Java Desktop System Email and Calendar User Guide
To Display Access Permissions for a Folder
Perform the following steps:
  1. Right-click on the folder, then choose Permissions from the popup menu to display the Folder permissions dialog.
  2. The access control rules are listed in the Permissions tabbed section. The following table describes the elements in the Permissions tabbed section:
    Element
    Description
    Name
    Name of the person or group with access permissions.
    Availability
    Select this option to allow the named person to see that the folder exists.
    Invite
    Select this option to allow the named person to invite you to meetings.
    Read
    Select this option to allow the named person to read the contents of the folder.
    Delete
    Select this option to allow the named person to delete the contents of the folder.
    Modify
    Select this option to allow the named person to modify the contents of the folder.
    Add
    Click Add to add a new entry to the permissions list.
    Edit
    Click Edit to edit an entry in the permissions list.
    Remove
    Click Remove to remove an entry from the permissions list.
    OK
    Click OK to save your changes and close the Folder permissions dialog.
    Cancel
    Click Cancel to close the Folder permissions dialog without saving your changes.
  3. To display the list of owners for the folder, click on the Owners tab. The following table describes the elements in the Owners tabbed section:
    Element
    Description
    User
    Displays the list of owners of the folder.
    Add
    Click Add to add a user to the User list.
    Remove
    Click Remove to remove the selected user from the User list.
    OK
    Cancel
