System Administration Guide: Devices and File Systems
Chapter 18 Mounting and Unmounting File Systems (Tasks)
This chapter describes how to mount and unmount file systems in the Oracle Solaris OS.
This is a list of the step-by-step instructions in this chapter.
Overview of Mounting File Systems
After you create a file system, you need to make it available to the system so that you can use it. You make a file system available by mounting it, which attaches the file system to the system directory tree at the specified mount point. The root (/) file system is always mounted.
The following table provides guidelines on mounting file systems based on how you use them.
Mount Type Needed
Suggested Mount Method
Local or remote file systems that need to be mounted infrequently
The mount command that you type manually from the command line.
Local UFS file systems that need to be mounted frequently. Local ZFS file systems are automatically mounted by an SMF service.
The /etc/vfstab file, which mounts the file system automatically when the system is booted in multi user state.
Remote UFS file systems, such as home directories, that need to be mounted frequently
  • The /etc/vfstab file, which automatically mounts the file system when the system is booted in multiuser state.
  • autofs, which automatically mounts the file system when you access it or unmounts the file system when you change to another directory.
You can mount removable media that contains a file system by inserting the media into the drive and running the volcheck command, if necessary. For more information on mounting removable media, see Chapter 1, Managing Removable Media (Overview).
Commands for Mounting and Unmounting UFS File Systems
The following table lists the commands in the /usr/sbin directory that you use to mount and unmount UFS file systems.
Table 18–1 Commands for Mounting and Unmounting UFS File Systems
Command
Description
Man Page
mount
Mounts file systems and remote resources.
mount(1M)
mountall
Mounts all file systems that are specified in the /etc/vfstab file. The mountall command runs automatically when the system enters multiuser mode.
mountall(1M)
umount
Unmounts file systems and remote resources.
mount(1M)
umountall
Unmounts all file systems that are specified in the /etc/vfstab file.
mountall(1M)
For more information about mounting and unmounting ZFS file systems, see the Oracle Solaris ZFS Administration Guide.
Keep the following key points in mind when using the mount and mountall commands:
Commonly Used UFS Mount Options
The following table describes the commonly used options that you can specify with the mount -o option. If you specify multiple options, separate them with commas (no spaces). For example, -o ro,nosuid.
For a complete list of mount options for each file system type, refer to the specific mount man page (for example, mount_ufs(1M)). For information about mounting ZFS file systems, see zfs(1M).
Table 18–2 Commonly Used -o Mount Options
mount Option
File System
Description
bg | fg
NFS
If the first mount attempt fails, retries another mount in the background (bg) or in the foreground (fg). This option is safe for non critical vfstab entries. The default is fg.
hard | soft
NFS
Specifies the procedure if the server does not respond. The soft option indicates that an error is returned. The hard option indicates that the retry request is continued until the server responds. The default is hard.
intr | nointr
NFS
Specifies whether keyboard interrupts are delivered to a hung process while waiting for a response on a hard-mounted file system. The default is intr (interrupts allowed).
largefiles | nolargefiles
UFS
Enables you to create files larger than 2 GB. The largefiles option means that a file system mounted with this option might contain files larger than 2 GB. If the nolargefiles option is specified, the file system cannot be mounted on a system that is running an older Solaris version. The default is largefiles.
logging | nologging
UFS
Enables or disables logging for the file system. UFS logging is the process of storing transactions (changes that comprise a complete UFS operation) into a log before the transactions are applied to the UFS file system. Logging helps prevent UFS file systems from becoming inconsistent, which means fsck can be bypassed. Bypassing fsck reduces the time to reboot a system if it crashes, or after a system is shut down uncleanly.
The log is allocated from free blocks on the file system, and is sized at about 1 MB per 1 GB of file system space, up to 256 MB. The log size might be larger, up to a maximum of 512 MB, if the file system has a large number of cylinder groups.
atime | noatime
UFS
Suppresses access time updates on files, except when they coincide with updates to the time of the last file status change or the time of the last file modification. For more information, see stat(2). This option reduces disk activity on file systems where access times are unimportant (for example, a Usenet news spool). The default is normal access time (atime) recording.
remount
All
Changes the mount options associated with an already-mounted file system. This option can generally be used with any option except ro. However, what can be changed with this option depends on the file system type.
retry=n
NFS
Retries the mount operation when it fails. n is the number of times to retry.
ro | rw
CacheFS, NFS, PCFS, UFS, HSFS
Specifies read/write (rw) or read-only (ro). If you do not specify this option, the default is rw. The default option for HSFS is ro.
suid | nosuid
CacheFS, HSFS, NFS, UFS
Allows or disallows setuid execution. The default is to allow setuid execution.
Field Descriptions for the /etc/vfstab File
An entry in the /etc/vfstab file has seven fields, which are described in the following table.
Table 18–3 Field Descriptions for the /etc/vfstab File
Field Name
Description
device to mount
This field identifies one of the following:
  • The block device name for a local UFS file system (for example, /dev/dsk/c0t0d0s0).
  • The resource name for a remote file system (for example, myserver:/export/home). For more information about NFS, see System Administration Guide: IP Services.
  • The block device name of the slice on which to swap (for example, /dev/dsk/c0t3d0s1).
  • A directory for a virtual file system.
device to fsck
The raw (character) device name that corresponds to the UFS file system identified by the device to mount field (for example, /dev/rdsk/c0t0d0s0). This field determines the raw interface that is used by the fsck command. Use a dash (-) when there is no applicable device, such as for a read-only file system or a remote file system.
mount point
Identifies where to mount the file system (for example, /usr).
FS type
Identifies the type of file system.
fsck pass
The pass number used by the fsck command to decide whether to check a UFS file system. When the field contains a dash (-), the file system is not checked. Currently, the fsck pass value in the /etc/vfstab file is ignored during the boot process.
When the field contains a zero, UFS file systems are not checked. When the field contains a value greater than zero, the UFS file system is always checked.
All UFS file systems with a value of 1 in this field are checked one at a time in the order they appear in the vfstab file. When the fsck command is run on multiple UFS file systems that have fsck pass values greater than 1 and the preen option (-o p) is used, the fsck command automatically checks the file systems on different disks in parallel to maximize efficiency. Otherwise, the value of the pass number does not have any effect.
mount at boot
Set to yes or no for whether the file system should be automatically mounted by the mountall command when the system is booted. Note that this field has nothing to do with autofs. The root (/), /usr and /var file systems are not mounted from the vfstab file initially. This field should always be set to no for these file systems and for virtual file systems such as /proc and /dev/fd.
mount options
A list of comma-separated options (with no spaces) that are used for mounting the file system. Use a dash (-) to indicate no options. For a list of commonly used mount options, see Table 18–2.
Note –
You must have an entry in each field in the /etc/vfstab file. If there is no value for a field, be sure to specify a dash (-). Otherwise, the system might not boot successfully. Similarly, white space should not be used as a field value.
The following sections describe how to mount a UFS file system by adding an entry in the /etc/vfstab file or by using the mount command from the command line.
How to Determine Which File Systems Are Mounted
You can determine which file systems are already mounted by using the mount command.
$ mount [ -v ]
The -v displays the list of mounted file systems in verbose mode.
Example 18–1 Determining Which File Systems Are Mounted
This example shows how to use the mount command to display information about the file systems that are currently mounted.
$ mount
/ on /dev/dsk/c0t0d0s0 read/write/setuid/intr/largefiles/xattr/onerror=...
/devices on /devices read/write/setuid/dev=46c0000 on Thu Sep  ...
/system/contract on ctfs read/write/setuid/devices/dev=43c0001 ...
/usr on /dev/dsk/c0t0d0s6 read/write/setuid/intr/largefiles/xattr/...
/proc on /proc read/write/setuid/dev=4700000 on Thu Sep  2 ...
/etc/mnttab on mnttab read/write/setuid/dev=47c0000 on Thu Sep  2 ...
/etc/svc/volatile on swap read/write/setuid/devices/xattr/dev=4480001 ...
/system/object on objfs read/write/setuid/devices/dev=44c0001 ...
/dev/fd on fd read/write/setuid/dev=4800000 on Thu Sep  2 ...
/var/run on swap read/write/setuid/xattr/dev=1 on Thu Sep  2 ...
/tmp on swap read/write/setuid/xattr/dev=2 on Thu Sep  2 ...
/stuff on /dev/dsk/c0t0d0s5 read/write/setuid/intr/largefiles/xattr...
/export/home on /dev/dsk/c0t0d0s7 read/write/setuid/intr/largefiles/...
/home/rimmer on pluto:/export/home/rimmer remote/read/write/setuid/xattr/...
This example shows how to use the zfs mount command to display information about ZFS file systems that are currently mounted.
$ zfs mount
rpool/ROOT/zfs509BE            /
rpool/export                    /export
rpool/export/home               /export/home
rpool                           /rpool
ProcedureHow to Add an Entry to the /etc/vfstab File
Use this procedure to mount non-ZFS file systems at boot time unless legacy mount behavior is needed for some ZFS file systems. For more information about mounting ZFS file systems, see Oracle Solaris ZFS Administration Guide.
  1. Become superuser or assume an equivalent role.
  2. Create a mount point for the file system to be mounted, if necessary.
    # mkdir /mount-point
    There must be a mount point on the local system to mount a file system. A mount point is a directory to which the mounted file system is attached.
  3. Edit the /etc/vfstab file and add an entry. Ensure that you do the following:
    1. Separate each field with white space (a space or a tab).
    2. Specify a dash (-) if a field has no contents.
    3. Save the changes.
    For detailed information about the /etc/vfstab field entries, see Table 18–3.
    Note –
    Because the root (/) file system is mounted read-only by the kernel during the boot process, only the remount option (and options that can be used in conjunction with remount) affect the root (/) entry in the /etc/vfstab file.
Example 18–2 Adding an Entry to the /etc/vfstab File
The following example shows how to mount the disk slice /dev/dsk/c0t3d0s7 as a UFS file system to the mount point /files1. The raw character device /dev/rdsk/c0t3d0s7 is specified as the device to fsck. The fsck pass value of 2 means that the file system will be checked, but not sequentially.
#device           device             mount    FS       fsck   mount    mount
#to mount         to fsck            point    type     pass   at boot  options
/dev/dsk/c0t3d0s7 /dev/rdsk/c0t3d0s7 /files1  ufs      2      yes       -
The following example shows how to mount the /export/man directory from the system pluto as an NFS file system on mount point /usr/man. Neither a device to fsck nor a fsck pass is specified because it's an NFS file system. In this example, mount options are ro (read-only) and soft.
pluto:/export/man   -                /usr/man nfs      -      yes       ro,soft
The following example shows how to mount the root (/) file system on a loopback mount point, /tmp/newroot. LOFS file systems must always be mounted after the file systems that are in the LOFS file system.
/                   -                /tmp/newroot lofs -      yes       -
ProcedureHow to Mount a File System (/etc/vfstab File)
  2. Mount a file system listed in the /etc/vfstab file.
    # mount /mount-point
    where /mount-point specifies an entry in the mount point or device to mount field in the /etc/vfstab file. It is usually easier to specify the mount point.
Example 18–3 Mounting a File System (/etc/vfstab File)
The following example shows how to mount the /usr/dist file system that is listed in the /etc/vfstab file.
# mount /usr/dist
Example 18–4 Mounting All File Systems (/etc/vfstab File)
The following example shows the messages that are displayed when you use the mountall command and the file systems are already mounted.
# mountall
/dev/rdsk/c0t0d0s7 already mounted
mount: /tmp already mounted
mount: /dev/dsk/c0t0d0s7 is already mounted, /export/home is busy,
        or the allowable number of mount points has been exceeded
When using the mountall command, all the file systems with a device to fsck entry are checked and fixed, if necessary, before they are mounted.
The following example shows how to mount all the local systems that are listed in the /etc/vfstab file.
# mountall -l
# mount
The following example shows how to mount all available ZFS file systems.
# zfs mount -a
The following example shows how to mount all the remote file systems that are listed in the /etc/vfstab file.
# mountall -r
# mount
ProcedureHow to Mount a UFS File System (mount Command)
  3. Mount the UFS file system.
    # mount [-o mount-options] /dev/dsk/device-name /mount-point
    -o mount-options
    Specifies mount options that you can use to mount a UFS file system. For a list of options, see Table 18–2 or mount_ufs(1M).
    Specifies the disk device name for the slice that contains the file system (for example, /dev/dsk/c0t3d0s7). To view slice information for a disk, see How to Display Disk Slice Information.
    /mount-point
    Specifies the directory on which to mount the file system.
Example 18–5 Mounting a UFS File System (mount Command)
The following example shows how to mount /dev/dsk/c0t3d0s7 on the /files1 directory.
# mount /dev/dsk/c0t3d0s7 /files1
ProcedureHow to Mount a UFS File System Without Large Files (mount Command)
When you mount a file system, the largefiles option is selected by default. This option enables you to create files larger than 2 GB. If a file system contains large files, you cannot remount the file system with the nolargefiles option or mount it on a system that is running older Solaris versions, until you remove any large files and run the fsck command to reset the state to nolargefiles.
This procedure assumes that the file system is in the /etc/vfstab file.
  3. Ensure that no large files exist in the file system.
    # cd /mount-point
    # find . -xdev -size +20000000 -exec ls -l {} \;
    where /mount-point identifies the mount point of the file system you want to check for large files.
  4. Remove or move any large files in this file system to another file system, if necessary.
  5. Unmount the file system.
    # umount /mount-point
  6. Reset the file system state.
    # fsck /mount-point
  7. Remount the file system with the nolargefiles option.
    # mount -o nolargefiles /mount-point
Example 18–6 Mounting a File System Without Large Files (mount Command)
The following example shows how to check the /datab file system and remount it with the nolargefiles option.
# cd /datab
# umount /datab
# fsck /datab
# mount -o nolargefiles /datab
ProcedureHow to Mount an NFS File System (mount Command)
  3. Ensure that the resource (file or directory) is available from a server.
    To mount an NFS file system, the resource must be made available on the server by using the share command. For information on how to share resources, see About the NFS Service in System Administration Guide: Network Services.
  4. Mount the NFS file system.
    # mount -F nfs [-o mount-options] server:/directory /mount-point
    -o mount-options
    Specifies mount options that you can use to mount an NFS file system. See Table 18–2 for the list of commonly used mount options or mount_nfs(1M) for a complete list of options.
    server:/directory
    Specifies the server's host name that contains the shared resource, and the path to the file or directory to mount.
    /mount-point
Example 18–7 Mounting an NFS File System (mount Command)
The following example shows how to mount the /export/packages directory on /mnt from the server pluto.
# mount -F nfs pluto:/export/packages /mnt
Procedurex86: How to Mount a PCFS (DOS) File System From a Hard Disk (mount Command)
Use the following procedure to mount a PCFS (DOS) file system from a hard disk.
  3. Mount the PCFS file system.
    # mount -F pcfs [-o rw | ro] /dev/dsk/device-name:logical-drive /mount-point
    -o rw | ro
    Specifies that you can mount a PCFS file system read/write (rw) or read-only (ro). If you do not specify this option, the default is rw.
    Specifies the device name of the whole disk (for example, /dev/dsk/c0t0d0p0).
    logical-drive
    Specifies either the DOS logical drive letter (c through z) or a drive number (1 through 24). Drive c is equivalent to drive 1 and represents the primary DOS slice on the drive. All other letters or numbers represent DOS logical drives within the extended DOS slice.
    /mount-point
    Note that the device-name and logical-drive must be separated by a colon.
Example 18–8 x86: Mounting a PCFS (DOS) File System From a Hard Disk (mount Command)
The following example shows how to mount the logical drive in the primary DOS slice on the /pcfs/c directory.
# mount -F pcfs /dev/dsk/c0t0d0p0:c /pcfs/c
The following example shows how to mount read-only the first logical drive in the extended DOS slice on the /mnt directory.
# mount -F pcfs -o ro /dev/dsk/c0t0d0p0:2 /mnt
The unmounting of a UFS file system removes it from the file system mount point, and deletes the entry from the /etc/mnttab file. Some file system administration tasks cannot be performed on mounted file systems. You should unmount a UFS file system when the following occurs:
In an emergency situation, you can use the umount -f option to forcibly unmount a busy file system. This practice is not recommended under normal circumstances because the unmounting of a file system with open files could cause a loss of data. This option is only available for UFS and NFS file systems.
Prerequisites for Unmounting File Systems
The prerequisites for unmounting file systems include the following:
How to Verify a File System is Unmounted
To verify that you unmounted a file system or a number of file systems, examine the output from the mount command.
$ mount | grep unmounted-file-system
ProcedureHow to Stop All Processes Accessing a File System
  2. List all the processes that are accessing the file system so that you know which processes you are going to stop.
    # fuser -c [ -u ] /mount-point
    -c
    Reports on files that are mount points for file systems and any files within those mounted file systems.
    -u
    Displays the user login name for each process ID.
    /mount-point
    Specifies the name of the file system for which you want to stop processes.
  3. Stop all processes that are accessing the file system.
    # fuser -c -k /mount-point
    A SIGKILL is sent to each process that is using the file system.
    Note –
    You should not stop a user's processes without first warning the user.
  4. Verify that no processes are accessing the file system.
    # fuser -c /mount-point
Example 18–9 Stopping All Processes Accessing a File System
The following example shows how to stop process 4006c that is using the /export/home file system.
# fuser -c /export/home
/export/home:     4006c
# fuser -c -k /export/home
/export/home:     4006c
/export/home:
ProcedureHow to Unmount a File System
Use the following procedure to unmount a file system, except for the root (/), /usr, or /var file systems.
Note –
The root (/), /usr, and /var file systems can be unmounted only during a shutdown. The system needs these file systems to function.
  1. Ensure that you have met the prerequisites listed in Prerequisites for Unmounting File Systems.
  2. Unmount the file system.
    where /mount-point is the name of the file system that you want to unmount. This can be one of the following:
    • The directory name where the file system is mounted
    • The device name path of the file system
    • The resource for an NFS file system
    • The loopback directory for an LOFS file system
Example 18–10 Unmounting a File System
The following example shows how to unmount a local UFS home file system.
# umount /export/home
The following example shows how to unmount the UFS file system on slice 7.
# umount /dev/dsk/c0t0d0s7
The following example shows how to forcibly unmount the UFS /export file system.
# umount -f /export
The following example shows how to unmount all UFS file systems in the /etc/vfstab file, except for the root (/), /proc, /var, and /usr file systems.
# umountall
The following example shows to unmount all ZFS file systems.
# zfs umount -a
All file systems are unmounted, except for those file systems that are busy.
