Java Desktop System Release 3 Installation Guide
Setting up a MS Windows System as an Installation Server
To set up a MS windows system as an installation server, perform the following steps:
  1. Go to the directory dosutils/install.
  2. Copy the instorder file to \suseinstall\yast.
  3. Replace the UserAccount, PASSword, and IP-Number variables with the respective values of your MS windows machine.
  4. Copy the order file to \suseinstall\yast.
  5. Run the install.bat script to create the structure and to prompt you for the CDs.
    Note –
    During the installation process you need only to specify the share suseinstall.
