The Workspace Menu is the menu that appears when you click mouse button 3 on the background of the workspace. Regular users can customize the menu, and add items to the menu.
The following conditions apply when a user is allowed to work at multiple labels:
The user must have a home directory in the global zone.
To save the customizations, processes in the global zone must be able to write to the user's home directory at the correct label. The zone path to a user home directory that is writable by global zone processes is similar to the following:
/zone/zone-name/home/username |
The user must use the Customize Menu and Add Item to Menu options in a regular user workspace. The user can create a different customization for each label.
When the user assumes a role, changes to the Workspace Menu persist.
Changes that are made to the Workspace Menu are stored in the user's home directory at the current label. The customized menu file is .dt/wsmenu.
The user's rights profile must enable the user to run the desired action.
Any action that is added to the Workspace Menu must be handled by one of the user's rights profiles. Otherwise, the action fails when invoked and an error message is displayed.
For example, anyone with the Run action can double-click the icon for any executable and run it, even if the action or any commands that the action invokes are not in one of the account's rights profiles. By default, roles are not assigned the Run action. Therefore, any menu item that requires the Run action fails when executed by a role.
