Solaris 10 11/06 Installation Guide: Solaris Live Upgrade and Upgrade Planning
Deleting an Inactive Boot Environment
Use either the Delete menu or the ludelete command to remove a boot environment. Note the following limitations.
ProcedureTo Delete an Inactive Boot Environment (Character User Interface)
  1. From the main menu, select Delete.
  2. Type the name of the inactive boot environment you want to delete:
    Name of boot environment: solaris8
    The inactive boot environment is deleted.
ProcedureTo Delete an Inactive Boot Environment (Command-Line Interface)
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Type:
    # ludelete BE_name
    BE_name
    Specifies the name of the inactive boot environment that is to be deleted
Example 7–3 Deleting an Inactive Boot Environment (Command-Line Interface)
In this example, the boot environment, second_disk, is deleted.
# ludelete second_disk
