编写设备驱动程序
tran_setcap() 入口点
SCSI HBA 驱动程序的 tran_setcap(9E) 入口点通过 scsi_ifsetcap(9F) 进行调用。目标驱动程序调用 scsi_ifsetcap() 可更改 SCSA 定义的一组功能中其中一个的当前值。
目标驱动程序可能会通过将 whom 参数设置为非零值来请求为特定目标设置新值。whom 值为零通常表明请求为 SCSI 总线或适配器硬件设置新值。
tran_setcap() 应相应地返回以下值:
HBA 驱动程序可以使用函数 scsi_hba_lookup_capstr(9F) 来比较功能字符串和已定义功能的标准集。
示例 18–11 HBA 驱动程序 tran_setcap (9E) 入口点
static int
isp_scsi_setcap(
    struct scsi_address    *ap,
    char                   *cap,
    int                    value,
    int                    whom)
    struct isp             *isp;
    int                    rval = 0;
    u_char                 tgt = ap->a_target;
    int                    update_isp = 0;
    * We don't allow setting capabilities for other targets
    if (cap == NULL || whom == 0) {
        return (-1);
    isp = (struct isp *)ap->a_hba_tran->tran_hba_private;
    ISP_MUTEX_ENTER(isp);
    switch (scsi_hba_lookup_capstr(cap)) {
    case SCSI_CAP_DMA_MAX:
    case SCSI_CAP_MSG_OUT:
    case SCSI_CAP_PARITY:
    case SCSI_CAP_UNTAGGED_QING:
    case SCSI_CAP_LINKED_CMDS:
    case SCSI_CAP_RESET_NOTIFICATION:
    * None of these are settable through
    * the capability interface.
        break;
    case SCSI_CAP_DISCONNECT:
        if ((isp->isp_target_scsi_options[tgt] &
            SCSI_OPTIONS_DR) == 0) {
                break;
        } else {
            if (value) {
                isp->isp_cap[tgt] |= ISP_CAP_DISCONNECT;
            } else {
                isp->isp_cap[tgt] &= ~ISP_CAP_DISCONNECT;
        rval = 1;
        break;
    case SCSI_CAP_SYNCHRONOUS:
            SCSI_OPTIONS_SYNC) == 0) {
                break;
        } else {
            if (value) {
                isp->isp_cap[tgt] |= ISP_CAP_SYNC;
            } else {
                isp->isp_cap[tgt] &= ~ISP_CAP_SYNC;
        rval = 1;
        break;
    case SCSI_CAP_TAGGED_QING:
            SCSI_OPTIONS_DR) == 0 ||
            SCSI_OPTIONS_TAG) == 0) {
                break;
        } else {
            if (value) {
                isp->isp_cap[tgt] |= ISP_CAP_TAG;
            } else {
            isp->isp_cap[tgt] &= ~ISP_CAP_TAG;
        rval = 1;
        break;
    case SCSI_CAP_WIDE_XFER:
            SCSI_OPTIONS_WIDE) == 0) {
                break;
        } else {
            if (value) {
                isp->isp_cap[tgt] |= ISP_CAP_WIDE;
            } else {
                isp->isp_cap[tgt] &= ~ISP_CAP_WIDE;
        rval = 1;
        break;
    case SCSI_CAP_INITIATOR_ID:
        if (value < N_ISP_TARGETS_WIDE) {
            struct isp_mbox_cmd mbox_cmd;
            isp->isp_initiator_id = (u_short) value;
            * set Initiator SCSI ID
            isp_i_mbox_cmd_init(isp, &mbox_cmd, 2, 2,
            ISP_MBOX_CMD_SET_SCSI_ID,
            isp->isp_initiator_id,
            0, 0, 0, 0);
            if (isp_i_mbox_cmd_start(isp, &mbox_cmd) == 0) {
                rval = 1;
        break;
    case SCSI_CAP_ARQ:
        if (value) {
            isp->isp_cap[tgt] |= ISP_CAP_AUTOSENSE;
        } else {
            isp->isp_cap[tgt] &= ~ISP_CAP_AUTOSENSE;
        rval = 1;
        break;
    default:
        rval = -1;
        break;
    ISP_MUTEX_EXIT(isp);
    return (rval);
