System Administration Guide: Devices and File Systems
ProcedureHow to Erase CD-RW Media
You have to erase existing CD-RW data before the CD can be rewritten.
  1. Erase the entire media or just the last session on the CD by selecting one of the following:
    • Erase the last session only.
      $ cdrw -d cdrom0 -b session
      Erasing just the last session with the -b session option is faster than erasing the entire media with the -b all option. You can use the -b session option even if you used the cdrw command to create a data or audio CD in just one session.
    • Erase the entire media.
      $ cdrw -d cdrom0 -b all
