file.
  3. If neither of these methods yields a data file, the format utility uses the /etc/format.dat file as the data file. This file is shipped with the Oracle Solaris OS and should always be present.
Rules for Input to format Commands
When you use the format utility, you need to provide various kinds of information. This section describes the rules for this information. For information on using format's help facility when you specify data, see Getting Help on the format Utility.
Specifying Numbers to format Commands
Several places in the format utility require number as input. You must either specify the appropriate data or select a number from a list of choices. In either case, the help facility causes format to display the upper and lower limits of the number expected. Simply enter the appropriate number. The number is assumed to be in decimal format unless a base is explicitly specified as part of the number (for example, 0x for hexadecimal).
The following are examples of integer input:
Enter number of passes [2]: 34
Enter number of passes [34] Oxf
Specifying Block Numbers to format Commands
Whenever you are required to specify a disk block number, there are two ways to do so:
You can specify the information as an integer that represents the logical block number. You can specify the number in any base, but the default is decimal. The maximum operator (a dollar sign, $) can also be used here so that format utility can select the appropriate value. Logical block format is used by the SunOS disk drivers in error messages.
The other way to specify a block number is by using cylinder/head/sector format. In this method, you must specify explicitly the three logical components of the block number: the cylinder, head, and sector values. These values are still logical. However, they allow you to define regions of the disk that are related to the layout of the media.
If any of the cylinder/head/sector numbers are not specified, the value is assumed to be zero. You can also use the maximum operator in place of any of the numbers. Then, the format utility will select the appropriate value. The following are some examples of cylinder, head, and sector values:
Enter defective block number: 34/2/3
Enter defective block number: 23/1/
Enter defective block number: 457//
Enter defective block number: 12345
Enter defective block number: Oxabcd
Enter defective block number: 334/$/2
Enter defective block number: 892//$
The format utility always displays block numbers in both formats. Also, the help facility shows you the upper and lower limits of the block number expected, in both formats.
Specifying format Command Names
Command names are needed as input whenever the format utility displays a menu prompt. You can abbreviate the command names, as long as what you type is sufficient to uniquely identify the command desired.
For example, use p to access the partition menu from the format menu. Then, type p to display the current slice table.
format> p
PARTITION MENU:
        quit
partition> p
Specifying Disk Names to format Commands
At certain points in the format utility, you must name something. In these cases, you are free to specify any string you want for the name. If the name has white space in it, the entire name must be enclosed in double quotation marks ("). Otherwise, only the first word of the name is used.
For example, if you want to identify a specific partition table for a disk, you can use the name subcommand that is available from the partition menu:
partition> name
Enter table name (remember quotes): "new disk3"
The format utility provides a help facility that you can use whenever the format utility is expecting input. You can request help about what input is expected by typing a question mark (?). The format utility displays a brief description of what type of input is needed.
If you type a ? at a menu prompt, a list of available commands is displayed.
The man pages associated with the format utility include the following:
