Java Desktop System Email and Calendar User Guide
Advanced Message Composition Features
You can cut, copy, and paste the content of messages that you compose. You can search for text and replace that text. You can check the spelling of your message. You can also save drafts of your messages.
You can use the following formats for your messages:
Finding and Replacing Text in a Message
When you compose a message, you can search for text in the message. You can also replace the text you search for.
To Find Text in a Message
To search for text in a message, perform the following steps:
  1. Choose Edit -> Find. Type the text to search for in the text box of the Find dialog.
    Alternatively, you can use a regular expression to search for text. A regular expression is a way to specify a text pattern to search for. For example, the regular expression t*e finds the text the, time, table, and so on.
    To use a regular expression to search for text, choose Edit -> Find Regular Expression. Type the regular expression to search for in the text box of the Find Regular Expression dialog.
  2. Select the Backward option to begin the search from the end of the message, or from the cursor location, and proceed towards the start of the message.
  3. Select the Case sensitive option to find occurrences only of the text that match the case of the text that you type in the dialog.
  4. Click on the Find button. If the text is found in the message, the first match is highlighted in the message.
  5. To find the next occurrence of the text, choose Edit -> Find Again.
To Replace Text in a Message
To search for text, and replace the text with alternative text, perform the following steps:
  1. Choose Edit -> Replace.
  2. Type the text to search for in the Replace text box.
  3. Type the text to use to replace the text that you find, in the With text box.
  4. Select the Search backward option to begin the search from the end of the message, or from the cursor location, and proceed towards the start of the message.
  5. Select the Case sensitive option to find occurrences only of the text that match the case of the text that you type in the dialog.
  6. Click on the Find and Replace button. If the text is found in the message, a Replace confirmation dialog is displayed. Use the buttons on the Replace confirmation dialog to replace the text in the message, as described in the following table.
    Button
    Function
    Replace all
    Replaces all occurrences of the search text with the replacement text.
    Next
    Skips the current occurrence of the search text, and finds the next occurrence.
    Close
    Closes the Replace confirmation dialog, and does not replace any text.
    Replace
    Replaces the current occurrences of the search text with the replacement text, and finds the next occurrence.
To Create a Message in HTML Format
To create a message in HTML format, choose File -> New -> Mail Message. In the Compose a message window, choose Format -> HTML so that the HTML menu item is selected.
To Apply Font Formatting to Messages
To apply font formatting to messages in HTML format, perform the following steps:
  1. Select the text that you want to format.
  2. To format the selected text, perform one or more of the following actions:
    Format
    Action
    Plain text
    Choose Format -> Style -> Plain text.
    Bold
    Choose Format -> Style -> Bold.
    Italic
    Choose Format -> Style -> Italic.
    Underline
    Choose Format -> Style -> Underline.
    Strikethrough
    Choose Format -> Style -> Strikeout.
    Font size
    Choose Format -> Font Size, then select the font size from the submenu. You must specify the size of the text in relation to the size of normal text. The options that you can select include +2, +1, -1, -2, and so on.
    Font color
    Choose Format -> Text. Click on the arrow in the Color drop-down list. Select a color from the color table.
    Alternatively, to specify a custom color, click on the Custom Color color selector button. Use the color wheel or the spin boxes to select the color. Click OK to add the new color to the color table.
    Click OK to apply the font color formatting, and close the dialog.
    You can also use the format toolbar to format text. To use the format toolbar to format text, click on the button that represents the format that you want to apply.
To Apply Paragraph Formatting to Messages
To apply paragraph formatting to messages in HTML format, perform the following steps:
  1. Click in the paragraph that you want to format.
  2. To format the selected paragraph, perform one or more of the following actions:
    Format
    Action
    Style
    Choose Format -> Paragraph. Select the style that you want from the Style drop-down list. The styles that you can select include the following:
    • Normal
    • Preformatted text
    • Heading styles
    • Address style
    • Bulleted lists
    • Ordered lists
    Click OK to apply the style and close the Properties: Paragraph dialog.
    Alignment
    Choose Format -> Paragraph. Select the alignment from the Left, Center, or Right options.
    Click OK to apply the alignment and close the Properties: Paragraph dialog.
    Indentation
    To increase the indent in the paragraph, choose Format -> Increase Indent. To decrease the indent in the paragraph, choose Format -> Decrease Indent.
    You can also use the format toolbar to format paragraphs. To use the format toolbar to format paragraphs, click on the button that represents the format that you want to apply.
To Apply Page Formatting to Messages
To apply page formatting to messages in HTML format, perform the following steps:
  1. Choose Format -> Page.
  2. Select a template for the page from the Template drop-down list in the Properties: Page dialog.
  3. Type a name for the page in the Document Title text box.
  4. Enter the name of the image file that you want to use for the message background in the Background Image drop-down combination box.
    Alternatively, click Browse to display a Background Image dialog. Use the dialog to specify the image file that you want to use.
  5. To select a color for the text, links, or message background, click on the arrow in the appropriate drop-down list in the Colors group. Select a color from the color table.
    Alternatively, to specify a custom color, click on the Custom Color color selector button. Use the color wheel or the sliders to select the color. Click OK to add the new color to the color table. Click OK to apply the color and close the dialog.
  6. Click OK to apply the formatting to the message and close the Properties: Page dialog.
To Insert an Emoticon Into a Message
To insert an emoticon into a message, choose Insert -> Smiley, then select the emoticon that you require.
Customizing the Message Composition Window
You can customize which message elements are displayed in a message composition window. The following table describes how to display message elements in a message composition window:
To Display ...
Choose ...
Attachments pane
View -> Show attachments
From field
View -> From Field
Reply-To field
View -> Reply-To Field
Cc field
View -> Cc Field
Bcc field
View -> Bcc Field
