Solaris 10 11/06 Installation Guide: Solaris Live Upgrade and Upgrade Planning
Comparing Boot Environments
Use the Compare menu or lucompare to check for differences between the active boot environment and other boot environments. To make a comparison, the inactive boot environment must be in a complete state and cannot have a copy job that is pending. See Displaying the Status of All Boot Environments.
The specified boot environment cannot have any partitions that are mounted with lumount or mount.
ProcedureTo Compare Boot Environments (Character User Interface)
  1. From the main menu, select Compare.
  2. Select either Compare to Original or Compare to an Active Boot Environment.
  3. Press F3.
  4. Type the names of the original (active) boot environment, the inactive boot environment, and the path to a file:
    Name of Parent: solaris8
    Name of Child: solaris8-1
    Full Pathname of the file to Store Output: /tmp/compare
  5. To save to the file, press F3.
    The Compare menu displays the following file attributes:
    • Mode.
    • Number of links.
    • Owner.
    • Group.
    • Checksum – Computes checksums only if the file in the specified boot environment matches its counterpart on the active boot environment in all of the fields that are described previously. If everything matches but the checksums differ, the differing checksums are appended to the entries for the compared files.
    • Size.
    • Existence of files in only one boot environment.
  6. To return to the Compare menu, press F3.
ProcedureTo Compare Boot Environments (Command-Line Interface)
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Type:
    # /usr/sbin/lucompare -i  infile (or) -t -o  outfile BE_name
    -i  infile
    Compare files that are listed in infile. The files to be compared should have absolute file names. If the entry in the file is a directory, then comparison is recursive to the directory. Use either this option or -t, not both.
    -t
    Compare only nonbinary files. This comparison uses the file(1) command on each file to determine if the file is a text file. Use either this option or -i, not both.
    -o  outfile
    Redirect the output of differences to outfile.
    BE_name
    Specifies the name of the boot environment that is compared to the active boot environment.
Example 7–2 Comparing Boot Environments (Command-Line Interface)
In this example, first_disk boot environment (source) is compared to second_disk boot environment and the results are sent to a file.
# /usr/sbin/lucompare -i  /etc/lu/compare/ \
-o /var/tmp/compare.out second_disk
