Solaris 10 11/06 Installation Guide: Solaris Flash Archives (Creation and Installation)
User-Defined Section Keywords
In addition to the keywords that are defined by the Solaris Flash archive, you can define other keywords. The Solaris Flash archive ignores user-defined keywords, but you can provide scripts or programs that process the archive identification section and use user-defined keywords. Use the following format when creating user-defined keywords:
For example, X-department is a valid name for a user-defined keyword.
For an example of using options to include user-defined keywords in the archive identification section, see Example 3–9.
