Java Desktop System Release 3 Troubleshooting Guide
3.1 All Locales
3.1.1 PDF Printing Does Not Work
Platform
  • Solaris OS for SPARC systems
  • Solaris OS for x86 systems
  • Linux
Problem
Change Request Number: 6239307 and 6218079
Affects the following locales:
  • All locales
PDF Document Viewer cannot print localized PDF files.
Solution
Use Acrobat Reader on Linux and Solaris OS for SPARC systems. Use StarOffice to create PDF files on Solaris OS for x86 systems.
3.1.2 Modifier Keys Do Not Function Correctly
Platform
Problem
Change Request Number: 4996542
The Alt key and Shift key might not function as modifier keys when you use the Internet/Intranet input method.
You might not be able to make a selection in a text using the Shift+arrow key combination. Latin characters might be inserted instead.
Solution
Use a different input method, for example Default. To switch input methods, right-click on an object and select Input method.
