Java Desktop System Email and Calendar User Guide
To Add a Virtual Folder
Perform the following steps:
  1. Choose Tools -> Virtual Folder Editor.
  2. Click Add on the vFolders dialog.
  3. Enter the details for the virtual folder in the Add Rule dialog. The following table describes the elements on the Add Rule dialog:
    Element
    Description
    Rule name
    Type a name for the virtual folder in the text box.
    Add
    Click this button to add more criteria to the virtual folder.
    Execute actions
    Use the drop-down list to specify whether a message must meet all, or any, of the criteria, to be added to the virtual folder. You can select the following options:
    • if all criteria are met: Select this option to specify that the message must meet all of the criteria in the search.
    • if any criteria are met: Select this option to specify that the message must meet at least one of the criteria in the search.
    First drop-down list
    Select the message component to use for the criterion. For example, if you want the virtual folder to search the text in the body of the message, select Message Body.
    Second drop-down list
    Select the relationship between the message component and the search text. For example, if you want the virtual folder to search for messages whose body includes the search text, select contains from the second drop-down list.
    Text box
    Type the search text. This text is not case sensitive.
    Remove
    To remove a criterion, click on the Remove button beside the criterion.
    vFolder Sources
    From the drop-down list, select the folders from which you want to create the virtual folder. Select one of the following options:
    • specific folders only: Select this option to create the virtual folder from folders that you specify.
      To specify a folder, click Add. Select the folder that you want to add from the Select Folder dialog, then click OK.
      To remove a folder, select the folder, then click Remove.
    • with all local folders: Select this option to create the virtual folder from all folders on your local system.
    • with all active remote folders: Select this option to create the virtual folder from all folders on the mail server to which you are connected.
    • with all local and active remote folders: Select this option to create the virtual folder from the following:
      • All folders on your local system.
      • All folders on the mail server to which you are connected.
  4. When you have entered the details for the virtual folder, click OK on the Add Rule dialog.
  5. Click OK to close the vFolders dialog.
