System Administration Guide: Devices and File Systems
Collecting CacheFS Statistics
Collecting CacheFS statistics enables you to do the following:
These statistics help you determine the trade-off between your cache size and the desired performance of the cache.
The following table describes the CacheFS statistics commands.
Man Page
Specifies the location of the log file. This command also displays where the statistics are currently being logged, and enables you to stop logging.
Interprets the log file to give a recommended cache size.
Displays statistical information about a specific CacheFS file system or all CacheFS file systems. The information provided in the command output is taken directly from the cache.
Note –
You can issue the CacheFS statistics commands from any directory. You must be superuser to issue the cachefswssize command.
The CacheFS statistics begin accumulating when you create the log file. When the work session is over, stop the logging by using the cachefslog -h command, as described in How to Stop CacheFS Logging.
Before using the CacheFS statistics commands, you must do the following:
Note –
The following procedures are presented in a recommended order. This order is not required.
ProcedureHow to Set Up CacheFS Logging
  1. Set up logging.
    $ cachefslog -f log-file-path /mount-point
    Sets up logging.
    Specifies the location of the log file. The log file is a standard file you create with an editor, such as vi.
    Designates the mount point (CacheFS file system) for which statistics are being collected.
  2. Verify that you correctly set up the log file.
    $ cachefslog /mount-point
Example 19–13 Setting Up CacheFS Logging
The following example shows how to set up the /var/tmp/samlog log file to collect statistics about the /home/sam directory.
$ cachefslog -f /var/tmp/samlog /home/sam
  /var/tmp/samlog: /home/sam
ProcedureHow to Locate the CacheFS Log File
  1. Display where CacheFS statistics are being logged.
    where /mount-point specifies the CacheFS file system for which you want to view the statistics.
    You can also use the cachefslog command with no options to locate a log file for a particular mount point.
Example 19–14 Locating the CacheFS Log File
The following example shows what you would see if a log file has been set up. The location of the log file is /var/tmp/stufflog.
$ cachefslog /home/stuff
	 /var/tmp/stufflog: /home/stuff
The following example shows that no log file has been set up for the specified file system.
$ cachefslog /home/zap
	not logged: /home/zap
Use the cachefslog -h option to stop logging.
$ cachefslog -h /mount-point
The following example shows how to stop logging on /home/stuff.
$ cachefslog -h /home/stuff
not logged: /home/stuff
If you get a system response other than the response specified here, you did not successfully stop logging. Determine if you are using the correct log file name and mount point.
ProcedureHow to View the Working Set (Cache) Size
You might want to check if you need to increase the size of the cache. Or, you might want to determine the ideal cache size based on your activity since you last used the cachefslog command for a particular mount point.
  1. Become superuser on the client system.
  2. View the current cache size and highest logged cache size.
    # cachefswssize log-file-path
    For more information, see cachefswssize(1M).
Example 19–15 Viewing the Working Set (Cache) Size
In the following example, the end size is the size of the cache at the time you issued the cachefswssize command. The high water size is the largest size of the cache during the timeframe in which logging occurred.
# cachefswssize /var/tmp/samlog
	       end size:  10688k
	high water size:  10704k
	       end size:   1736k
	high water size:   1736k
	       end size:    128k
	high water size:    128k
	       end size:   1472k
	high water size:   1472k
	       end size:   7168k
	high water size:   7168k
	       end size:   4688k
	high water size:   5000k
	       end size:   4992k
	high water size:   4992k
    total for cache
	   initial size: 110960k
	       end size:  30872k
	high water size:  30872k
Viewing CacheFS Statistics
The following table explains the terminology that is displayed in the statistics output for CacheFS file systems.
Table 19–2 CacheFS Statistics Terminology
Output Term
cache hit rate
The rate of cache hits compared to cache misses, followed by the actual number of hits and misses. A cache hit occurs when the user wants to perform an operation on a file or files, and the file or files are actually in the cache. A cache miss occurs when the file is not in the cache. The load on the server is the sum of cache misses, consistency checks, and modifications (modifies).
consistency checks
The number of consistency checks performed, followed by the number that passed, and the number that failed.
The number of modify operations. For example, writes or creates.
ProcedureHow to View CacheFS Statistics
View the statistics with the cachefsstat command. You can view the statistics at any time. For example, you do not have to set up logging in order to view the statistics.
  1. View CacheFS statistics.
    $ cachefsstat /mount-point
    If you do not specify the mount point, statistics for all mounted CacheFS file systems will be displayed.
Example 19–16 Viewing CacheFS Statistics
This example shows how to view statistics on the cached file system, /home/sam.
$ cachefsstat /home/sam
	    cache hit rate: 73% (1234 hits, 450 misses)
	consistency checks: 700 (650 pass, 50 fail)
	          modifies: 321
garbage collection:  0
