Java Desktop System Release 3 Installation Guide
Before You Begin a Network Installation
Before you begin installing the Java Desktop System from the network, you need to have the following:
Boot Disk Locations
The boot disks are available from the following locations:
The boot disk subfolders are named as follows:
Use the following command to make other disks, if required:
dd if=/export/suseimage/boot/bootdisk of=/dev/fd0
Note –
You may need additional disks depending on your hardware, for example, SCSI controllers and USB drives.
