Solaris 10 11/06 Installation Guide: Network-Based Installations
x86: Overview of Booting and Installing Over the Network With PXE
This section provides an overview of the Preboot Execution Environment (PXE).
x86: What is PXE?
PXE network boot is a “direct” network boot. No boot media is required on the client system. With PXE, you can install an x86 based client over the network by using DHCP.
PXE network boot is available only for devices that implement the Intel Preboot Execution Environment specification. To determine if your system supports PXE network boot, see your hardware manufacturer's documentation.
x86: Guidelines for Booting With PXE
To boot over the network by using PXE, you need the following systems.
When you are preparing to use PXE to install a client over the network, consider the following issues.
