Java Desktop System Release 3 Installation Guide
System Requirements
To complete the installation you require the following:
Table 1–1 System Requirements for the Java Desktop System Release 3 on Linux
Recommended
Minimum
Processor
 Pentium III, compatible PC 600 MHz
Pentium II, compatible PC 266 MHz
Hard Disk
6 GB
4 GB
RAM
384 MB
256 MB
Display Resolution
1024 x 768
800 x 600
Note –
Java Desktop System Release 3 supports users upgrading from Java Desktop System 2003 and Java Desktop System Release 2 systems with 128 MB of RAM. However, we strongly recommend that you upgrade your systems to 256 MB of RAM for performance reasons.
The PC must be set up to boot directly from the installation CD. The process of booting from the CD varies between systems. Consult the documentation provided with your PC if you have any difficulty with booting directly from the installation CD.
You need to provide the following information for your PC:
Allow at least 45 minutes for the installation. If your system appears to hang during the installation procedure, do not interrupt the installation process.
