Java Desktop System Release 3 Troubleshooting Guide
2.6.3 Login Error Message
  • Solaris OS for SPARC systems
  • Solaris OS for x86 systems
You might encounter the following error message when you log in to a Java Desktop System session:
Could not look up internet address for hostname. This will prevent GNOME from operating correctly. It may be possible to correct the problem by adding hostname to the file /etc/hosts
Ensure that your hostname is set up correctly. Perform the following steps:
  1. Set the hostname in the /etc/hosts file as follows: localhost loghost hostname localhost.localdomain
  2. Ensure that your hostname is listed in the /etc/nodename file. This file must also contain the following line: localhost loghost hostname localhost.localdomain
  3. Add the following entry to the /etc/inet/ipnodes file: hostname
In each case, hostname is your system name.
