Solaris Dynamic Tracing Guide
void printa(aggregation)
void printa(string format, aggregation)
The printa() action enables you to display and format aggregations. See Chapter 9, Aggregations for more detail on aggregations. If a format is not provided, printa() only traces a directive to the DTrace consumer that the specified aggregation should be processed and displayed using the default format. If a format is provided, the aggregation will be formatted as specified. See Chapter 12, Output Formatting for a more detailed description of the printa() format string.
printa() only traces a directive that the aggregation should be processed by the DTrace consumer. It does not process the aggregation in the kernel. Therefore, the time between the tracing of the printa() directive and the actual processing of the directive depends on the factors that affect buffer processing. These factors include the aggregation rate, the buffering policy and, if the buffering policy is switching, the rate at which buffers are switched. See Chapter 9, Aggregations and Chapter 11, Buffers and Buffering for detailed descriptions of these factors.
