Java Desktop System Release 3 Troubleshooting Guide
2.6.2 Error Message After Upgrade
Platform
  • Linux
Problem
Change Request Number: 6261477
The following error message is displayed when you login after you upgrade from Java Desktop System Release 2 to Java Desktop System Release 3:
You have a keyboard remapping file (.Xmodmap) in your home directory whose contents will now be ignored. You can use the keyboard preferences to restore them
Solution
  • Remove the .Xmodmap file in your $HOME directory.
  • If necessary, use your keyboard preferences to restore customized settings.
