System Administration Guide: Devices and File Systems
ProcedureHow to Create a UFS File System
Before You Begin
Ensure that you have met the following prerequisites:
For information on finding disks and disk slice numbers, see Chapter 11, Administering Disks (Tasks).
For information on formatting disks and dividing disks into slices, see Chapter 10, Managing Disks (Overview).
  1. You must be superuser or assume an equivalent role.
  2. Create the UFS file system.
    # newfs [-N] [-b size] [-i bytes] /dev/rdsk/device-name
    -N
    Displays what parameters the newfs command would pass to the mkfs command without actually creating the file system. This option is a good way to test the newfs command.
    -b size
    Specifies the block size for the file system, either 4096 or 8192 bytes per block. The default is 8192.
    -i bytes
    Specifies the number of bytes per inode. The default varies depending on the disk size. For more information, see newfs(1M).
    device-name
    Specifies the disk device name on which to create the new file system.
    The system asks for confirmation.
    Caution – Caution –
    Be sure you have specified the correct device name for the slice before performing this step. If you specify the wrong slice, you will erase its contents when the new file system is created. This error might cause the system to panic.
  3. To verify the creation of the UFS file system, check the new file system.
    # fsck /dev/rdsk/device-name
    where device-name argument specifies the name of the disk device that contains the new file system.
    The fsck command checks the consistency of the new file system, reports any problems, and prompts you before it repairs the problems. For more information on the fsck command, see Chapter 21, Checking UFS File System Consistency (Tasks) or fsck(1M).
Example 17–1 Creating a UFS File System
The following example shows how to create a UFS file system on /dev/rdsk/c0t1d0s7.
# newfs /dev/rdsk/c0t1d0s7
/dev/rdsk/c0t1d0s7:  725760 sectors in 720 cylinders of 14 tracks, 72 sectors
        354.4MB in 45 cyl groups (16 c/g, 7.88MB/g, 3776 i/g)
super-block backups (for fsck -F ufs -o b=#) at:
 32, 16240, 32448, 48656, 64864, 81072, 97280, 113488, 129696, 145904, 162112,
 178320, 194528, 210736, 226944, 243152, 258080, 274288, 290496, 306704,
 322912, 339120, 355328, 371536, 387744, 403952, 420160, 436368, 452576,
 468784, 484992, 501200, 516128, 532336, 548544, 564752, 580960, 597168,
 613376, 629584, 645792, 662000, 678208, 694416, 710624,
 fsck /dev/rdsk/c0t1d0s7
After You Create a UFS File System ...
To mount the UFS file system and make it available, go to Chapter 18, Mounting and Unmounting File Systems (Tasks).
