Java Desktop System Release 3 Installation Guide
Dual Booting
You can create a dual boot on your PC during the installation of the Java Desktop System.
Most factory-installed Windows installations take up all the space on your hard disk, leaving no space for installing Linux. Therefore, the Java Desktop System installation configurator (Configurator) creates a partition where you can install the Linux operating system.
Every operating system has a specific type of file system, and other operating systems often cannot read from these file systems. The Configurator can read the FAT32 file system that is used by Windows.
Since Linux needs to have specific partitions and Windows does not have the ability to resize partitions, the Configurator checks your hard disk and proposes an appropriate partition setup.
Note –
You can also create a specific custom partition in the event that your existing Windows supports an NTFS file system. The Configurator does not enable you to resize your partition in this case and proposes to replace your existing partition. However, you can use third-party partition applications to resize your partitions if you want to retain your Windows partition.
If you intend to create a dual boot system, consider the following:
